Saturn Aura Real World MPG
What kind of MPG are you getting with your Aura?
We will be taking a 600 mile trip next week in our XR. We have about 6000 miles on it right now and I am hoping the mileage will finally be up to spec's. :shades:
Have a safe trip.
Phaeton Driver
We went from the hot, So Cal, lower desert to Morro Bay. We used US 101 for the drive up and back with a different connection route each way so as to keep it fresh.
330 miles each way with a round trip average of 27.88 MPG
We had 240 miles of mountain and city driving in the Morro Bay/Atascadero area. The mountain road was mostly performance driving (using that 6 speed paddle shifter) when traffic permitted.
Overall, 900 miles on 34 U.S. Gal. of 87 Octane (Avg Cost 3.399/gal )net us 26.5 MPG.
So Far, my wife and I are 100% satisfied with the MPG and performance balance of this Saturn Aura XR. :shades:
I was driving between 75 and 80 for most of our 660 miles on the highway.
I figure we are getting about 24 combined MPG.
Oh! and having a lot of fun at the same time.
still it is very tempting. the ride was so sweet.
But hey! if you short shift it and keep up with traffic instead of staying in front, the mileage isn't bad.
It's never going to be a Scion or other gas sipping econobox. But there not as much fun or comfortable as the XR. :shades:
MPG I am getting is 20.8 ; mostly city driving.
I now have 11300 miles on my XR and still lov'n every minute, well maybe not every...
I actually got 29.5-MPG for about 350 miles in Washington and Oregon. Sure it was flat but but I was averaging 80-MPH. Last month I went to Arizona and that was flat too, but I could only muster 26.4 for about 400 miles, average 78-MPH, before it got hilly.
My trip north showed 26.2 for ~1150 miles with plenty of stops and one overnight. I averaged 63-MPH for the 1150 miles. My trip south averages 68-MPH and 28.2-MPG.
The whole trip according to the computer showed 66-MPH and 26.8-MPG for 2300 miles.
I am so pleased it is finally coming around. :shades:
ONE THING THAT HAS HELPED THE MPG IS RUNNING THE LOW PROFILE GOODYEARS AT 40-PSI. This is 4 PSI below maximum which helped keep them cool and lower the rolling resistance (friction). The ride was a bit harsh, but it was worth it I think.
I also have over 6000 miles on this oil and the computer says I am at 30% remaining. That is killer. I am taking it in anyway for the oil/filter change next week.
I am going to replace a quart of oil with a quart of Dura Lube before the next trip to Arizona in September. We'll see if that helps the MPG like it has in my other cars.
Low pressure can ruin a tire, and with these low profile tires you could damage a rim too.
NOTE: When you have your tires rotated, be sure the tire mechanic knows to relocate the valve stems. My mechanic didn't so when my tire got a nail the diag system said it was a front tire when it was the rear one.
Your XE should get better than my XR but I think you need to give it at least 10000 miles to brake in the engine.
So before you throw in the towel, wait at least 10-12K miles then re-evaluate your XE
Phaeton Driver
I recommend you rely on the EPA labels to get a relative (not absolute) sense of fuel economy. The EPA test cycle removes the variation in driver behavior and is a measure of the vehicle.
Personally, I think the Aura is a fun car and I find myself driving it hard -- and there are consequences with respect to fuel economy. With Aura you can achieve good gas mileage by driving conservatively, but you can also have fun when so desired.
To try to get a handle on what I'm apt to achieve based on the new numbers, I took my current average MPG and then adjusted the ratio of city/highway driving of the new numbers to deliver that number, and then use that combination to compare cars under the new system. Basically before on the old numbers my mileage equated to something like 80% city/20% highway, but using the new numbers now it's basically 50/50. Even though most of my driving is around town, much of that is on the Interstate that bisects our city, so technically I probably do more highway driving than I think I do, so 50/50 is more realistic.
I swapped a V-10 3/4 ton truck (10MPG) for a Saturn Aura because I didn't need the big truck and wanted a high performance 4 door sedan. My budget was $25000 with trade in so that eliminated a lot of German and Japanese Performance sedans.
I got everything I wanted in the Aura XR and if I only average 25 MPG, the way I drive, I couldn't be happier.
