Dodge Dakota throttle position sensor
Can anyone tell me where it's located and how to change the tps on an 02 Quad Cab?
Dusty
The intake for the Throttle Body faces forward (front of vehicle).
INSTALLATION
1. Switch the engine off and remove the ignition key.
2. Remove the the air duct from the the front of the Throttle Body.
3. Locate the Throttle Position Sensor (TPS) on the left (drivers) side of the Throttle Body. The TPS will have a 3-wire connector and is in plane with the throttle valve shaft. The TPS is secured by two Torx screws and is located just above the Idle Air Control Motor which has a 4-wire connector.
4. Ensure that the throttle plate is completely closed.
5. Remove the connector from the TPS.
6. Remove the two (2) Torx screws that mount the TPS to the Throttle Body.
6. Grasp the TPS and remove by pulling the sensor directly away from the Throttle Body.
INSTALLTION
1. Note the position of the two triangle-shaped tangs that are visible from the end of the TPS.
2. Insert the new TPS in to the cavity that contains the end of the throttle plate shaft. The TPS should seat without significant resistance.
3. Rotate the throttle plate shaft by moving the throttle cable lever. Note the amount of throttle plate opening. The throttle plate should be able to open without undue force to the wide open position.
4. If the throttle cannot be opened fully, remove the TPS and ensure that the tangs are correctly engaging the end of the throttle plate shaft.
5. Reinstall the two mounting screws and the 3-wire connector.
6. Proper operation may be checked before reinstalling the air duct.
Dusty
Thanks again for your input!!
By the way, do you have any codes? Do you know how to retrieve the codes from the instrument panel?
I think you said this was a '02. I'd start looking for more cracked vacuum hose, especially the evaporative collection system.
Best regards,
Dusty
I'm NO mechanic at all.....I will search for more cracked hoses but I dont know where the evaporative collection system is you refer to.
You're a great help.....good to know there are people like you out there willing to help others out.
Trij1
Dusty
I am thinking the throttle body sensor is either bad or needs adjustments. Please assist if you can.
Thank you,
JC
There are a number of things that could cause this problem. I recommend performing some relatively simple checks:
*PCV valve - A sticking PCV will cause this problem, and will be especially noticeable in colder weather. If the PCV valve plunger sticks in the closed position, the manifold air flow is effectively reduced. This has the same effect as closing the throttle plate, hence, the engine essentially stalls. In colder weather moisture build up in the motor oil will gravitate to the PCV. In freezing temperatures the moisture around the PCV valve plunger solidifies and cuts off air flow. Look for any signs of moisture in the oil and change it out if necessary.
On a vehicle that old and mileage, I would also suggest checking the vacuum hose that goes to the PCV valve. I've seen these get gummed up to the point they no longer flow much vacuum.
*Vacuum hoses - Vehicles of this age typically by now have dry, brittle, and cracked vacuum hoses and causing leaks. This may not show up much at higher RPMS or road speeds...although it usually causes slight hesitation or surging...but will definitely cause idling problems.
*Sticking Idle Speed Motor - On Throttlebody equiped vehicles, the idle speed is regulated by the Powertrain Control Module (PCM) based on various inputs (sensors) in the system. The PCM then modulates the Idle Speed Motor to open a plunger-type valve that allows more or less air into the manifold to adjust the idle speed. This area is prone to carbon and gum deposits, especially with cheaper fuels. The Idle Speed Motor should be checked and cleaned, especially if you've never done is on this truck before. The Idle Speed Motor is easily removed on Dodge truck motors.
*Throttle Position Sensor (TPS) - This is essentially a non-linear potentiometer and can cause idling problems if the voltage is interupted across the terminals. This is caused by a corroded or dirty contact in the sensor. You can check this with a volt-ohm meter, preferably an analog type, by measuring DC resistance across the tap (slider) contact and rotating the TPS shaft. Erratic meter movement indicates a dirty or scratchy resistor. However, because of the miles, I would just change it.
