Subaru Legacy/Outback Unusual Clunks and Noises
Hello All.
Have a quick question about a 95' Legacy L wagon with FWD. I bought the car in 2004 with 154,00 miles on it. It's been a good car so far. My only problem has been this strange continuing noise up front on the driver side. I was told it was the front driver side axle. So I had it replaced in 2004. then again 2005. I am starting to think it is something else. I don't travel up hills much, as I know this is hard on those front axles. The noise develops arond 35 Mph very softly, kinda sounds like a blrrrrrr, then changes in sound with engine rpm's. It can only be heard on the driver side. The sound will return around 50mph when the rpm's drop, this is when it becomes quite loud with a blrr poppy sound kind a. At 70mph it really sings. once over 80mph it goes away. the sound is only heard mainly at o to 35 mph then slowly you hear it again at higher speeds. when you let of the pedal it makes a reveresed blrrrrr sound. I recently had it in the shop for a check and no one found anything wrong, even during test drives the mechanic never hears it. only one time did they hear it when I pointed it out. the axle was replaced, but the sound came back almost right away coming of the lot. any ideas ?
Appreciate any comments/assistance.
Then, if it gets worse after the warranty expires, you can say you pointed it out before it expired.
-juice
The bearings were a common enough problem that I'd have that checked out. Maybe they replaced those when the swapped the axle, though. By the way, I'd do both sides to keep things in balance.
-juice
CVs are actually a fairly simple repair, we did a set on a legacy this pas weekend in about 2hrs. Cheap parts too.
-mike
I did not consider replacing the joint itself as the local advice at the time (that was pre-Edmunds days for me) was that they are built to be a one-piece unit.
-mike
$60
confused ? LOL
Cheers Pat.
-Brad
:lemon:
Even if what you are hearing is piston slap, it has very little affect on the life of the engine and you have stated that it hardly every happens and goes away after the car warms up. I am not seeing what the big deal about this is? Is is really that bad of a problem to get justify getting rid of the car? I guess you might see this as being a terrible problem, but I guess I just don't see it.
I seem to be seeing more of this lately. Someone has one minor problem with their car and they are flaming away on message boards saying how horrible their car is, etc... I owned a 2001 VW Passat, I KNOW what an unrealiable car is, and yours ain't got nothing on it.
From what I have read online, it is prone to happen around 100k miles.
( had about 57k at the time, and less than the 5 years).
i did exactly this, and the next morning, sure enough, it was the proud owner of a loud ticking noise, which became more apparent as rpm's increase in city driving. ( please also note that the dealer replaced the timing belt since this had to be removed anyway, and i only had to pay for the part)... at highway speeds, the noise is very hard to discern, primarily due to highway and tire noise, and running at about 2,500 to 3, 000 rpm on the tach....
the local gargage, which is highly respected and aaa approved, noted that they have mentioned that the valves might need to be adjusted as this is common when timing belts are replaced.... the dealer however explained that this should not be necessary because the valves were not impacted when this major engine work was performed...
the question to subaru was, why did this new headache inducing noise appear after this major engine work when it never, ever made this noise before..... tis a mystery to them, and next week it will go in to the dealer for analysis and whatever engine repair is necessary to eliminate this unpleasant situation.. this will be under my extended warranty purchased through the dealer at the time of purchase, so glad i did...........
and for the individual who may think this should not be made a big deal.... spend 27 grand for something which now sounds like my '62 beetle's engine and you be happy with it... we all should expect high quality from suburu for what they tout as exeptionally crafted automobiles....
Our fairly new(to us) 96 Brighton AWD Wagon w/136k on the odo has a ballsy rumble coming from under the vehicle. To me it sounds more pronounced in the back seat than the fdront, but I now how sound can travel from its origination point in a vehicle. It is pretty consistent both in town at low speeds and also on the highway. The noise seems to be vehicle speed-related and not engine speed-related, so I'm leaning towards drivetrain issues.
Before I go in and replace wheel bearings, wheels/tires, Center Driveshaft bearing, axles, and tear into the rear differential, I was hoping this forum could help me isolate the cause a bit.
