Chevrolet Cavalier Starting/Stalling Problems
Please help. I have a 2004 cavalier and when I am stopped at a stop sign the car acts like it wants to die, I have to put it in park and push in on the gas so it dosen't die. I changed out the fuel filter and air filter. anyone have any ideas on what it can be? I am would like to fix it myself, but I am new to all of this.
See also: (Video, 14:58) How to test & troubleshoot starter problems
What happens, is when the key is put in the ignition and I go to start the car, it clicks but that's it. I do that twice, and the third time it starts.
I'm thinking it might be the ignition switch. The starter was replaced with a brand new AC Delco one a little over 2 years ago, and as far as I know, it came with a new solenoid tube.
So, if it's not the ignition switch, then I am at a loss.
Also, on a slightly different note, does anyone know of a store or a warehouse or website where we can purchase these "discontinued" parts so we can stop getting pillaged by the dealerships selling the parts from their vintage line? We just bought new weather stripping for the front windows of the car and they were "discontinued" so we had to pay $75 for 2 pieces of rubber.
but it starts great,new fuel filter, platium plugs 10,000 miles old, hook it up to a machine and is said air fuel mixture is at 14.6 when at idull, but get on the gas it's drop to 12.2. When under a load it's try to die,backfires, stalls. Ican slowly give it gas it's okay up to a
certain spot then stall time. Thanks
I don't think the second is related to it but I have no idea what it could be. Are you saying it shuts off as you're driving down the road or sitting at idle?
Does it run rough and seem to have a loss of power?
After I located a reasonable fuel pump/sending unit. (had a little confusion regarding the colored plugs that were put on the lines after manufactured-once I figured out they could be removed) I installed the tank unit assembly and the fuel filter. Did the turn on test-Listened for the 'wheering' pump noise, checked for leaks. Car ran fine for almost a full tank. But I pulled off the freeway today made a left turn and it stalled out again. At exactly 300 miles and 1/4 tank of fuel. I still have the same problem evidently.
I think I will check the fuel supply pressure next which may reveal either the pump will not run off the low fuel pressure signal that the fuel pressure regulator should be sending or something else.
I found a good price for the fuel pump at http://myworld.ebay.com/ebaymotors/alanisdeals/
I wish I would have replaced the harness while I was replacing the pump also.
Catalytic convertor replaced the mass air (MAP) replaced (and oil sending unit for oil leak) ONE of the repair places writes on bill in ( ) Aternator v or a running low. (I dont think this is the problem)
Cranks fine but will not fire till let set. Runs fine when running. Then after so many miles just dies out.
Parked it just before it cut out , popped open hood and just listened to it slowly die out.
Have forced the issue with it by stomping on the gas just before it died out when parked and there was some coughing / sputtering noises. ( one time the catylytic convertor turned super red glowing , then replaced)
In checking the vin with dealer found all the possible maker defects for repair or recalls were done by previous owner,
Help?????
The debris would build up as I drove to the point where hardly any fuel could get through. After it stalled and sat everything would settle back down and I could drive it again.
Not sure if this is the problem with your Cavalier but it might be worth a look.
Recently, however, I was driving to work along a two lane highway (about 100km/h...(55mph?)) and it started doing the hesitation thing again...this time it was very pronounced, even bucking occassionally. I got to work and when I went out to my car after work and started it (cold engine), the tachometer was going up and down like crazy and when I started to drive it was hesitating and bucking again. So I took it to a garage when I got home and they checked it out. They told me that when they test drove it, they couldn't find anything wrong but it "has a history code for random misfire and front O2 sensor. Spark plugs look good". They replaced the fuel filter which was very "gunky" (their word, not mine...) and added gas line antifreeze. Of course, driving home from the garage my car acted up for me...just slight hesitation and very intermittent.
Soooo, wondering if this could be a problem with the O2 sensor after all? I've read that they can malfunction in such a way that they do function intermittently and don't cause any engine codes. And by the way, no warning lights ever came on at any time during these problems...no check engine light or any such thing. Thanks for your input! Cheers!
The first thing to go wrong was my timing chain... ya thats right, no lying... about 1 year after I had the car. Then the stalling began. This car has been nothing but a never ending hospital stay. Its like caring for a sick relative :sick:
I do believe the 2005 cavalier is officially a :lemon:
Please let me know i you have any other ideas... this seems to be a common problem with this model
Let it sit a few minutes and would fire back up and run poorly for maybe 10 minutes and die again..
Does yours have a ignition coil pack assy ? If so the coils will be mounted on a metal plate which is actually a module plate for the coils to fire. I would check here first if you are losing spark. Have your mechanic check it or Try to find a used coil pack assy to test it with
Good Luck..
Don
The fuel tank was changed a month ago, the fuel filter soon afterwards. From the idle, I think all sparkplugs are firing. I've been told everything from perhaps the fuel filter became wrecked from the possible water, I need to change the coil pack, Catalytic converter, put it on a scanner, to draining the tank and refilling with new gas, and a host of other ideas.
I'm hoping someone here can help me, or eliminate more of what it isn't. Oil levels are fine and I checked all of the fluids the day before.
I took the car to my mechanic hooked it up to the diagnostic machine and zero codes came up, He drove it all day (highway)ect and it didn’t die. Today the car did the same thing; He thinks it could be the fuel pump. Any suggestions??
Thank you,
Kerri
It is caused by not replacing the transmission fluid every 30K, it gums up the valves.
Thank you again!
Kerri
If someone knows why this happens i would really appreciate a heads up before i dump a load of cash into it trying to find the problem!! I cant put 2 kids in a car that decides it wants to stop going 60 on the highway!!
A friend who had a similar car had the same problem: ran fine then lost power and eventually couldn't keep running. He took a jack bad and knocked the base of the fuel tank a bit (7 times were the fuel pump would be) and it started fine and ran fine.
Does the fuel pump make more noise than it used to? If it does, and what I described above fixes it, then it is the fuel pump, and it should be changed as soon as possible. The intake filter itself sounds like it may be clogged. Even when driving, a sudden jolt might shake some of the gunk loose, but it will be sucked back up and kill the engine, which it sounds like what is happening to you.
If not the fuel pump, then sorry, no clue.
i have an 04 manual cavalier that stalls out in low speeds only if my AC is on. If the AC is off, i'm fine even though it appears the engine revs a bit on it's own.... but if the AC is on, i have to keep giving it gas to prevent it from stalling out.
The first time it happened was about a year ago, in rush hour traffic, then didn't do it again for about 3 months. happened again twice in a week then nothing for about a month, now it's consistent; AC on = car stalling out.
I got a diagnostics check that came back saying I have a fuel pressure regulator leak and a recommendation of cleaning my fuel injectors. I replaced the pressure regulator, ran with AC on for about 3 minutes, then stalled out.
I'm going friggen NUTS over here!!!!!!!
How about the plug wires? Heat increases the resistance and the problem will be magnified with plug wires that are going bad. The fact that it acts up in warmer weather or after the engine has warmed up has me focused on this possible cause.
The only way I've keeping it running is to shift to neutral or park. I'm beginning to think this problem is transmission related because I went through a similar issue with another 94 Cavalier I had and it turned out to be the shift solenoid on the side of the transmission. I had no more problems with that car when I replaced the solenoid. The problem could also be fuel pressure related. Any suggestions would be helpful as this problem is getting annoying. Thank you. :confuse: :sick:
