Isuzu Rodeo Engine Swaps
Ive came to the conclusion that I'm going to just swap my presant engine and tranny. I've searched around and need some tech info. Does nebody know the type of tranny in a 2wd/auto V6 rodeo? Thanks in advance,,,,jt
In the meantime, if anyone else has information please feel to jump right in here!
did some more research found out the rearend is a dana 44 i know this is a strong enuff rearend and easy to regear if needed!! i think this swap is going to be a great improvment over stock. power,emissions,better fuel economy. needs to warm up to so i can do it. i need everything drawn out before i start something this involved.
I am currently performing this conversion on my Honda Passport. This vehicle is 4 wheel drive, and I am swapping in a chevy sb mated to a 700R4 trans while maintaning the original tranfer case. The original engine had a spun bearing and was too costly to rebuild. This is why I choose to swap in a V8. One thing I wanted to aviod was drive line Mods. The Isuzu transfer case spline will accept a 700R4 trans. I made a two piece adapter to make this happen. However, there is interfirence problems with the front drive shaft. I had to modify the trans oil pan a bit and move the center line of the power train 1/2 " to the drivers side to make clearance. A lift kit would make this swap much easier.( If interested I will manufacter this adapter for around $500.00) The Engine oil pan fit with no problems there is about 3/4" clearance around the IFS. Distributor is no problem either. Although, I wanted to aviod the drive line mods, I will have to shorten the rear drive shaft. The engine mounting is simple I extended the original engine perches out about 6' via 1 1/2 by 1 1/2 square tubing and modified the Isuzu mounts to work with the V8. I haven't tried to fit a starter in yet and I think I may have a problem there. If so, a gear reduction starter will fit with no problem. I plan on using shorty headers for an S10 V8 conversion.
Well this is where I'm at on this swap, I am now working on cleaning, painting and resealing every hting before I reinstall every thing for good. I will post pictures as soon as posible
this motor out with a chevy/gmc 4.3. is this possible, or should I just trade it in
for a Blazer? Thanks!
cdolce
i was looking around on craigslist and found a rebuilt motor in great shape form a 1998 Isuzu rodeo, their the same type motor, i just don't know if the to years are compatible.
does anyone know if the 1998 will fit into the 2000 without any major changes being made? :confuse:
I would love to know if I can (nearly) painlessly put this motor into a 4WD version... and what changes I may be expecting i.e. bellhousing, mounts etc.
Also important, is what years of Rodeo's can I accomplish this with?
(Is it really true I can't put this in a newer vehicle anywhere in the US?)
Thanks in advance!
Has any one else had this problem and have a solution???
Saw one guy who had swapped to a diesel engine, but he also swapped out transmission and driveline and in general sounded like an expert with access to an automotive shop.