My wife drives it more than I do, so her despription is what I'm using here. She says(and PO comfirms this) that the noise is more pronounced when making a sweeping right hand turn on the open road but turning back to the left, the noise is still there, but not as noisy. A simple right hand turn on a city street doesn't generate any more noise than a left hand turn and no clicking sound symptomatic of a CV joint going bad.
The PO is a friend of ours and has stated that this noise has been with the vehicle for as long as they've owned it and it hasn't gotten any worse over the last 50k. Thee PO did some on- line research and found out that Subaru re-designed the 97 model drivetrain to get rid of this "problem".
If any of you know what this is specificically and how to fix it, I'd be eternally grateful?
New tires didn't solve the problem for the PO, so I'm sorta ruling that out.
If I have to install a 97 or later rear Differential or drive train, will they interchange and how do I tell if I'm getting an"improved" model other than checking the VIN number on the car?
Max
Replacement of the front drive shaft (which included the bearing) with a junkyard special solved the problem and it never returned (put 140K additional miles on the car). New, I think the "part" was about $500, because for some moronic reason the bearing was not available without the front shaft. Basically, these are two separate parts, save for the bearing having a slightly dented bit of metal on it to affix it to the shaft. Once removed from the car, a heavy duty screwdriver will shift that metal "ding" and allow you to slip the bearing off the shaft. Finding a new bearing, though, might be tricky unless a shaft is attached. :sick:
To me, it almost sounded like someone thwacking the underside of the car with a rubber mallet.
As an aside, the PO did tow a fair sized power boat with the car, so the rear wheel bearings could be over worked a bit. I'll update when there's something to update!!
DM&FS
Have you got any further with your investigation? It would be useful to know what you have found out before I take mine to the mechanic.
Alex
-mike
Any ideas,
Frustrated
-mike
Motorsports and Modifications Host
If it is a "dull" noise rather than a metallic ticking, then it is likely plastic.
You might also check to see if there is something small and flexible wedged through the radiator and protruding into the space where the dual cooling fans spin. The fans might be sucking it in occasionally, while other times it flops down and sticks to the radiator.
Just brainstorming here....
When I turn the car off after driving, the engine continues to make a clicking sound for a while. It almost sounds like a faucet dripping (but there is no leak on the ground) or clicking sound which continues for a minute or two. Someone told me that this is the sound of the exhaust system cooling down. Is this true? I hear the same sound if I stop the car and put it in park but leave the engine on.... I don't hear it when just idling at a light (not in park).
Also, when I do I a cold start of the engine, it is very loud at first. The noise goes down significantly as the car warms up. After fully warm, the car is very quiet. Just wondering whether is normal or not and what other people's experiences were with both types of engine noise.
As for noise on start-up, what sort of noise is it and at what temperatures do you hear it?
The noise at start-up is not really an unusual sound... regular engine start-up sound but it is a lot louder than other cars I've had in the past... mostly Hondas. Once the car warms up, the engine sound is ok. Is this just typical of boxer engines?
Some folks have reported PZEV engines running very rough upon cold start. I noticed on Subaru's website a few days ago that there is a TSB related to this, though I have not looked at it.
There is also a TSB about a noise from the exhaust during startup which is normal and related to the lean burning also.
It seems people in the NW and New England are complaining most about the PZEVs. Is there gas there different from CA and the midwest??
-mike
We've had it less than 2 months and haven't driven it any real distance - just around town, to and from work, etc. About a week ago, it started making "chattering" noises - the best way to describe it is that it sounds like it's a diesel engine when it's not. It's not driving any differently or acting "funny" at all. It's about 200 miles overdue for an oil change, though.
My husband had a mechanic friend take a look and listen and he said something about the "cams" in such an old car not being able to hold enough oil and how that's usually remedied by adding something that will allow the valve to close to hold oil? I just called a mechanic in town and he said to check to make sure the oil isn't low.
Any ideas from any of you out there?
This is a car with more than a quarter million miles - make a habit of checking the oil with every fueling.
-mike
