2000 Chevy Blazer ZR2 Turning Problems
Ok, I just bought a used 2000 Blazer ZR2 w/ 68000 miles on it. Not bad for a 2000. Anyways. I didn't notice this until I had already purchased the vehicle. When I turn very sharply on pavement (say to park) the front wheels seem to skip. It only does it when turning sharply. What could be causing this problem? Is this a normal thing for ZR2s? I've been reading through forums but haven't found anything similar to this. I am wondering if it's a problem with the differential or something. Maybe the 4 wheel drive won't disengage? I drive primarily in 2 wheel high. But it has the problem in 4 wheel also.
I have been having trouble with the passenger side door panel coming off the door and the plastic bushings that hold the . As well as some issues with my power windows malfunctioning. Can anyone tell me the best place to get these issues repaired ? Is it worth it to take it into a dealer or to find the parts on my own and have them put on at a body shop?
Any info would be greatly appreciated
Robert
What kind of power window problems are you having?
The Driver side power window seems as if it's dead.
I heard a faint grinding sound about a week ago and now it won't even go up or down.
I am not sure if it's the motor or a fuse.
used motor for S10 window
I don't work for these guys, but I have bought a couple of parts for the '02 xTreme I bought and they are quick to deliver, and the used parts were just as represented.
It seems as if the motor is probably dead.
Thanks again for your help
Robert
The faint grinding sound about a week ago does sound like the motor gave up the ghost though.
Definitely use a meter or test light to see if you are getting power to the motor. The switch is very easy to change, and is also available from s10warehouse.
I promise I don't work for or get a kick-back from those guys, but with the price of dealer parts I figure any time I find a 'good deal' I am going to spread the word.
Well if S10 warehouse is a good deal I can understand the need to want to pass that along to people. Perhaps they should have you working for them. You definitely seem to know what you're talking about and where to find parts at a reasonable price.
Which has always been very important to me when buying anything.
So, by doing a little research I was able to install the remote keyless entry for $59 with two key fobs. The dealer had to "tell" the computer that the vehicle now had RKE, but since I am a regular customer for some maintenance items, they did it for free.
As for hopping in a parking lot...mine sqeels and thats fine...just don't put the vehicle in 4x4 on pavement...it will destroy the drive shaft in the front...hense the hopping when in 4x4 is normal because something has to give as the outside wheels turn faster than the inside.
Good Luck
Glenn
Has anyone ever replaced a hub sensor?
That is about the right price AutoZone quoted you, depending on the brand. It is for the front wheel, 4WD, 5-lug bolts, 27-spline hub/bearing/sensor/reluctor wheel/ pigtail and connector assembly.
BCA / National #513124....$132
Timken #513124... $113
ACDelco FW127...$234
There are cheaper ones available on e-bay but avoid those because they are inferior off shore products and may only last a few months.
The only specialized tool you will need is a bearing puller and 3 or 4 hours at home is about right.The new car dealership gave you a courtesy bid that included an extra $278 to cover the "take it somewhere else" cost..
