Chevy Astro Bucking Problem
It ONLY bucks when I push the gas pedal down 'slightly'. I can accelerate hard or gradual with no problem.
Only at that certain spot past idle. ( no foot on pedal )
If I hold it at this spot, it will buck and "miss" so bad you think half the cylinders are missing. Get past this spot in pedal position, and it is fine.
The problem was I had a cracked coil, which was destroying the dist. cap to soon. Fixed the coil, now runs great.
I am having a similar problem with my Safari van. Did you replace the distributor? Was this problem accompanied by starting problem too? My van used to start on the first crank no matter what the weather was like. Now I have to hit it two or three times. Let me know at your earliest convenience. Thanks.
regards,
Doug
Did a complete tuneup
But when the weather was wet it would misfire give me a check engine and registar a p300 error code.
When dry out the problem would go away.
No one could correct the problem.
I did notice though that when the problem started that when it was cold and wet that the turn signal switch would also start acting strange.
I noticed that the misfires and the turn signal switch problem occured at the time.
I replaced the turn signal switch.
All my problems went away after almost 2 years of hell when it rained or snowed.
