Thank you for any help.
Thanks for your reply.
Does the radio look sort of like this one? 95 radio
I do appreciate your responding and giving me this info.
Thasnk you
Bob
Bob-- Southlake, Texas
Does anone have a glue-I'm reafdy to send this thing to the farm.
Rolltop1949
When you consider how much pollution the Iceland vocano has produced recently & the effects it has had on the travel & shipping industry why worry about what your engine might be doing to your local area?
Drive it.
As for the other poster, sure that volcano spewed out 750 tons of ash a second, but it is still good to have clean emissions closer to the ground where it can leach into our water tables. I forget what chemical they used to use in gas in CA, but it proved to do more harm than good when it was found in the water supply. The difference between the two is vast, the ash cloud is high up in the atmosphere and will get dispersed over a very large area, with not as great an impact as what one might think, OTOH, when you have thousands of cars spewing exhaust fumes less than 1 foot above the ground, the fumes tend to stay there and not disperse as easily, so the cleaner they are, the better off we will all breath. Of course if you like dirty exhaust fumes I can alway s bring my F350 diesel around with its 5" exhaust pipe and lay down a few smoke clouds for you if it will make you feel better. :shades:
The engine is running fine and I don't think I'm putting any damaging pollutants in the air. Yes the light problem should be solved
I can appreciate the response to my question and why the Volcano in Ireland . and the MBTE additive was mentioned. Yes these lights were put in these cars for a reason, however back in the 1990's allot of guessing was going on and most emmision parts that were put on really caused more problems than they were worth. Something like the MBTE in Calif.
I thank you for your time and response.
RVH
\ Thank you
Dash warning indicates door ajar, but multi door slams do nothing to resolve the situation. "Push Interior" on the headlight knob will also not fix it. Suggestions please.
elliottcowand@yahoo.com
mkbeth2
I have no idea how this housing comes out. I hope I haven't confused e=everybody and that someone knows exactly what I'm talking about and lead me accordingly.
RV
Now all I need to know is what do I center punch and drill out to get the regulator out? Also how does the glass come out of the channels?
Your response is greatly appreciated.
RV
Just note on what direction you get the window out. It should come out after you drill out the rivets to the window by raising the aft end and coming out with the front part of the window first, You have to reverse your procedure going back in. Put the rear in first and then the front. I will have a complete removal and installation on my experience with this regulator. Its not just a drill, a hammer and a center puinch beelieve me. I just completed my removal and installation and I now know.
RV
Now starts the hard part-
Remove as much of the black panel deadening material as you can- it doesn't have to be completely removed but enough to gain access to the SEVEN rivets that have to be drilled out. ( YES 7) Once the deadner material is removed you will see the regulator track and cables. The track is vertical. At the top under some black tape there are two holes drilled out where there are two bolts holding on the track. Remove those nuts with a 7/16" deep socket and ratchet. ( note mark the bracket where the nuts are so you can reinstall and tighten the nuts at the same place when you put in the new regulator) Get a piece of 1/4" plywood 9 1/2'" long X 4" wide and cut a 1/2" deep slot in its center on one end.. Put this piece of wood in the large opening at the aft end of the door panel under the glass window. This wood piece will hold the window glass at the proper height where you can remove the rivets attaching the glass to the track. using a punch and a hammer tap out the center inserts of all 7 rivets, with these inserts removed you will now be able to insert your drill bit into each rivet and start drilling them out completely. Remove the two holding the glass first. The aft rivet is easy to do as its out where you can see it, the forward one you have to go through an aligning hole that should be lined up with your wood piece installed. With these two rivets drilled out you should now be able to remove the glass. Forward end up and out first.. Now you have 5 rivets to go- two at the bottom of the track and three where the regulator is attached to the inner door panel.once these 5 rivets are drilled out you should now be able to remove the regulator assembly. With the glass removed completely you will be able to push the two top track studs out of the top bracket and the track should now fall down where you can remove it.
With the regulator on the bench you will see where the black plastic housing holding the cable is attached to the motor assy. There are 3 torque headed screws that you have to remove to get the motor assy away from the regulator. Now at this time pay particular attention to how this motor assy is removed, as the plate that is riveted to the glass is part of this build up & will fall free and it has to go on the new regulator the same way it was on the old one.
You are now ready to reinstall the regulator back in the door. You have to have 7 1/4" bolts approx 1/2" long, with lock washers, flat washers and nuts. These will replace the rivets you drilled out previously.
Install the regulator assy back inside the door and insert the upper two studs into the upper bracket, put on the nuts and align on the marks you put there on removal. but do not tighten. Now put in two of the 1/4" bolts at the bottom of the track, just snug them up. Then put in three 1/4" bolts into the regulator housing and tighten these bolts to proper tightness.
Remove the long rubber seal from the slot where the glass slides down into , this will provide more room for the glass to go into the door. Reinsert the Glass, use care as this is glass and can be broken. Do not force. Start with the rear of the glass in first and once the glass is in the door bring it down to your piece of wood.
Now on my installation I had to lower the glass retainer down to line up with the holes in the glass bracket. Your electrical switch will operate , just turn on the key and operate the switch. Note - remember that this window has an auto open so keep your hands clear. Operating the switch you will get the hang of it and see where you have to go to align the two holes for the glass. Install the last two 1/4" bolts and tighten to proper torque. Reinstall the long rubber seal at the top of the door panel.
Now the glass alignment. - operate the window and watch how the window travels , you do not want the window to drag as this puts undue strain on the regulator. Moving the upper two attach bolts to the right or left as they are slotted and also the bottom two bolts until you get a free smooth run on the window. Tighten the bolts top and bottom Operate a few more times to be sure you are satisfied with the operation.
Now put the black deadner back in place and then the door panel back on. You are now back in business with a job well done.
Door Regulator $119.00, I got it for $88.00 plus Tax at my Ford Dealer.
P/N F3VY-5423209*A
M/Hrs---------6 hours
Ford wanted $477.00 including the part.
Ground issue that is effected by outside temp?
Faulty Engine Temperature Control sensor?
Is it possibly the fan?
I'm puzzled. Thanks in advance for any ideas.
I'll bet the dealer wants to charge a few hours in case they start out by swapping the GEM and blow the new one due to a short somewhere else, so they cover their butt on it.
I learned a long time ago, never park a car outside for any length of time if you plan to keep it. I have a 1999 F350 Dually Diesel, parked it outside for a month, and now have to replace all the brake components, they seized up from the dampness, now I have it parked in the garage, with a trickle charger on the batteries, and a cover on it to keep the paint clean. I roll it out every so often to prevent flat spots on the tires.
RV
