And like like someone said you hit cancel it will take you to the previous screen.
Happy holidays
Lou
the 08 previous destinations are listed as a DATE ( for what good this does is totaly beyond me ) As a realtor i used previous destinations to show properties. I called Acura tech and the dealerships. They have no idea why it shows a date rather than an address ( in fact sometimes its an address sometimes a date with numbers after it. - seemingly indicating how many previous destinations on that date ? Once you choose a date as a previous destination it then asks you an inane question which Acura doesn't know what that means " do you want to replace ".
They are working on it but i dont have much hope. Seems the function of previous destination doesn't have much purpose in the new version. Hopefully there is some work around for this. Or a trick to getting the previous destinations to be addresses in the list rather than the date.
any thoughts ??
YMMV
The DVD is located under the front passenger seat and is accessed from the front of the seat. A door drops down and the DVD can be ejected and inserted.
Alpine Electronics supplies the MDX NAV and the map disks. I purchased and installed an updated version from them for $99. Be sure that you know the NAV "pin number" before you try and change the disk. It will ask you for it once you insert a new map disk.
Does anyone know how to get to the "edit" screen to delete a stored adress in the address book in a 2008 MDX?
1. Systems with the Nav system have worse residual value than the base model, which indicates that even the banks/manufacturer know that the technology will be obsolete long before the car is.
2. Lack of traffic re-routing. A traffic system is great, but it's only really useful if it will automatically re-calculate your route based on traffic conditions. Letting you see icons on the screen and colored lines for traffic density is of rather limited use to me. I'd rather get a traffic alert and a choice to automatically re-route me around the problem.
After test driving the MDX several times it became apparent to me that the $600 upper end Garmin I had was better than what came in the MDX, and could be swapped out again at a later date for much less than the $3000 the Acura technology option cost. Possibly if the Acura Tech Package included other features like keyless ignition, etc, I might have opted for it.
Thanks. :confuse:
There! I feel better. Glad you guys enjoy yours.
P.S. The screen also washes out completely if the sun is out. Only visible in the dark.
Other than this minor problem, the MDX is perfect!
To edit or delete an address, you have to hit the "setup" button, then go to "personal information", then click on "address" and it will bring up the edit screen. Why would it have been so difficult to put that in the manual? :mad:
Toyota gives the next three exit numbers by distance, and if there is a rest stop. That is really nice.
Maybe I just have not found out what to do to get detail.
The navigation units are not too hard to replace - they sit under the passenger seat. You could save labor costs by switching them out yourself. There is as security code "pin" number that needs to be input once the new unit is installed. [A new replacement for the 2004 lists for $3240., dealer cost is $2592] So if it really is broken, the quote from the dealer is fairly accurate.
1. Assume you have a bluetooth phone that does NOT allow the phonebook transfer.
2. Borrow a phone that is approved for phonebook transfer, insert your sim and transfer your phonebook to the vehicle.
3. Remove your sim and place it back in your own phone. You must leave the bluetooth profile for the phone you used, in the vehicle. In other words, do not selete the phone you used to insert the phonebook.
4. Access the phonebook and dial a number using your non-compatible bluetooth phone.
My local Radio Shack will let me use one of their phones for a few minutes to do this, but I would like to know if anyone has tried it.
H. Nikdel
However, I decided to send my husband over to talk with them. They investigated my maintenance record and decided to replace the unit. This all happened around November of 2007.
This is not quite the happy ending you think it is. I just started encountering the same problem last week.
When it breaks this time, I will replace it with a portable unit.
What am I missing?? About the conversation about a fuse missing, could that be my case??
I hope you can help me. Thanks.
Just got new 08 MDX
https://store.alpine-usa.com/Acuradvdsales/naviorder.php
order form
The only feature my Garmin model doesn't have that the MDX has is voice recognition, but so far I the MDX hasn't demonstrated that it does a very good job of recognizing voices either!
If Acura (and other car makers who are trying to reinvent the wheel), would wake up, I think they would realize they could offer a much better, user friendly GPS system to their customers if they would enter partnerships with these companies like Garmin who really do this for a living.
Overall we are liking the MDX, but this GPS system is very disappointing, esp. when Acura promotes themselves as a luxury line.
