2008 Subaru Impreza WRX
1568101130
  • stevecebustevecebu Member Posts: 493
    If GM had even half the influence you imply they had, the 08 Impreza would have a transverse engine and we'd be seeing FWD models in the lineup
    I don't think so GM is pretty heavy handed in the way they deal with things. Use the 900 lb. Gorilla analogy if you like. I can see this happening which would explain a lot to me about why Subaru did some of the things it did. But yes, it's not provable so it remains speculation but very believable. Cost cutting is alot different than radical changes which Subaru would severely object to. Cost cutting is a GM thing as well as Ford. Low budget the car I mean look how long it's taken for GM to give the Corvette a decent interior. How many years was it? Most of them? Is an interior that expensive? No it's to save every penny they can.
    I still don't think the Corvette interior is that good... :D
    GM was very different to Isuzu vs. Subaru. With Isuzu, they gobbled up their diesel technology, starved them of new product, then eventually used Isuzu dealers to sell more GMC trucks.
    They really didn't do that at all with Subaru. Well, Japan got the Subaru Traviq (actually an Opel), and Saab got the 9-2x, and Chevy even sold a Forester in India. But we just didn't see them control Subaru they way they did to Isuzu.
    If anything, Subaru has accelerated new product launches. Look how quickly the Tribeca came out and was revised.
  • dino001dino001 Member Posts: 6,162
    Yeah - as much as would like to blame GM for everything, including Locust in Africa, Subaru stumbles are most likely on them, not GM.
    2018 430i Gran Coupe
    :shades:
    Yeah but I'm trying to be nice about a $60,000 car. :D
    I think we as consumers will see all this for ourselves in just a few months but I still think at this point in time the base Impreza has a lot going for it over the WRX model since it seems like a lot of changes have diminished the WRX model in order to make the STI look better. I could be wrong, but I am heavily weighing other options.
    Well, since GM's involvement they have added content to most models, FWIW. I really don't see much cost cutting.
    They shared some models, cloned a few cars, negotiating big purchases with suppliers to get prices down, but there isn't any evidence that I see of rampant cost cutting.
    You may counter with the LSD delete but they deleted the LSD from the 2002 Impreza RS, too. Plus they add VDC in its place now.
  • dstew1dstew1 Member Posts: 275
    Steve said: This makes as someone on here said the base impreza to be a much better deal by far. You get everything but the turbo and the sport suspension well I can't say how different that is but my guess is you can add a turbo and remap the ECU and get gobs more power which enthusiasts do anyway.
    This is generally not a good idea with these cars. The NA 2.5L is NOT the exact same engine as the 2.5L turbo.
    The general consensus has been that if you were going to spend the money to do a NA to turbo conversion on one of these cars, and do it RIGHT, you'd be better off buying the turbo (whether it be WRX, XT, GT) in the first place. Not to mention if you buy the turbo'd version, you get a warranty.
    Doug
    Pistons, rods, compression ratios, head gasket design could all be changed, and then add standalone fuel management and a couple wide band O2 sensors and 40 hours of dyno tuning....
    Perhaps but guys who buy knowing they will tune the cr don't worry as much.
    Myself the only mods I will make to a car are Cross tower strut brace, Different sway bars, Rims and tires, brakes, I like performance brake pads. Better brake fluid and a change of tranny fluid to Redline after 10K miles.
    I would also upgrade the shocks when they originals wear out and none of that stuff is a big deal, all bolt on stuff and the tranny fluid makes a huge difference in shifting.
    I won't remap the ECU or major mods even once it's not under warranty.
    Have you seen the video where they dropped the motor from the Suzuki Hayabusa into a Smartfortwo car? OMG! All it would do was burn rubber in every gear! 175HP in a 1,000 lb car! A friend of mine had a twin turbo Miata. But it did have a bit of lag down low but once it was spun up it was a screamer!
  • jeffmcjeffmc Member Posts: 1,742
    "All of the WRX pics I have seen are the wagon, is there no sedan being released?"
    Looks like no one answered your question. Here are pics of the WRX sedan, available exclusively in North America (& maybe Australia, too?):
  • aaykayaaykay Member Posts: 539
    Frankly, if you were to ignore things like Juice's pet phrases like "concave side panels" etc., the new Sedan's overall look is of the current Toyota Corolla. The Wagon/Hatch on the other hand has an overall tasteful appearance, however.
    I am glad the STI is based on the wagon than the sedan, this go around. I might even buy one. :shades:
    The LSD is an actual piece of solid mechanical equipment that transfers power from side-to-side as the situation demands, based on inputs from the sensors. Very useful for high-performance driving, especially in a car like the WRX. I would bet my bottom dollar that they would not be eliminating it from the STI, like they have done with the WRX. Even in the Spec-B, they have retained the LSD, even though they added the VDC....I am certain it includes some creative programming to enable the VDC to function well, with an LSD doing its thing.
