Wind noise for Outlander 2007
disappointed12
Member Posts: 15
This is for tracking and discussing solutions to the excessive wind noise for Outlanders. If you are facing similar issues with your Outlanders, please post it here and also any resolutions you received, if any.
My XLS Outlander has excesssive wind noise, especially from the driver side. It's prominent around the windshield pillar (driver side), and the edge where the roof and the driver door meets (well, and the B-pillar). It is more evident (and irritating) during cross-winds.
If there is an easy solution, let's help MITSU save an otherwise good product.
I love the car otherwise, but I, too, am disappointed with the noise level from wind. Do you suppose those oversized side mirrors contribute to the problem?
I'm very interested in posts on this subject.
GROUP 42A Body
Wind Noise From Outside Mirrors - 2007
Outlander. A wind noise (a light buzz) may
originate from the outside mirror area of the
2007 Outlander when driving between 30-40
mph. The noise may be more apparent in a
cross wind. To repair this condition, remove
the plastic cover under the mirror pivot point.
Apply adhesive backed foam or felt to the two
tabs, wrapping the foam/ felt around each tab,
then reinstall the cover. Verify the repair.
Hope this will help you.
I am not bothered by wind noise, I accept this as natural, what bothers me is the noise from passing cars, engine noise of adjacent cars at a stop. Maybe, I have sensitive ears, but my other cars which are sedans do not have this problem.
I have noticed that the mountings for the roof rack have gaps, not sure how good the insulation at these locations. I also mentioned before that the seal on the channel where the rack rails run are not sealed. When I depressed the seals, a hollow channel is revealed. Also not sure if this seal should be tight.
I will try to conduct an experiment this weekend, I will try to cover the gaps with some kind of insulation and see the effect of an outside noisy radio next to my window.
Will post results.
As I said, I really love the car otherwise.
Oh yes it did "cure" all the rattling sound I hear from the right side mirror. It worked 100% for me. I am glad this was just an extra sealing to do the job and not something permanent I have to live with.
Some described an audible wind noise, which I don't have. In fact I do hear some wind noise (after closely listening) in the cabin, but not loud enough for me to complain about. Tire noise is much better compared to my GF's 03 CR-V, so no complains about that either.
I think most of us who are complaining about wind noise is not complaining abaut the "rattle", well, atleast not me. I don't have much of a rattling sound around the mirror.
I experience more wind noise only when it is windy/ when there is a cross-wind / or while driving against the wind. It's prominent from the roof-top, wind-shield and top of the door. I live in North and it is cold and sometimes windy out here. I don't know whether it is true for folks in warmer places.
I am thinking of doing some experiments before taking again to the dealer, like putting some foam tapes where there is a hollow tube seal below the rails, maybe on the top of the door and windshield too...
I will update you all with the results.
My post was actually a reply to this earlier post by mucool:
The service manager told me to come back anytime when the wind noise could be demo'd, as they were not able to characterize it today. He said, he didn't feel that the mirrors on my SUV needed the fix... I don't agree. Looking at some other posts though, I am not sure how much noise reduction the fix has to offer.
Can we say it's louder compared to make X model X? It's always nice to have a comparison. Because in my Outlander, my closest/best comparison so far is an 03 CR-V, and road/wind noise is louder in the CR-V. I wish I could own a vehicle, especially an SUV, without wind/road noise. I always thought you will have wind/road noise with any vehicle.
Interstate roads are very notorious too in creating loud road noise, especially the ones we have here in IN/IL border area. I wouldn't say they badly maintained because they're in fact being repaired section by section as of now, but I wouldn't call it bump/crack free either. And with speed limits above 50mph on these cracked roads, it's easy to see where the noise can come from.
Thanks for your input!
Thanks. :shades:
1. windows (except laminated)
2. Firewall
3. Undercarriage etc..
Aluminium roof probably has little to do with it.. but then I am not an automotive engineer..
RAV4 V6 was unexpectedly noisy too when I test drove it- engine noise, road noise and as a daily driver I don't drive a quiet car either. I was expecting a much quieter ride from a big V6 as I used to enjoy from other V6s I had/drove in the past.
Wind Noise From Outside Mirrors - 2007 Outlander.
A wind noise (a light buzz) may originate from the outside mirror area of the 2007 Outlander when driving between 30-40 mph. The noise may be more apparent in a cross wind. To repair this condition, remove the plastic cover under the mirror pivot point.
Apply adhesive backed foam or felt to the two tabs, wrapping the foam/ felt around each tab, then reinstall the cover. Verify the repair.
I did the modification myself and it FIXED the problem completely, no doubt about it. Here are some photos of how to remove the cover from the bottom of the mirror.
There is a small opening designed for a screwdriver that allows you to pry it off. Once off, just roll up some foam and place it in the middle of the cover. Then just snap the cover back on.
I went a little farther and put electrical tape on the outside to prevent air from getting into the leading edge of the gap. My plans are to make a piece of black graphics vinyl that will seal it completely and look stealth. Once I get the shape I'll post it.
But for now, absolutely no wind rattles anymore.
Pics...
Thanks so much for the tip!
Can anybody guess which forum this came from?
No, it is actually from 2007 Santa Fe Maintenance and Repair, post #144
If anyone, anyone has any suggestions or fixes for this problem, please please let me know. Else sooner or later, I will have to cut my loses and trade-in for something else.
I was planning to make long road trips this summer with my new vehicle; but now I have to go back to Hertz to do those stuffs :mad:
And talking of long trips, Winconsin here we come... Too bad the weather has been very unpredictable this past few weeks. Bikes racks and the new mountainbike are all ready for an off-road fun with the Outlander. Can't wait til it's summer already.
Really shooting in the dark now, but maybe some different tires would help.
Personally, my Outie is quiet enough for comfortable cruising.
Do an Advanced Search for "dynamat Varmint" for a bunch of posts about a member who used dynamat on his CR-V to try to quieten the road noise.
Here's one example post of his:
varmint, "Honda CR-V Owners: Accessories & Modifications" #494, 27 Apr 2005 10:18 am
http://secondskinaudio.com/cgi-bin/index.cgi
Lots of great hands on information on their forum section.
And thanks for those who gave various suggestions to reduce wind noise. I want to keep adding dynamat insulation, by removing door panels and firewall to be the last option. Does they void the warranty of the car? Can the insulation be done on the pillars too (since the pillars have airbags)
Does tightening the doors so that it is more pressed against the frame, make any improvement? The speaker on my driver side door seems to be loose. Anyone noticed that? Also, does an improper windshield installation cause more wind noise?
I did fix mine as shown in the DIY instructions posted in this thread and it works. When I go in for my first oil change I will ask the dealer if I can get the "official" fix, just for the sake of comparing the results. Either way, this is not an issue for me anymore.
My ride is fine the way it is, with some wind noise that I consider normal for this car. I guess it depends on what you compare it to.
somehow abated on my Outie, not sure of the reasons. I suspect that it takes the seals from the windows several opening and closing to make it tighter. I used to hear all the noise from cars passing by, but that was 3 months ago and several opening and closing of the windows.
Check the seals in your windows, there might be some kinks or something that prevents them from closing tight.
