Ford Mustang Interior and Trim
For those of you that have it what color do you set your gauges at? I switch from a Blue of R1 G1 B5, a Purple of R5 G1 B5 and a the preset Red.
Mark.
IT is way to freaking hard to put on. It is something that you will not do.
The Z-fold top is ALWAYS OUTSIDE OUT. This is different from other convertibles that are INSIDE OUT when the top is down. ON THOSE OTHER cars, you need the boot cover to keep the inside of your top clean and to keep the sun from destroying it.
If you are going to garage the vehicle and never drive it with the top up, then the boot cover does give you a cleaner look.
Also, go for the cloth top.
Mark.
Thanks a lot for the response. I was sensing that this thing was a waste....and you just confirmed it! I will put my order in without this option.
Thanks man!
Mike
Second, if you put the key into the ignition and cycle from off to start to off about 8 times in a row and the locks pop up and down then you have remote keyless.
Mark.