    The VDC on the other hand, simply uses the sensors in the existing hardware (4-wheel ABS sensors etc), adds a couple of additional sensors and brakes individual wheels or cuts engine power as needed, using software/firmware driven logic. Much cheaper for a manufacturer to implement (especially since most of the sensors needed for the VDC to function are already present in a car like the WRX) and seemingly is an excellent marketing tool :) ....also very useful for bad drivers. :P
    Given an either/or kind of situation, I would heavily favor the LSD over the VDC. But if both are available, then I am fine having both, as long as there is a VDC disable switch, which the new Impreza seems to have. ;)
  • rcinmdrcinmd Member Posts: 139
    Ford Focus on steroids....
    I guess I need to see one in person before I rush out to buy a leftover 2.5i wagon for winter.
    It seems like the Japanese in general are kind of following the BMW 5-series billboard sides, huge flat side panels from the skirt to the window.
    Also, whats with making cars so high up? My Legacy wagon (not-outback) is 2" higher than my 90s Accord. The WRX can almost drive over the Accord (slight exaggeration) and this is a sports sedan.
    As much as I want to feel European and be practical, I have always liked the WRX sedan more than the wagon and it seems like I still do. I wasn't in the market for an STI anyway so thats not going to affect my life.
    I do think as the styling gets more bland and they get rid of the technologies and features that differentiate them in the market (LSD), the appeal goes away.
    I agree although the Impreza in itself is actually a very good car and in fact most Subaru's are great cars. The problem is just as you described. I had to get my Hi-Lux an oil change today (7 liters of oil :sick: ) so my wife and I walked around the showroom while we waited. 2 hours for an oil change there, so we grabbed a Jeepney and went to the mall afterwards but we did check out all the 2007 Toyotas in the showroom and they do have models that will never be available for the US market. Now we didn't drive anything, but my wife sat in everything and played with the seats and controls as well as seeing if she could back it up visibility-wise etc... as we will need a car when we get back to the US next year. The Camry here comes loaded with everything but a NAV system and it retails for P2,000,000! :surprise: That converted at todays rate is $43,505.62 USD! :surprise:
    Anyway the reason I mention this is regardless of how the car drives, most don't handle very well, it has one nice interior with power reclining rear seats and all kinds of buttons for the rear seat passengers to control stuff and the leather interior is really, really comfortable. Now this same car in the US is probably about $27K and you can get discounts so it brings it pretty close in price to a WRX which many people have talked about how nice the interior of the WRX is. Now my 2002 WRX was a fun car to drive but not in a million years was the interior anything like the Camry interior.
    So when people and magazine articles say the interior on the WRX is nice I can't picture it being THAT nice. Take away some of the WRX goodies and what you have is an AWD car that's $25K and is quick to 60 and is great in the snow. But I don't see how it's going to compete with other cars in this price range unless they need AWD. That's what Subaru is trying to do, is compete and it's in the same money class as a Camry and Accord and some others. Sure the driving experience is better in the WRX but c'mon how many people are going to notice the good handling when they sit in super plush leather seats and oodles of comfort items? Most people drive their cars like appliances anyway. So if you don't live in snow country the WRX isn't offering as much as it used to and the new interior, well if it's as nice as the Camry they really would sell a lot more of them. When you try to appeal to the mass market you have to provide cushy rides and isolation from the road and reliability and lots of bang for the buck. We don't have any grey market cars here yet, probably in 2-3 weeks we should be seeing them but they have to be converted to left hand drive so that takes time. We had FJ Cruisers before they got to the US.
    If I see one when I am in Manila I will take it for a test drive and see how it really is. Of course it will be the Japanese spec but still close enough.
    The WRX is a niche market car and I sincerely hope it's going to find it's niche again. But no way will it compete with cars like the Camry with the average car buyer IMO.
    By the way the WRX never got the MECHANICAL LSD that the STi had. It walways had the viscous coupled LSD which anyone who knows LSDs knows that the viscous is not nearly as good as a true mechanical LSD. I'm suprised you guys aren't up in arms about that.
    The only Subies to get a mechanical LSD were the SVX and the STi IIRC.
    -mike
    By the way the WRX never got the MECHANICAL LSD that the STi had. It always had the viscous coupled LSD which anyone who knows LSDs knows that the viscous is not nearly as good as a true mechanical LSD. I'm surprised you guys aren't up in arms about that.
    Ok well, actually I did know about that and sure I expect the STI to have stuff the WRX doesn't. I mean that extra $$$ has to buy something. But if it's not a big deal then why take it out? The only reasons I can think of is cost savings or to make the STI look better, or both.
    I just might look at other subaru models as well but I like sporty, but we'll see. I still am feeling down about the LSD. :(
    But sure the Torsen is much better. Look at all the stuff the STI and EVO will get! But of course the price is high and hard to justify.
