2000 Taurus Rear Door Panel
                    How do you remove the rear door panel on a 2000 Taurus.  I see three screws but nothing else.  I am sure there are plugs. After removing the screws can I just pry off the panel and pop the plugs
You will get a complete description of all major components and how to de & reintsall and repair.
They usually cost less than $30.00.
Good luck
Any thoughts???
Good luck
Mark.
Like I mentioned in my previous answer, I got an estimate for $150 last year. Have done nothing so far but I hate looking at the blank panels every day! :confuse:
I have contacted the Ford Customer Relations via phone, received a case number and have sent a letter to them along with pictures. I have asked Ford to reimburse for the cost of replacement which was done by the dealer to the tune of about $350-400 for each door. Have not heard back yet.
This of course raises the question on why anyone would intentionally glue leather patches on a plastic car door.
A Sable/Taurus isn't some high end luxury car that is kept out of direct sun every moment it isn't on the road and looked after by an employee who has interior leather care as one item on their regular detailing regiment.
The plastic door panel had to be a hint.
Someone had to know what would happen.
It is just like when the all plastic proprietary headlight switch knob broke and cost me $20 at the dealership (replacing it myself). Can you believe they wanted to give me a quote for the labor?
I almost have to think it was an intentional choice. :lemon:
I tried to order a switch from Direct Ford On Line but they sent me a combo dome light switch. So my thinking now is that the sunroof was an aftermarket addition.
Any ideas where I can get a replacement switch?
It is a stand alone toggle switch in front of the opening.
Not sure if taking the panel off will allow me access to that one "pleather" area that needs to be repaired".
Ebay has some Charcoal gray, but I need the regualar Gray panels.
Can't even find a junk yard here in my area, yet I know they exist.
Alan, Chesapeake, VA
Still, figured Ford/Mercury would have said something long ago.
I will see if I can find an ulphoster in the area here in SE Virginia.
Thanks for the info
Alan
http://www.taurusclub.com/forum/116-aesthetics-interior-wheels-tires/151636-comm- on-inside-door-panel-gen-4-failure.html
This "tutorial" was great, but my fix was a little more simple. I didn't have the carpet between the panel and the leather/vinyl material. I just had the spray on foam.
So all I did was yank each panel off (careful because the long panels like to snap in half!). Then I cleaned the edges of each panel and each piece of vinyl/leather, scrapping off the spray-on foam then scrubbing the edge with a little rubbing alcohol. I made sure they dried and then I bought a couple hundred clothespins (50 for a $1 at Walmart), and 3-4 bottles of Loctite super glue (15 second dry time; $4 at Walmart). I used clamps (don't need to buy if you don't have them) to clamp the material to the panel as I went along and laid super glue, then pinched the material together with the clothespins, as shown in savetheland's photos.
I let it dry over night. I pushed the panels back onto and adhered them to the door using UGlu strips (from Walgreens, price ??) That might have been a bad idea, but so far the strips have worked great to hold the panels back on. And the adhesive was strong enough to "de-warp" the warped panel I had.
For me, this was definitely worth it over spending $50-150 per door for a shop to do it for you.