What i did, i installed map dvd first, and what i suposed to do is to install set up first. Now i got the message. Invalid dvd when i put set up dvd first. Tried to unplug the battery, and still comes that message. It will not recognize my 2005 dvd too. When i put 2009 dvd it will recognize, but will display old 2005 map. Does somebody knows how to fix it.
The Nuvi 760 has a FM transmitter, MP3 Player, Bluetooth, so you can wirelessly play all you music loaded on the MP3 player over your stereo and when someone calls in, their voice will come through your audio speakers. The features of the Bluetooth blows away what the Acura's offers. Phone book, call history, etc.
Good Luck.
How well does Acura handle technical support to their 2009 MDX navigation system?
How are GPS updates handled ?
Is their truth to rumor that several other 2010 Acura vehicles have updated GPS systems and thus MDX make get a upgrade??
I am able to receive incoming calls thru blue tooth but not able to make outgoing calls.
The 2010 MDX will likely have the scenic routing feature where you can choose a more scenic route.
so with inventory running out of the MDX and a really good deal that I was able to get I went with the 2009. I didnt lease it but might be worse that I bought because I will automatically lose money after I drove it off the lot plus already put 400 miles on it.
oh well, I guess I would be able to get decent money back for it from the same dealer if i really want the 2010? how much can they really take off if i just have it for like a month till the 2010 comes out and put a few miles on it. I guess a lot, ugh, enough to not make it worth doing.
I used to have a portable xm player that worked in the car, on the go and in the house all on one device and paying one xm account. otherwise you ahve to pay for your xm/sirius and then for another unit in your house or portable.
The best feature of it was that it coudl record xm radio so if you heard a song you liked you could record it to its storage and listen to later like when you have no xm signal or going througha car wash or tunnel or something.
someone told me that bmw had that ability with their integrated sat radio that you could record the song to a built in hard drive.
you didn't mention this with the 2010 mdx but just the fact alone that it has a Hard drive makes me want to have waited. although iw ould want to store mp3s not just rip cds. i imagine you put the audio cd in the 6 disc in dash cd changer and then an option to pull the tracks off the cd to store to the built in hdd so you dont need to have that cd in anymore to listen to it so you could essentially have 6 cds in and then many others stored to the hdd? that isn't bad but yeah i'd want mp3 storage and playback like a lot of the aftermarket Pioneer units use and i understand that the 2009 mdx is a pioneer unit.
maybe the 2009 can be upgraded with the 2010 unit or other aftermarket Pioneer nav and audio all in one units with hdd and still work with the integrated mdx controls?
the higher resolution sounds great especially for when you watch a movie on the front screen which I am still trying to figure out how to do on the 2009 mdx which i could do on my previous 2006 suv.
Also if the 2010 front nav screen is 8" what is the 2009? it does seem smaller even then TL's prior to 2009 even, like my wifes 2006 TL seems ot have a bigger NAV screen plus its closer to you in the dash not set back which makes the mdx's seem even smaller.
40gb hdd isn't bad but only 12gb for music?
it doesn't sound amazing, but def a little bit of an upgrade from the 09. Again I hope there is a way to pu tthe 2010 nav audio unit in a 2009 or better yet an aftermarket Pioneer unit that is even better then what they are putting in the 2010 with other features and larger hdd but still somehow work with the 09's controls. i guess that is asking too much.
all i know is a few friends of mine have Pioneer aftermarket all in one head units with huge screens and hard drives and it can store music and movie/video files for play back on the screen also so if i can get something like that installed into the 09 mdx that would be great but i know certain dash's just dont lend themself to an aftermarket nav audio all in on head unit and i'm thinking the 09 mdx kind of doesnt'.
i kind of just wanted to believe it wasn't adding anything and was afraid it was just getting the ugly Plenium grill so took my chances and got an 09 before they ran out since there are hardly any left instead of risking waiting for the 2010 mdx only to find i didn't like it and could get the 09 i like better for less but then find there are none left in the color and packages i wanted.
but now i realized I didn't think about the interior upgrades and didn't hear anything about it till now.
I will just have to check it out when it comes out and if I really really like it better then the 09 will just have to hope the dealer buys it back from me for a good price based on what i bought it for and gives me a similiarly good price on the 2010 but somehow i think that woulnd't work out so well I would lose more money then it would be even be worth changing to the 2010 ultimately just for a larger nav screen and possibly uglier grill.
