2002 Pathfinder blower motor resistor broke
My fan would not turn off...it constanty blows in high mode. I know it is the resistor for the blower motor but I cannot find it! It is kind of embarassing considering that about 5 years ago I worked in a Nissan Dealership as a service tech...I just never performed this maintenance on this vehice.I cannot find where it is to replace it. Hopefuy someone can expain where to find it.Any help is appreciated.
Have fun. ">
Check the salvage yards... mine was purchased for about $25 and then I traded the Pathfinder in on an '07 Frontier CC LB, which is what I wanted to begin with... good luck.
http://www.datasheetcatalog.org/cgi-bin/helo.pl?field=Nume&type=B&text=k25&lang=- en&action=Search
the "2S" in front of K25 simply means that it was made in japan....i think.
it's not a big deal to buy it or replace it once you know which specific component to buy. Help?
thanks...rich
thanks so much....rich
part # NTE2393 It is the part inside the fan amp it is black and has three prongs connected to a small circut board. Can you identify the numbers on yours (the black part with three prongs?
here is a site that lists NEC FET's with a K25 starting part number:
http://www.datasheetcatalog.org/cgi-bin/helo.pl?field=Nume&type=B&text=k25&lang=- - en&action=Search
i appreciate your info and i will post anything i find.
rich
also i have read that the 2 cabin air filters are a probable cause for the amp going bad. since they become very dirty and clogged, the amp overheats and causes it to fail. Bottom line is that you should clean or probably replace these filters while you have the glove box out or you will be having the same problem down the road again.
look at this thread and you will see many conversations that steer you in the same direction. also, at about the middle of the thread , you will find a post that has the pictures of every step needed to replace this amp and filters as well as sources for the amp purchase other than a nissan dealer.
http://forums.nicoclub.com/zerothread/289709
good luck.....rich
http://x.nissanhelp.com/forums/Knowledgebase.html?catid=241&sort=d&pp=10&page=4
http://www.nissanhelp.com/Ownership/Bulletins/2003/NTB03-057.htm
I've checked the local salvage yards for a replacement amp, but haven't had luck there either. Does anyone known of any other makes/models that use that same part(the whole amp with heat sink)?
part # NTE2393. It is the part inside the fan amp. it is black and has three prongs connected to a small circut board. this part will give you 2 speeds, not 3 but that worked for me. i think it was about $9...
good luck
still debating what to do.....thinking about putting in new blower....$150.00......lot of money to waste if it don't fix it.
