2007 Tahoe/Yukon Maintenance Manual
rshtrsht Member Posts: 277
edited March 2014 in Chevrolet
Does anyone know of any Service Manual currently available on the market, specifically for the 6.2L V-8? Basically, I want to confirm the torque spec for the engine oil drain plug (18ft/lbs or 15ft/lbs), and if the drain plug gasket is re-usable ?
  • rshtrsht Member Posts: 277
    I just ordered a set of 3 Volume Service Manuals from HELM
    http://www.helminc.com
    Unfortunately, its not 6.2L V-8 only, but also covers the 5.3L, and etc for all 2007 Yukon, Denali, Tahoe, Escalate... If anything specific you are looking for, I will be happy to look it up for you before you spend the money. The set that I got is with a lot of information. I also wish they have one specific to 6.2L only as that is all I care and need.
  • brewboybrewboy Member Posts: 36
    Does anyone know if you can add the heated steering wheel option easily or not? All 07 Denali's have the deluxe steering wheel so it will except that option but I wasnt sure if its easy to retrofit.