*General engine tune - Of course, things like worn spark plugs, old spark plug wires, carbon tracked distributor cap and rotor, clogged air filter, will have a deleterious effect on engine performance and idle quality that may not have been noticeable in the warmer weather.
Best regards,
Dusty
Take care.
Use care when reinstalling the TPS. It is possible to get the TPS engagement socket 180 degrees out.
Best regards,
Dusty
Are you in a winter environment? Can you retrieve a trouble code?
Dusty
Dusty
How many miles on the vehicle?
When was the last tune-up performed (miles)?
Dusty
You can make a cursory check of the Idle Speed Motor by placing the Mode Control knob (Heater/Air Conditioning Control) in the defrost mode. Your should hear the Air Compressor Clutch engage and the idle speed should come up at least 50 RPM (50-125 RPM is spec.).
I would recommend checking the connections at the Idle Speed Motor and Throttle Position Sensor connectors for loose pins or signs of corrosion. Since throttle position sensors are a common failure item, you could replace it as a shotgun approach.
Check for the presence of excessive oil sludge in the fill tube under the engine oil cap. Remove the moisture diverter by grasping the end and pulling straight upwards. You will or should see the opening on the right (passenger) side of the oil fill tube for the PCV valve. If this is clogged, it could cause the engine to idle too low. In cold weather this can be especially acute. The PCV valve could also be clogged from the gooey sludge freezing overnight, then after it warms the engine may idle fine after that.
Check the various vacuum lines for splits or cracks. This can cause a loss of idle control.
The Engine Coolant Temperature or Manifold Absolute Pressure sensors could be defective.
Best regards,
Dusty
When the heater control is placed into a defrost mode, a signal is sent to the PCM which causes the Idle Speed Motor to advance slightly. This is to compensate for an idle speed drop caused by the increased load of the air compressor.
If it idles fine in the defrost mode, you either have a defective Idle Speed Motor, or a PCM problem. It's possible the PCM might need a reset, although I think its more doubtful in this case.
By connecting a DRB3 scan tool to this truck, a Dodge tech. can get a better idea of what's going on.
Dusty
My son couldn't make payments on his 1998 4x4 Dakota SLT with a 3.9 and auto and 104,000 miles, so I took it over figuring it would be good to move our boat from the shed to the ramp at Raystown Lake in PA (less than a mile). The issue he passed on to me though is a throttle issue. The throttle responds as it is supposed to when the truck is first started and until it warms up, then if you step on the pedal while in park or nutural the idle will roar to about 2800 rpm and very slowly back off to about 750 give or take. When I say "slowly falls" it might take 8 -10 seconds to fall back down to 750. In gear this is not evident if it's happening, but I have to think it could so I'm concerned...a lot.
I've replaced the TPS since it seemed one of the cheapest fixes and the root of much discussion for idle problems. I think I did a pretty good job checking all the vacuum hoses; and they look good although I'm tempted to replace them just to be sure. I cleaned up the IAC and it's seat/port in the TB, and it tested ok using a 9v battery, but it might be sticking and it's the original, so I'm thinking it's another cheap replaceable item that probably will need replaced soon if it's not the root to the current issue thinking of the vehicle age and mileage.
The dealer where he bought it was closed by Dodge in the sweep of taking away small town dealers this year, and I'm not real happy with the alternatives that charge 30% more just to component change and they really don't care what your name is as long as the money is green, so it hasn't been to a dealer shop for their opinion. Our local shop says it might be one of these sensors but without leaving it with him he can only guess (he is mostly GM by training).
I'm not dumb under a hood or at least in the old days I wasn't
Thanks for your help!
Wvbigdog
When I take off again the vehicle is fine and runs all day long at any speed with normal acceleration and idle;once the truck sits all night it is the same problem the following morning unless the temps are above 32.
I changed out the coolant temp sensor and have had a tune up within the last year with new plug wires installed.All other sensors on the car are original parts.
Any suggestions? I would appreciate your insights..thanks ! Mark
