Has anyone tried the new Rain-X wiper blades?
They're supposed to be superior to anything that's on the market (as they should be, they're much more expensive than anything else on the market). Does anyone have them? If so, are they worth the price?
I liked what Rain-X did, even though I had to take the time to apply it. But the washer fluid gives me pretty much the same results, and the reduction in the amount of washer fluid I'm using as a result offsets the higher cost of the Rain-X juice compared to the run of the mill blue stuff.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I'm pretty sure my wiper life has extended somewhat too because I use them less during those times when it's just spitting rain and it rolls off.
I've never tried their anti-fog stuff for the inside of the windows.
Hm... wonder what happens if you mix the winter formula with the summer formula? Frost-free, non-adhesive bugs?
(sorry bottgers... this really isn't helping you)
I've tried multiple products, and the one that seems to last from October through June, our rainy season, is Aqua-Pel. Once applied, I don't even use the wipers at night, as it makes no difference in visibility. During the day, I can leave the wipers on intermittent, irregardless of how hard it's raining.
Out of all the products I've tried, this one's by far the best and longest-lasting. You can search for it with your favorite search engine.
I use the Trico Innovision blades (got mine at Meijer), and they are incredible. They have a funky design where only the middle of the blade has support, but this works out well because the rest of the blade "snaps" along the windshield. Best blades I've ever used.
Odie
Odie's Carspace
What was on left the shelf was all that they had.
We ended up getting Anco wiper arm/blade combo. Not bad. Anco has been around since I was a kid(don't ask how long that is,lol).
Tried some weird (from Wal-Mart) Triple Edge wipers once, 5-6 years ago, did not work well, took them back.
Hey, those Meijer's wipers sound intriguing!
take care/not offense
Click here
Looking at the new Rain X blades, they appear to have the same idea, slightly different design.
I bought the Tricos last spring, so honestly I don't remember what I paid. They weren't cheap, though they still work like new. The only time I've ever had them streak is when my car had been sitting out in freezing rain, and they were coated in ice.
I can't recommend them highly enough, though I'd give the Rain X ones a try if I couldn't find the Tricos. They LOOK pretty similar.
Had one of those semi-annoying rains this afternoon and the Rain-X washer fluid did its job. Really only had to turn on wipers if we were behind a vehicle going through a low lying area with standing water throwing up that nasty, grimy spray.
That's what I've found,and what really cuts down on not only wiper use, but washer fluid use as well. Changing blades seems to be more of a function of age of the blades rather than how much they've been used. After a certain amount of time, they just need to be changed. Next set of blades I put ona vehicle, I'm going to start keeping a log
My kid bought some of the somewhat similar (but cheaper) innovision blades, but these seemed kind of flimsy compared to the Icons. We will see how they hold up, have only had them for 6 months or so. Also they do not have the "spoiler" like Icons (and RainX apparently) so may not work as well at higher speeds.
These Icon blades just work so much better all year around, I'll gladly pay the $30-40 cost for a set of them. Discovered these in 2005 because my wife's new Jetta came with them. After having them on that car for about a year, I decided to upgrade our old Windstar to them. Now I have a new Mazda and before next winter, I will definitely switch the crappy conventional blades for a set of Icons (or perhaps I'll try this new rainx version.
We are approaching two years with the Icons on the Jetta and they still seem to be working good. They had begun to show signs of wearing out after about 20 months (including two full winter seasons) and then I cleaned them with vinegar and my wife said they were working good again.
I use winter-formula washer fluid all year long, as it doesn't seem like I go through enough of it to switch back and forth between summer and winter.
I have mixed feelings about Rain-X on the windshield--I don't use it currently.
Are you sure you're applying it correctly? I've used Rain-X for decades and have never experienced any such distortion.
Once a month is more than sufficient for me and I do a couple of thousand miles per month.
I commute 25 miles of I-5 each way, and I've been delighted with this product. In fact, I had a "greasy" windshield from Rain-X, and was dis-satisfied with it.
With Aqua-pel, you DO have to clean the windshield so it's like new. I always apply in 4 different directions, then wipe with a paper towel after about 10 minutes. At night, I see no improvement with the wipers on vs off.
I probably would have thought that way too, until I saw just how much better the Icons are compared to my previous wiper blades of choice...which were Bosch microedge. The extra $15-20 is well worth it to me...especially since these have worked well (winter and summer) for far longer than other blades.
I'd use SilBlades in summer too if only they came in a 21" size I need. I can forgive the missing inch in winter, though.
I tried Triple Edge blades many years ago. I threw them away. As far as I could tell, they last forever because they're too hard & stiff to actually follow glass closely enough to wipe water away. Perhaps I should have given them more time to break in, but I didn't want to wait. (To be fair, I know someone who had the same reaction to summer SilBlades).
I saw the Bosch Icon blades, but they don't come in the 16" length I need for my rear window. I see that SilBlade now has a similar "one-piece frame" blade, but they don't come in the 21" length I need for the driver's side. (This is getting frustrating...) The Rain-X Latitude blades come in all three sizes I need, and as soon as I find a store with all three in stock, I'll buy them. I'll gladly pay more to see better.
I also put Rain-X on all my car windows and outside mirrors, and enjoyed the results enough that I'm really kicking myself for not having found time to do it again. Maybe this weekend.
I think I'll get Diamon-Fusion or Nanoprotect AG for my next new car...
Rocky
Rocky
Come in a snazzy yellar box with neat graphics and
a $18 bucks EACH pricetag !!!!!!!!!
Must be that quality made in mexico difference !
Rocky
on sale when I need them. I use 2 sets. The regular
ones for summer and the winter ones that are fully
encased in rubber for snow and ice season...........
Been wanting to try the heated ones on my plow truck
for winter use but the $75 bucks is steep !!!!
The only thing I will say is they are not as aerodynamic as I thought. Under some windy conditions when driving over 65, the right one skips slightly.
I think they look cool, too. Tried the one piece from anco for the other car and they are not as good, and took them back and got more of the Rain X.
Bosch Icons have won me over. Discovered them when they came on my wife's new Jetta. The Rainx ones look so similar that I will consider them in the future too. I even wonder if they are made for them by Bosch, because of the lookalikeness.
Rocky
my GM bud Rock........
Just commenting with my reasons on why so costly at $18 bucks each.........
Too bad you read it that way.........
snowplow sites. All the hanging/exposed wiring scares me
as not to last too long during heavy snow events, scraping
and brushing around them or how those dangling wires
would hold up after HOURS of usage during plowing !
Heck..The "winter" style blades are bad enough! They have
ruined the windsheild on my 04! You can see the wiper
pattern "burned" into the windsheild..........
Oh well should have my new 07 in a week or so.
No V-max package on the 3/4 tho.!
But that 6.0 should have enough GRUNT to drag a blundra
around........LOL! :P
