Dodge Ram Seats and Interior Issues
I have an 06 big horn addition that I just added factory leather/power/heated seats, and the dealer installed them. I have a constant problem with both seats over heating on high after only 15 minutes. They shift to low setting for a few minutes, then turn off by themselves. The dealer can find no explanation for this and has been there a few times. This is very annoying because I don't want to take it just anywhere and void other parts of the truck warranty. I have a full service manual but we (myself seeming to know much more then the dealer) followed it to a tee. Does anyone have enough experience here to help out? I have alot of details if I can spark an interest in a guru. Any help would be greatly appreciated.
So assuming that it isn't supposed to be reset every fifteen minutes, the next step is to check out the control systems. Following that, is the current draw exceeding the manufacturers spec? If so, the heating element is faulty.
Finally, and I'm sure you must have considered this, optional factory seats installed by an authorized dealer must surely be under warranty? If the seats aren't performing to spec the fix is the responsibility of the dealer and supplier. It shouldn't be your problem.
However, looking back over your post " I purchased the seats a few months after buying the truck........... I purchased the switch/modules through Chrysler" it may well be that the seat heating elements and the control system are incompatible. Sometimes even seats within the same model line can be controlled in different ways.
Did the seats come with the heaters already installed, and did you buy them through your dealer? Are they a seat that DC uses in another model?
That will have the effect of lowering the resistance of the circuit and, if the control module is using a resistance measurement to control the seats, will allow the seats to remain on longer (in theory ).
steve
2001 Ram2500 4X4 Reg cab
Try removing the current overhead console and see if there's a wiring harness there. Let us know what you find.
Dusty
James
chek out this link and you may find an answer for your question.
http://www.barbari.com/car-seat-covers/leather-seat-covers.html
they sell leather, fabric and easyfit seat covers with very reasonable prices.
i just bought my self 2 pairs of leather seat covers for my ride and with no over heating issues.
I have found a few areas that Dodge can/should improve on. Lets hope the 2009 model is better all around,. Looks like it from what I have seen.
Ski in TX
p.s. NOW is the time to buy a new RAM if you need a truck. Due to high gas prices, they are almost giving them away now. At my local dealer they have a super price, they give you a 50" big screen TV AND the $2.99 gas deal for 3 years!! Not including the lifetime power-train warrantee.
Prices have come down considerably since I bought mine last October 2007 and I thought I got a good deal. ;(
Ski in TX
But, I talked to an upholstery man today who says it's easy to fix, you just need the foam cushion (factory/dealer part). The upholstery is easily removed as it's attached with plastic hooks on the bottom of the seat. When replacing the custom molded foam, place a piece of leather or vinyl over the 2 bars the foam rests on. This will prevent the metal from gnawing at the foam. Place the foam and recover the seat and hook at the bottom. Wa-La, but it may happen again as the replacement foam isn't any better than the scrap you just replaced.
I wish I could find a place that sold the fitted foam as an after market part, but I've scoured the internet and can't find one....Happy Hunting...
Has anybody found a suitable way to fix these cup holders and make them usable?
By the way, you lhave the Quad Cab, which is the same size class as other brands' extended cabs - Dodge simply chose to use normal rear doors instead of the rearward-opening "suicide doors". The actual Crew Cab was just recently introduced with the new body (2009 for the 1500, 2010 for the 2500/3500).
kcram - Pickups/Wagons Host
