Subaru Impreza Clutch questions
At 100K the clutch finally gave way. Since this is my first stick shift, I can see this happening.
Question I have:
1. Does it make sense to replace it with a STi clutch, and what will this do for me? Car is stock otherwise.
2. Are the new clutches - both standard and STi lighter than the '02/'03 units? Is one heavier than the other?
Just a couple of questions. Thanks!
Car has been great otherwise (including other issues I have posted).
Question I have:
Personally I recommend the Exedy Performance clutch, it's still organic but is a bit heavier pedal feel and better gripping force.
-mike
-mike
Having an updated Subaru Clutch package put in (I am guessing the current one for the WRX, since it also is a 5 speed). It is cheaper than the old package - $650 for parts (flywheel, plate, throttle body, spring, etc.). Does $1350 seem reasonable for the dealer to replace all this? They are dropping the Tranny which I guess is needed for the Subis.
Just curious. Regardless I am looking forward to the lighter clutch!!!!
Does this look reasonable? :confuse:
As for the flywheel being lighter from Subaru, I don't think Subaru has a lightened flywheel. If you want drop me an e-mail or post your model and I'll look up how much the exedy package is for the parts and we can see if that's a good price.
-mike
The other area is that I said the fly wheel. What I should have stated was the clutch spring.
The dealer is already working on the car.
I greatly appreciate your assistance and quick reply. It is people like you that make this board as great as it is!!!
Figure about $400 for the Exedy Sport Clutch Kit(upgrade from OEM)
Another $400 or so in labor to pull the trans and resurface the flywheel.
Should be about $800 total.
If you throw in a lightened flywheel from exedy you are looking at an additional $400
So $1200 with Exedy Sport Clutch Kid and Lightened Flyhweel would be right. But you did say it was a dealer so things usually cost more there.
-mike
If that is the case, then I can deal with the dealer charging an extra $100-$200 bucks.
Thank you for giving me peace of mind!!!
I just want to get it running well enough to sell the car and would rather not put a lot of money into it.
Thanks for any help you can offer
-mike
Imagine what 14 year old brake fluid looks like? Like nasty, melted milk chocolate. That's what the stuff looked like from my Miata. Not only was the fluid contaminated, but also the slave cylinder seals were shot.
I got lucky - a slave cylinder rebuild kit and some new brake fluid did the trick. It's been OK for the past 2 years.
First check the master cylinder. Is it holding any fluid? What does the fluid look like? Fresh brake fluid is nearly clear, with a yellowish tint. If it's brown, time to flush it out, at a minimum.
My level was low, so I could tell I had a leak, and it turned out to be the slave cylinder.
Check there, and if it's not that simple, follow paisan's advice.
A week ago I noticed a noise that was only present only when I was in gear and moving. The noise would disapear if I pushed down a couple of inches on the clutch. The noise sounded like a "ratatatatatat" or some sort of clicking sound with was corresponded with how fast I was going, regardless of the gear I was in.
2 days ago the noise started to show up when the car was idling in addition to the previous situation.
This morning when I started the car it had all of the previous conditions, and the new one was a screeching/whining/"noise basketball shoes make a a court" when I started to press down on the clutch, but only when I press it down a little. Once the clutch is fully in that noise is gone, but the clicking is still there. I'm becoming afraid and I want to see this fixed. :sick:
Whats wrong? how much does it cost? :confuse:
Thanks in advance to any advice anyone can offer.
-mike
-mike
There is a leak somewhere, the fluid has to be going somewhere.
For me, it was a leaky clutch slave cylinder. Luckily an $11 slave cylinder rebuild kit solved the problem.
Do not ignore this - you will eventually lose all clutch function, fix it!
My '98 Forester had a recall on the Brake Master Cylinder. Call 800-SUBARU3 to see if yours was covered. You might get a new one for free.
-mike
i kno the clutch is burnt up , could that have anything to do with the rough idol :confuse:
it has also been sitting in my friends yard for about 2 years so, what should i check when i am looking under the hood????? :confuse:
However, reading you post again, I am starting to think you are referring to the vehicle's idle....
The first things to check are the spark and fuel: Plugs, wires, and coil pack are likely candidates for replacement.
I'm actually very impressed that it started after sitting for 2 years. Wow.
I would change the oil and filter, spark plugs, spark plug wires, air filter, and fuel filter. Start with that. Then see how she runs.
Next I would change the ignition coil (about $80), if it's still running rough.
I would go ahead and change the transmission oil in the front (75w90 gear oil) and in the rear diff as well. I bet those are totally spent.
also why would the speakers on the car make a crackling noise ONLY when u turn teh volume up or down???? :confuse:
plz reply as soon as possible
thank u
Could be that or a bad ground.
I see these $99 specials at Best Buy for installed AM/FM/CD head units, I'd just get one of those and let them worry about it.
When mine did that I tried a new fuse, then a higher amp fuse. Finally gave up and replaced the head unit and it was cured. The speakers and everything else was OK.
Did not go to dealer, but garage who has done work for me before. Had a new factory clutch replaced, told me oem flywheel for that model and year was not available? resurfaced flywheel and clutch kit installed total $825. Price was right but now I have clutch chatter out of first and in reverse and down shifting worse then before. Was Told to drive car to break in clutch, took a few launches to help speed up break in. 10 days later not much difference. He told me to bring back but why do I still have this chatter? wondering if I should have gone to dealer?
-mike
Have you replaced the fluid?
-mike
? those that have done it ...will you do it again or pay someone else?
? is this difficult and require any special tools?
? how high would I have to lift the car from the floor?
? would i need a helper?
-- original clutch got 105K miles - pretty happy with it, i enjoy driving hard but don't race (old age and wisdom)
? what's advantage in going to another clutch vs. the Subaru stock - taking into account the dealer price - ouch!
? recommendation on clutch kit manufacturer and distributor web address?
? replace or resurface the flywheel?
? if replace then from what manft'r and distributor?
thanks!!!!
I've done several, and have paid to get recent ones done.
You'll need a clutch tool, and if you don't have air tools, you'll need them as well to break the bolts.
I'd say you need the car at least 1'-2' off the ground, enough to get the trans out from under it, you'll also need a trans jack or 2nd jack.
Several helpers would help
I've used Exedy clutches as replacements, better than stock and cheaper
I'd go for the Exedy Sport Organic Clutch kit (which includes the pilot and throwout bearing, and pressure plate)
I replaced mine with the Exedy Lightened Flywheel, easy upgrade while you are in there.
Hope this helps.
-mike
I've got air tools but i do know how difficult it is to change a clutch from a laying position vs. working under a lift. I think that i'll follow your lead and pay my local trusted mechanic ...with a lift.
Many clutch options - is this the one that you were referring to?
http://www.car-stuff.com/store/?N=11735+4294967264+1719+11921+9191
Exedy Clutch Kit 2002-2005 Subaru Impreza Pull Type Clutch FJC521; FJD024; BRG601. Availability: In Stock Usually Delivers in 2 to 3 days
FITS (ENGINE/CHASSIS)
2002-2005 Subaru Impreza W0133-1653770 $273.95
Flywheel is pricey at $471.95 - is this the one you were referring to?
http://www.car-stuff.com/store/?Ne=28&N=11735+4294967264+1719+5798
Thanks so much!
david
I assume your car is a WRX?
-mike
I went to the Exedy web site and came up with the following:
Clutch Kit - Organic (as you suggest)
- http://www.exedyusa.com/oe/15802
and the flywheel:
- http://www.exedyusa.com/oe/FF01
prices all seem to be the same regardless of distributor for a combined total of $1,020.00.
Dealer wanted $1,596 installed which included $257 for a new flywheel. Difference of $600 should be labor for my local mechanic ... and i'd get a better clutch and flywheel.
thanks,
david
-mike
May as well, though.
Any thoughts?
