Jeep Liberty Towing
I want to use my 2004 Liberty to tow a 1 horse trailer. The owners books says it can handle it. I had a hitch installed, but the installer said he didn't know where/how to install the brake controller.
How do I do this?
How do I do this?
It's too bad dealers don't hook up trailers so you can do a complete test drive
Thanks for your time
Towed a 12x6 enclosed trailer no problem.
Towed a 1500 lbs Kubota tractor no problem.
I have pulled a 15 Passenger VAN out of snow stuck on the side with no problem.
its capable, just be nice to it
A towing test with a brand new vehicle would likely damage the rear differential. Some dealers will let you take a used vehicle for hours or even a day. Find a used one with a hitch and try it out.
I'll be pulling a uhaul trailer, thinkin about a 5x10 cu.ft. The place where I'll be getting the trailer from, says I will have to drive Jeep in 4wd all the way there. Will I really have to do this? I've never used it to pull anything before.
Thnx, :shades:
When your transfer case is in AWD the setup is virtually the same as most of the older Grand Cherokees that only had AWD for towing and normal driving.
Can anyone give me advice to where or what I need to do to hook up the tow wiring with out cutting into the wiring harness itself?
Thanks...
Orly. :confuse:
Thanks Paul
the dealer told me a Chev pickup would cost $90.00 but something about the Liberty uses up many hundreds of dollars worth of Labour
and the approximate cost ? 2005 Liberty Sport 3.7 litre 6 speed manual
If you are looking for a 'real' bumper, then you may have some difficulty. I've searched all over and only found one. It is a heavy steel bumper for off-road use. Cost about $900. You probably would have to do some cutting and welding to install it.
I bought a kit, popped both taillight fixtures out, ran the wires up through the openings from underneath (no drilling required) and connected the new wiring harness.
You just unplug the existing wires from the brake/tail lights, and then connect the kit wiring in between.
I would rather not have to scale down to the 16' model.
Didthe Liberty CRD and T@da for about half of what an Airstream & more powerful vehicle would cost.
I have a 2004 Jeep Liberty and will be renting a travel trailer next weekend to attend the Dover race. I'm renting the trailer from Ft Meade and they are telling me The Original Aerolite A21 RDB 20 ft (which I can't find true specs on) is around 4700lbs fully weighed down. I have a tow hitch and electronic braking system and am a bit worried about the 4700lbs. The drive will be flat towing except for driving over the Bay Bridge. I am planning on a slow drive out there but want to make sure the Jeep is capable of this towing. I won't have anything loaded in the trailer, just minimum gas in one tank and will fill up with water when I reach my destination. Should I be worried?
I also live in a mountain area and I know diesels need to breathe to provide the extra effort. I have close to 100,000 miles and this engine performs better than it did when I got it new :shades:
For info: During 4 hours at a steady 80 mph with 3 passengers plus luggage and 90 degrees Fahrenheit (in the shade), the temperature indicator needle did not pass over the mid temperature line.
For "lightnin3": my tire pressure was 39psi
I have a friend with the same vehicle and he said there was a Technical Service Bulletin (TSB) out and they fixed his, but he couldn't remeber the details. I asked the dealer and they said "huh?". I did some looking on another forum, and they show TSB 08-043-05 as reprogramming the software so the gauge shows the correct temperature.
It sounds fishy to me, because of the abrupt runup from straight up to far right on the gauge and it only happens when towing uphill.
I'll go back to the dealer with the TSB number and see what I get.
