Chevy Venture Audio & Entertainment Systems
Can I listen to music in the front while the kids watch and listen to there video in the back?
Thanks!!!
Anyone have any idea as to what the problem may be?
Additional info:
I also have a 2002 Venture Warner Bros. Edition with a DVD player that does what the owner's manual indicated. I can connect devices to the inputs without any issues. Therefore, I went ahead and replaced the DVD player in the 05 Venture with the one from 02 Venture and it works. The problem DVD player from the 05 Venture does not work in the 02 Venture. (Yes, I am able to view DVD movies on both players without any issues in both vans.) Here's the real frustration, I also went ahead and sent in the problem DVD player to a repair shop in Massachusetts, they sent me a refurbished unit, and a new unit after that, and both did the same exact thing as the original that came out of the 05 Venture. Only the player from the 02 Venture seems to work as indicated in the owners manual and technical tech specs. Amazing! I am stumped!!!
The only difference between the 02 and 05 Ventures DVD players is the labeling in front of the players; the one from the 02 Venture has "PWR/AUX" label instead of "SOURCE" as labeled for the 05 Venture DVD players. What does this mean?
The possibilities are:
- install a DVD overhead player, and use the FM modulator to get the sound from DVD/MP3 to the current radio. I'm not sure the audio quality will be good.
- replace the radio with an audio player with aux input, and just use a portable DVD player as required. I'll probably need to use the AUX input to get the DVD audio to the speakers.
I have a bias towards the second option. Venture's door chimes and airbag logic is in its radio. So, I can't just replace the radio. I'll need to buy harness and some accessories worth $200, and leave the old radio connected and hidden under the seat. Apart from the additional expense, it seems like an untidy solution.
From what I've heard, it doesn't seem possible to just add an Aux input to the existing radio. (It won't improve the sound quality, but it can be good enough for movie audio.
Any advice? It seems to me that many people must be in this position.
Whichever way I go, my wife seems to think it's an old car, and is not worth spending much on. (I see a demand for a new car coming up :-) ). I don't believe the car is old - It drives well; and it seems like a waste to get rid of the car with only 65000 Kms on it.
- sandyr.
I also own a 2003 Venture; I replaced the radio with an after-market I bought at Target. It is a VRCD500SDU for $100 two years ago (installation kit from Best Buy) and it worked great. It has an auxiliary input, usb port, SD card port. Go to www.roadmasterusa.com/vr3_auto.html to read about the radio, as well as purchasing direct from the company. You can also call the company and talk to them about your concerns. I did not have any issues with door chimes or the airbag logic, or anything else. I connected a portable DVD player, sound output, to the auxiliary input of the radio, and the sound quality was fine. There are different setups as DVD players go, headrest mount is the way I went. Kids didn't have a problem with it.
You can also go to www.replacementradios.com and find other solutions. They sell interfaces that allow you to connect external devices to your existing OEM radio. Their phone number is posted on their website. I bought a radio and a XM tuner from them for my 2005 Venture and have not experienced any problems.
You can also try ebay motors, I've seen DVD Entertainment Systems from 03 Ventures being sold and/or auctioned off...If you go the ebay route you will probably need to have a professional installer do the work.
Well good luck, I hope this helps....
_gb5
It's reassuring to know someone has done it without any issues. You've inspired me to act.
- sandyr.
Again, good luck...
Here's what he said:
"I need an input to the, "Video In" jack on the factory-installed dvd player in my 2004 Chevrolet Venture mini van that will result in switching from playing disks to the auxiliary audio inputs.
I want to play my mp3 player thru the auxiliary audio inputs of the dvd player.
-- If I connect the, "Line Out" from my mp3 player to the audio phono input jacks on the dvd player and play the mp3 player, no sound sound is heard.
-- If I connect one end of a cable to the video phono input of the dvd player with the other end open, there is still no sound.
-- If I connect the video out from my camcorder to the the video in on the dvd player, there is still no sound.
-- If I now turn my camcorder on, there is still no sound.
-- If I now press, "Play" on my camcorder, the (mp3 player) sound plays just fine thru the vehicle's speakers."
If anyone knows a way to play audio only through the DVD player aux input, please do tell!
Very interesting, I'll try experimenting with that and get back to you with the results.
I thought I tried that before with connecting an Atari video game unit and didn't get video or audio; but I'll try with my video camera and duplicate what that guy encountered.
Crazy, huh?
Thanks again....
We purchased a used 2002 Chevy Venture WB Edition. While testing the features we noticed an issue with the DVD. We can hear sound, but there's no picture. Does anyone have any tips on troubleshooting this? Is there a trick to gettting the picture to appear. The owner's manual doesn't say. Also, ours did not come with the wireless remote and headphones. Does anyone know a good place to purchase these besides the dealer? We appreciate any advice. Thanks.
I recently had Best Buy put in a pioneer stereo with MP3, and remove the factory stereo. They informed me I'd lose the DVD. My kids are older so it didn't matter.
The stereo, (plus $200 in harness and accessories) went in fine.
My problem is this. I have an overhead console for the rear passengers to plug headphones into, and most importantly control their AC/Heat/Fan. This console no longer works. Unless someone here knows how to make it work, I have no option but to have the stereo removed.
Does anyone know anything about this? GM dealership is useless, and Best Buy doesn't know.
Thanks everyone!
thanks.
Take it to your local car audio shop to debug. The dealership won't know what they are looking at.
G
Thanks in advance!
There are a series of rollers and capstans (pins) that need cleaning. Generally a little isopropyl on a clean swab is enough, but sometimes you need to take some 'rubber renew' (dimethyl benzine and methyl salicylate) to resore the 'grip' of the rubber rollers. You may have to remove the deck. If thourough cleaning and renewing doesn't solve your problem, then it's not worth going further I'm afraid.
Use isopropy on all the rollers, and pins. Use rubber renew on the rubber rollers only.
I just bought an 03' and I get the "Disabled" message. Have you had a chance to take it in?
...So we just went and bought a portable dvd player for the kids. GB
