Lincoln Navigator Suspension
We just replaced the compressor relay and now the compressor is coming on, but the rear of the truck still won't lift. Does anyone have any ideal of what could be wrong? We also noticed that when we open any of the trucks doors the compressor shuts off.
Sorry for the probably silly question, but I'm brand new to this vehicle and this type of suspension. Any info would be greatly appreciated.
Personally I like the air suspension, though it can be more troublesome than simple shock absorbers, it is more functional. Troubles you're likely to see as the truck ages are leaky air shocks and/or lines and perhaps a probelm with the compressor or dryer.
I had a 93 Mark VIII with similar system. Saw no probs with air until close to 8 years/100K miles. Most cars would've gone thru at least one set of shocks by then.
Thanks for the help. As we just purchased the vehicle, the dealer will make good on any issues.
C U on the trail!
Did you find out the problem, I am having the same problem with mine, I have replaced the compressor, relay, height sensor ect it worked for about a day and now rear end is low as she can go.
Fox
I heard this gunshot type sound, and checked under the hood, and found the top had blown off the compressor dryer and the little clear pellets had blown out as well. Do I need the WHOLE compressor, or just the black cylinder??
Thanks for the help, I have to order it ASAP.
Tom
I'm having the same problem.Where is the RELAY located at???? I know it costs $ 125 at dealer , but they don't tell where it is at!
My wife took it to the dealer and they said was the PUMP and the RELAY and ask for $ 1k. I'll replace the relay and see how it goes!
Can you tell me just where the relay is located? I believe that it is located on the frame near the drivers door. Also do you have the instructions to bypass the relay?
When this first happened and after a couple of days with the switch turned off. I turned it back on and the compressor lifted the back end up, I then turned off the switch again and it stayed up, until I started playing around with it.
I'll replace the relay and then the compressor and dryer. I've found the compressor for $115.00.
Here's the problem... Ever since that happened, my air suspension started acting funny. The car would sometimes have a bumpy ride. Almost like riding a lowered car. I also noticed that sometimes the rear end would sit too high when parked. Sometimes one side of the rear end would sit higher than the other. Once in a while I'd hear the air suspension go but not as much as before. I always hear that "click click" sound coming from the rear end everytime I park. Occasionally, I'd hear it while I'm driving too. It sounds like a relay but I'm not sure.
I need your help. Please advice me of what to do. Thank you so much!!!
Any advice on not getting ripped off tomorrow? Parts to check, etc?
I'll post back when I get the 'Gator back home.
Gatorrob
Somebody told me that it needs a new vent solenoid for that particular problem. I never got the chance to look that up coz' I'm happy the way my car is riding for now.
Let me know what the dealer says... Good luck!!!
These are the facts:
'98 navigator sits on the rear tires. I didnt hear anything before it 'broke'. nothing seems bad under the hood.
I'd bet there was a slow leak and I used to hear the compressor often. Now I dont hear the compressor at all. My guess is relay and/or compressor.
thanks for any and all help.
It seems to have fixed my problem.
The only tidbits of help are that I had to take it for a drive to activate the compressor. At 15 MPH i heard a slight squeal of the compressor turning on as I never heard that before. I used to hear a low humm/vibration (many thanks to the earlier post that identified that).
Also, I had to stop and do some web browsing to figure out how to remove the air tubes (press in, on the orange OR brass ring while tugging on the tube). Many thanks to one of those replacement part web sites that had this as a FAQ.
While I dont seem to have any problems, I cant find the relay for future reference. I looked under the driver's door, on the frame under the truck, and didnt see it. Can somebody provide some clarification on this?
thanks for the help and I hope this helps others.
one clarification. I only had to replace the compressor/dryer unit.
I'm on my way back to see if the problem has been fixed. Hopefully this will be the last of my troubles with this obviously common problem. I would've done it myself but convenience comes into play.... Oh well.
Good Luck
I do not hear the compressor at all. I'm just hoping that by checking everything else, it could be something other than the compressor. I will check it after I get off from work and will post back.
http://www.arnottindustries.com/part_LINCOLN_Air_Suspension_Parts_yid2_pid67.htm- l
I have an '03 Nav. Had a screw in one of my tires and air pressure was low. Then the chesck suspension light came on!
Leak turned into a flat (no surprise!) before I got it changed. Turned off the air ride suspension before changing tire and turned it back on, now she's riding low on the left side (back and front)! Is there a way to reset the suspension?? :confuse: :confuse:
Any suggestions would be greatly appreciated. Thanks.
alex
We've gone over a month without the system falling to the frame.
Good Luck
$700 later they changed the rear height sensors (parts only costing $240; labor $115/hour ) I'm ridin' right!!!
So I take it that it may be normal to sit low in front until you start truck and close ALL the dorrs ?? Do you have to put in gear or drive ??
Good Luck
Good Luck
