Bought it in September when it was still mostly warm. The rain doesn't seem to cause it to not start, but as soon as it got cold it started having issues. Its automatic and I'm more used to driving manual, but once its started at least I know that it need more gas to keep it started. It shimmies and shakes until I get it moving, then maybe 100yards later it evens out. Three seperate mechanics think I'm nuts cause it always starts when they try it. Automatic is started just by turning the key right? I shouldn't have to pump the gas to get it started right?
I thought I would throw this out for you to mull over.
From that he was now pretty sure it was the trucks computer, and when I told him that the first time we did a engine diagnostic the fuse that let the computers talk was missing, he became certain that it was the computer. I had bought the truck used and we now figure that the dealer or prior own just fudged things to make it sell able. And since the seller did some work on it before I took it home, we think it was him because apparently some of the issues Ive had were noticeable to anyone that knew what an engine was supposed to be like. er that meant not me.
I'll let you know how the computer change goes.
My problem only coincidentaly occurred after I had it serviced for an engine light on and poor idling. They checked/"cleaned" the EGR valve (said it may have been sticking open - which you'll read causes poor idle or even failure to start), replaced the fuel filter (said it was extremely clogged). The truck immediately ran great, but the next day I experienced my first "no-start".
When we experience the no-start, some of us do two things: 1) keep trying until we eventually wear the battery down, at which point calling for a jump start which somethimes gets the truck going, and thus leads us to mistakenly think its a battery power issue, or 2) keep trying until we flood the engine, which is when you smell raw fuel and it takes anywhere from 1/2 hour to a couple days later when you try to start it and it gets going like no problem.
Anyway, I took it back to the shop that week and they checked the fuel pressure (apparently was at 36psi), so a new fuel pump was put in. Then it started running poorly again(maybe the EGR that I did not replace), but the truck started alright for about a week, until this morning. After trying to start it a few times in about 10min span, i finally let it sit for about 25mins, and then attempted again to start it. This time, after two extended attempts she finally wound up and caught - just as the Road Service Guy was pulling up to attempt a jump start.
I haven't figured it out yet, but this weekend I'm going to put in a new set of spark plug wires. A few times in the past the spark plug wire change has done the trick when I had poor idle and performance. As it was explained to me, they get crappy over time - especially the cheaper ones - and what happens is they become more prone to taking on moisture. This is why a warm vehicle (or one thats only sat a few hours) starts right up - because the wires are nice and dry and delivering full power spark. You let it sit a couple of days and the suck in the humidity and are cold and you have trouble starting on the first attempt - and then you end up in situation #1 or #2 i described above.
I'll let you all know if it works.
Two weeks ago my service engine light started flashing at a rapid pace. The engine started acting like it was fuel starved or not getting proper spark. I managed to limp home by taking automatic out of gear at stop lights and keeping foot on gas to keep revs up. When I got home I turned engine off -tried to restart--would not start-would crank but NO start.
Had it towed to local garage-they said their code scanner could not get ECM box to work or could not get codes. Replace ECM box with new one-still same thing. Checked fuel pressure-OK-checked spark to plugs -OK-checkd voltage to injectors-not ok no voltage at all.
Have tried everything--this 4.3 V6 does not have a crankshaft sensor --has distributor--does anyone have any idea at all what the problem is???
thanking all in advance
Mike :sick:
http://theconservativearmyforumreview.podomatic.com/
unstick and clean central sequential fuel injection poppet valves. it is covered under warranty for 10 years or 200,000 miles. i kept getting code po300 and this fixed it.
hope this will help someone.
now.
it wont start. It cranks over has gas, spark, . i cleaned the spark plug holes out ( removed all plugs and turned over a couple of times spitting everything into rags), and allowed to sit for a couple hours b4 placeing new plugs in. i had to turn the rotar on the distributor 180 out cuz it was poofing through the intake, after the 180 out fixed that. but still same situation, the battery is good getting 14-15v has been on a charger most the time to keep it charged.
basically, I have spark, fuel, and no start, i have also tried using starting fluid as well to no avail,was putting smoke out the exhaust a few times while cranking, i am assuming this has no relation to my actual problem. and to top it all off im in the middle of getting ready to move.
Thanks in advance for any advise!
wires, cap, button, ignition mod under button, coil, and coil wire. Is there a crank
sensor that I'm not aware of? Could the ECM be at fault?
Fuel pressure while cranking is 42 and goes to 45 on start up.
While it is running the brake light is on and it idles at half throttle.
All ideas are appreciated.
Crazy thing is while it's turning over, it seems every now and then to 'bog' like something's mechanically holding the crankshaft back.....then releases and bogs again. Even with my Ranger next to it running with jumper cables keeping his battery up. We finally tried cranking it so much that smoke rolled out of the starter motor.
My question is.....is it the starter doing all this, or did we maybe burn the starter up due to an underlying problem? We took Serp belt off and checked all pulleys and turned motor over with just the crank being turned and it still bogs. Anyone got any ideas?............it'll be Monday or so before he gets the new starter. I just wonder what it could be if it still won't crank. Thanks. :lemon: ?
Try to start it and at the same time have some one hit the bottom of the tank below the fuel pump with a mallet or piece of 2X4, see if it starts.
B. test light
C. compression guage
D. vacuum pump/guage
E. torque wrench
F. screw drivers/phillips/standard/torx
G.socket set /metric/english/ 1/4, 3/8, 1/2 drive
H. wrenchs /box/open end/crow foot