    While a mechanical LSD would be the best, I would still prefer a TORSEN viscous type to an open diff and some computer retarding the engine output and or grabbing the brakes. I can think of very few occasions where having less power and dragging brakes will make the car perform better.
    Actually the one in the SPEC-B is also a mechanical LSD (I believe a Torsen). However, unlike the STI, which gets a mechanical LSD in the front too, the Spec-B has an open diff in the front. Also, unlike the STI which gets a Planetary Gear-based LSD with Electronically controlled transfer clutches in the Center Diff, the Spec-B gets the viscous coupler like all other stick-shifted Subarus.
    One good thing about the 4EAT WRX, the VDC OB and the 5EAT Legacy GT is that they get the same Planetary gear based LSD with the Electronic transfer clutches as the STI. They just don't have the capability to allow the driver to manually change the torque split, which the STI allows.
    Pardon my stupidity on this matter but it sounds like and please correct me if I'm wrong, that Subaru is giving you a better AWD system with the automatic tranny? :confuse: Is this about it? If so then why not in the manual tranny? I really don't like slushboxes. But I'm trying to figure out what's going on. I read up on the Spec B and the Outback (expensive cars and not as fast as the WRX) But I'm a bit confused about the LSD's that are in the WRX manual versus automatic and the stuff in the Outback and the legacy.
    Could you clue me in?
    Yes, that is true. The manual WRX uses the same AWD system as all other stickshifted Imprezas, other than the fact that the current WRX alone (among the Imprezas), gets a rear LSD. The ONLY stickshifted Subaru vehicle that gets the Planetary Gear based Center differential is the STI, which also has a switch that allows the front/rear torque split to be manually varied by the user...the default torque split being 41/59 with a bias to the rear. And yes, the 4EAT WRX also gets the same Center Differential hardware system, without the user having the ability to vary the torque split...the system in the 4EAT REX has a default torque split of 45/55 front/rear, but can automatically vary the torque split to the front/rear, as needed.
    I have no idea why they have not put the same system in the manual REX, which gets the same viscous coupling center diff system present in downmarket Imprezas, along with the 5-spd trans present in downmarket imprezas.
    In fact if you look at it, the STI gets a front mechanical Helical LSD, a rear Torsen Differential and the Planetary Gear based Center differential with electronic transfer clutches. This is in addition to the MUCH stronger 6-speed Trans (when compared to the 5-spd in the Stick WRX) and the significantly more powerful engine with forged pistons, Largest brake discs among all Subarus with large Brembo 4-pot/2-pot f/r Calipers, in addition to a host of other enhancements like way more beefier suspension components, Forged alloy BBS wheels that are 17x8 (as opposed to cast alloy 17x7 of the REX) with wider tires etc. The STI is certainly worth the premium that Subaru charges for it, over the REX, for people in the know, and is worth it from a value-for-money perspective (strange as it seems), even though it costs 1000s more than the REX. Several people mistakenly think of the STI as a REX with a little more power and one extra cog in the trans and an outlandish wing spoiler and they could not be more mistaken...in fact the REX is closer to the downmarket Imprezas than the STI, other than the fact that both the regular REX and the STI employ a turbo engine (albeit with big internal engine differences).
    Well let's get back to basics... I think some people are confusing things about the systems.
    The lines are being smeared here with some folks referring to the LSDs in the center v. the rear LSDs...
    Rear LSDs-
    SpecB, STi -Mechanical, STi has front and rear, SpecB rear only
    Pre 08 WRX, LGT, any other Subaru with a Rear LSD -Viscous rear only LSD
    Center Diffys/AWD Systems-
    5EATs - Planetary gears w/ 40/60 initial split, can transfer up to 10/90 or 90/10 depending on slippage
    4EATs - Electronic center diffy, 80/20 initial split can go to 10/90 or 90/10 depending on slippage
    5MTs - Viscous center coupling initial 50/50 and always strives for 50/50 but can vary to either axle depending on slippage
    6MTs - 50/50 initial, w/planetary gearset and electronic controls, can vary 90/10 to 10/90 depending on conditions and slippage, on STi can be locked at 50/50 and can vary initial split via driver control.
    This is a rough explaination of the systems, may not be 100% accurate.
    -mike
    Good description aaykay. And yes, that's the point of the STi to be the sports car. The WRX is setup for those folks who want a sporty car with some power, but not the all outness of the STi. Hence why they dropped the LSD in favor of the VDC would be my guess.
    -mike
    Rougly true, Mike, except for the 4EAT in the WRX (as different from all other 4EATs in the Subaru list of vehicles) having the 5EAT type system you referenced above, with Planetary Gear based Center Diff with Electronically controlled Transfer clutches (same hardware as the STI, without the ability to manually vary the torque split).
