Ford Explorer Rust
I bought my '03 Explorer about a year and a half ago. I am noticing some rust on the hatch and around the inside of the sunroof. I hate rust enough that if this isn't something that can be fixed, either on my own, or somewhere else, I may consider trading it in. I just don't know if I am making a big deal outa this. I had a '94 ranger before this, There was no rust on that, so I am concerned.
Thank You
Corrosion Coverage
Under your New Vehicle Limited Warranty, Corrosion Coverage begins at the
warranty start date and covers body sheet metal panels against corrosion
due to a defect in factory-supplied materials or workmanship. Corrosion
coverage (which lasts for 5 years, regardless of miles driven) only applies if
the corrosion causes perforation (holes) in body sheet metal panels.
If corrosion does not cause perforation (holes), and is not the result of
usage and/or environmental conditions, paint damage is covered under
the terms of the Bumper to Bumper Warranty (3 years or 36,000 miles,
whichever occurs first).
link title
http://www.motorcraftservice.com/pubs/content/~WO3EXP/~MUS~LEN/41/03frdwa5e.pdf
<a href="http://www.motorcraftservice.com/pubs/content/~WO3EXP/~MUS~LEN/41/03frdwa5e.pdf
has anyone gone ahead and had this fixed then sued the dealer in small claims court ?
2003 white explorer
susi
los angeles suburb, CA :sick: :lemon:
by the way: other things that have gone wrong, back up sensor works only intermittantly,
electronics cluster in the dash has had to be replaced.
gas tank sensor works intermittantly
bulb goes out in the directional frequently (part of some larger electronics issue)
basically i dont think i'd ever buy another ford..
HAS ANYONE ELSE EXPERIENCED PAINT FLAKING ON 04 EXPLORERS ?
Did you buy it "as is" or was there any warranty period?
If you only bought it a few months ago, I would send a registered letter to the dealership stating the problem, insert pictures into the letter, and ask them for a refund. It sounds like the rust has ruined the integrity of a car thats not very old. I would copy your attorney and be sure to show that CC on the bottom. Or - better yet - have your atty send the letter on your behalf, people resond immediately to a letter from an atty, and it might only cost you $50 to have it sent.
If they wont offer you a refund or excellent repair, file against them in small claims court right away (if the amount you are seeing is allowable by your courts) or you might lose your window of oppty. Good luck.
dealer no help, FORD should stand up and admit the problem as GM did in the 70s with hoods
and trunks on intermediate sedans and coupes, driving for 52 years,many new cars,once they start to rust you cannot stop it !!!!!!!!!!!!!!!!!!!