I hope you get a car that you enjoy and makes your heart pump and your face smile from ear to ear like my Saturn does for me.
Good Luck
Phaeton Driver
Also, I am guessing you aren't old enough to remember when we had to drive a car and various speeds and not to fast for the first few thousand miles then drive them on the highway and go fast for a few minutes. This was (one type) of recommended break-in procedure. If you just drove normally your engine would either never see it's potential or it would burn oil forever.
Todays engines/materials don't require the same techniques, but if you follow the old ways the power train will work better and last longer.
I am old school when it comes to break-in and may have something to do with my XR getting better than average MPG's and better than average acceleration (0-60 in 6.0 and 60-100 in 7.6). One trip I got 26.8 MPG for 2300 miles and another gave over 30 MPG for 350 miles.
I have over 13000 miles now and the XR is better than ever.
Phaeton Driver
Hey friend...I have a 2007 KIA Optima, and get at least 33MPG Hwy.(A high of 40.7)Hardly an econobox.Loaded with ALL available options and of course...a 4 cyl engine.It's plenty strong enough to suit me.I believe it's rated at 165 HP which is more than my 1952 Lincoln V8 was.
BTW we went to a dealer yesterday to look for an Aura Hybrid...of course they didnt have one,but I did look at a top of the line Aura and the leather seats and the dash were all very nice.Unfortunately it only comes with a V6 and with the $92 per barrel oil...very impractical. :sick:
My 2007 Aura XR 3.6 is doing just what I thought (and hoped) it would.
A couple of months ago I changed the oil and added a quart of Dura Lub.
I have done this in several other cars and it always improved my MPG and made the engine run very smooth. Well the 3.6 now idles and revs silky smooth. Idle is now about 800 RPM. I guess the computer only gives the engine enough gas to keep it running, and that is less now so lower RPM is the result.
I just took a trip to Northern California. Total miles 910. 870 of it on I-5and I-10.
I cruised at or close to 80 MPH whenever possible. The trip computer said I averaged 68 MPH for the 910 miles.
It used 30.08 gal of 87 octane for the 910 miles. I think this equate to 30.25 MPG.
The formula is keep tire pressure close to 40 PSI, the tires are rated MAX @ 44 PSI so this is quite safe. Add an engine oil additive like Dura Lub, Slik 50, or any other additive with PTFE. Now I don't have any ties to any company that produces this stuff, I just have had a lot of success using it. An alternative with similar results would be a synthetic oil like Mobile 1. Difference is you buy the additive ones every 50K miles, the oil every 3000 miles.
Now my XR is every thing I wanted and I can no longer whine about the MPG.
Take that you Accord lovers
The formula is keep tire pressure close to 40 PSI, the tires are rated MAX 44 PSI so this is quite safe. Add an engine oil additive like Dura Lub, Slik 50, or any other additive with PTFE.
Wow, 30 MPG! I am getting 27 mpg in my XR going 25 miles one way to work and back. Do you really think that the additives are making the difference or the tire pressure? Also, why do you suppose the manufacturer recommends 30 psi and no additives?
My on-board computer said I got 27.8MPG for the trip, so you can't believe it, monitor the gas and miles and do the math for accurate MPG. I drove for MPG so I was easy on the go peddle, resisted the urges to pass everyone, and used the cruise control as mush as possible. When going uphill I used the manual mode and dropped to 5th and slowed my speed to mid to low 70's.
I have used these PTFE additives for a long long time (about 1980) and every time it has proven to me to give more H-P, better MPG and longer engine life. The only car I ran Mobile 1 in was a turbocharged sport coupe and that was because of the hi-temp oil cokeing problems turbo's have.
The Tires say max PSI is 44 so for best traction and mileage/wear you want to run them at about 85-90% cold of that Maximum.
Several things happen when you do this.
1. The tires run cooler so tire pressure stays closer to the cold setting. Blowouts occurs most often to under inflated tires because the hi temp form scrubbing more tread on the pavement causes the air inside to expand much more.
2. The tires stay flatter on the ground when cornering and provide a more secure ride on those fast mountain roads. I used to race auto-cross and I found that running 50 PSI gave me the best traction in the corners. The runs were too short to cause tire failures at these hi pressures, but a long trip could cause tire failure.
3. The ride gets hard, not as comfortable, when pressures are higher than the car manufacturer recommends. In the case of the Aura, I think one of two reasons for the 30 PSI recommendation is a nice soft ride and the second is the pressure is actually the recommendation for the 16 inch 65 series tires. When you go to a lower profile you need to increase the pressure or risk damaging the rims and tires when you hit those nasty bumps and cracks on the interstate.
I am extremely happy with the ride and handling I get with my tires at 38-40 PSI. And there doesn't seem to be any wear on them at all with over 14000 miles.
Hope this helps
One more question:
Do you get a Tire Pressure Monitor warning when your tire pressure is that high?
No. The tire monitor doesn't warn of high pressure, just low, Mine has done this twice, both time the tire was about 25 psi due to a nail.
I do get a report email telling me my tires are not inflated to the recommended 30 psi.
I am not concerned about any excessive tire wear or unusual handling because of tires being inflated to 38-40 psi, especially for freeway driving. Just the opposite is true.
Check it out for one tank of gas on your daily commute. Can't hurt to verify what I am saying.
My trip computer said I got 26.7 MPG
My calculations show it was more like 28.6MPG :shades:
There was about 850 miles of freeway driving (50 - 80 MPH), the rest was city driving, short trips of 2-5 miles at 0- 40 MPH.
I am totally stoked at this mileage in a 250 HP sedan.
If one of those 4 bangers that gets 34 highway MPG could get 30 MPG combined would have saved about 2.5 gallons on the same 1150 miles, or $8.
The savings of $7 per 1000 miles? That's $350 for 50K miles saved by the 4 bangers.
Big deal :surprise:
Not I-4 mpg but very good for a 3.6/252hp V6 I think.
Anyone interested in some really good mileage? check pout this new car from BMW. I took this pix at a Palm Springs parking lot, notice the plate is from Canada :shades:
See more Car Pictures at CarSpace.com">
I now have over 17000 miles and the DIC says I have 40% of my oil life remaining. At this rate I will be over 12000 miles on this oil change. The only thing I have done to the oil was replace one quart of oil with one quart of Slick 50.
Anyone else experiencing this kind of oil life according to the DIC in their Aura?
Anyone using Mobile 1 and if so are they getting unusually long oil life according to the DIC oil life meter?
To maintain the warranty I need to change the oil when the DIC indicates I am within 10% of the oil life.
I have just been reading of other GM owners that are getting very high mileage between oil changes according to the on board oil life computer.
I have 6800 miles om my XR, 30% life left according to DIC. This next change will be my first. I have not done anything to my oil.
So I am in unchartered territory here with going so long without an oil change.....
Regards:
OldCEM
I have a 2007 Aura XR so it has a bigger engine and more HP than the 3.5 you are considering. I have had this vehicle for about 6 months now and I check and re-set my mpg with every fill up. I drive my vehicle to and from work and around town and I have been getting around 27 mpg overall. If I do a lot of "around town" driving, my mpg creeps down to around 24 or 25 mpg.
I am very happy with my mpg especially considering the >250 hp V6 under the hood! For the money, you simply can't beat an Aura.
I am a car guy and I have been driving since 62. The XR is the second most fun car I have ever owned (excluding the streetrod I built).
You have to decide which is more important, mileage of performance fun, then pick the Aura that fits that need best.
Good Luck
I am seeing about 27 or 28mpg with mixed driving about 60% "highway" and 40% city. No long road trips yet to see what I get for highway only. It did improve fuel economy wise as it broke in and the weather warmed up.
I am sure I could get slightly better if I could learn to keep off the gas, It is hard to not have a lead foot in this car it is so much fun to drive...
Aside from SUV-like MPG, occasional hum from the steering wheel pump (?) on tight turns, moon-roof rattles and an annoying Fuel Low message ... I love the car, first GM after owning two Mazdas and a Honda.
DISCLAIMER: I do not work for Saturn or any other car company, and I do not derive my income from the sale of automobiles.
- Think about that the next time you read a glowing car review posted just before the weekend.