    No other 4EAT in the Subaru line of vehicles, has a Center Differential.
    Gotcha. There are also different AT torque splits back in the 90s, early ones were 90/10 and later ones 80/20 initial.
    -mike
    So the Boring slushbox gets a far superior AWD system?! Is it just me or does this seem wrong and that we ought to get at least the same thing on the manual tranny?
    IIRC, the other Imprezas tend to be more front drivers rather than rear drivers I thought I read it was like 90/10 and when you needed it it would divert up to something like you posted 45/55 or something like that.
    It's been a while since I sold my WRX and left the US.
    I'm just really getting this "screwed over" feeling for some reason.
    Yes I know the STI is quite a different beast or at least was, who really knows for 2008.
    I mean look at base Lancer, it's an ok car in fact my wife sat in a couple of models yesterday to see how they fit/feel and her gripes were the rear wing blocks her visibility as she is short and the seat will not move up close enough to the steering wheel. These were 2007 models and nothing special but she so likes the EVO. I can only imagine and dread what dealers will be overcharging for a limited edition model. Subaru seems better than many other dealers about not overcharging at least that was my experience. Honda when they have a hot model will add on a lot over sticker. Too bad Mini is so far away as I might consider one at this point. But an almost 2 hour drive for an oil change? Nah.
    Sorry Mike I'd like to have an STI but justifying the added expenses unless you have a money tree growing in the backyard or a very generous boss, generally means you have to buy what you can afford. The WRX was a compromise but a damn good one. It had pretty much everything I wanted in a car and did it all up until they dropped the rear LSD.
    I mean if money wasn't an issue I'd just buy a Porsche GT3! :D
    No idea what we are going to do now. My wife thinks it all too much BS and thinks maybe an Accord would be a better choice even without AWD it offers a lot but she never drove an Accord I've owned at least 1 and it's not much fun to drive. At least my 1995 Accord wasn't. When you start nearing the $40K mark you can buy a BMW with the sport package for that, and a 328xi wagon for same as an STI.
    Slower, oh for certain but for $41K a 335i sedan with the sport package would make a very nice addition to the family and good snows in the winter Nokians or something and it'll go thru the snow just fine. $40K is a pretty high price for me to justify tho and the 135i is probably about 4-5K less but smaller and less practical.
    So that's why the WRX was so great fro me but now it's feeling like it's lacking.
  • subearusubearu Member Posts: 3,613
    Yep. The 4EAT also had one variant that came with VTD and a 45/55 default split. This was available in the WRX's and Baja Turbo.
    -Brian
    Sounds like you've made up your mind to not get a WRX and don't want to fork over the $ for the STi. This is fairly common for Subaru owners as I've dealt with them in terms of business and a personal level for close to 10 years. They want Lobster and Filet Minion but only want to pay for Fish Sticks and Hamburgers. :)
    -mike
    Well Mike, I think I'm more a Burger and Fries kind of guy, besides I'm deathly allergic to Lobster. :P I just want some ketchup with my burger and fries (LSD) :D
    They had it before, now no ketchup, so I have to buy Tenderloin to get ketchup, :sick: which is much more than I want or need. No decisions have been made. The WRX is still on my list of cars to try, although I did decide to maybe try a couple of other Subaru's when at the dealership. Yes, I also added a few cars to my list, but keep in mind my wife also needs a car so I might just try and make do with buying a car that we both use for a while and then see what happens. Either way we need 2 cars and I worry she will stuff the car into a snowbank as she's never even seen snow! :surprise:
    So the Subaru makes a lot of sense. I'm just ticked off about a few changes Subaru made and while I can afford an STI or an EVO both will come out long after I need a car and I don't think I want to pay BMW prices for a Mitsu or a Subaru. Time will tell tho. My wife thinks she might like a Honda Fit as a daily driver but 6 moths after we buy it the new 09 model will be out.
    The rumors of a diesel WRX now that could spark my interest but I doubt they are true..
    http://blogs.edmunds.com/Straightline/3054
    I like what I see here. I hope it works for them.
    Bob
    http://forums.nasioc.com/forums/showpost.php?p=18656461&postcount=1
    Roof rack (carrier base) now rated to carry 176 pounds! Used to be 100 pounds.
    Bob
    We don't agree on much, at least the subjective stuff.
    I prefer the sedan. No clear tails, and it doesn't look tall and not-quite-long-enough like the hatch does.
    To be honest I'm really looking forward to the Forester, because I prefer true wagons over hatches.
    Not trying to downplay this but the last place where I would want to be carrying almost 200 lbs is on the roof of a sub-compact, regardless of the rating of the carrier base.
    I would be more impressed if the - payload - were to increase to like 1100 lbs or so, from the current 900lbs (850 lbs for sedan).
    The Blade runner theme looks like they combined it with something from Final Fantasy.
    I see the market they are going for and have no idea how it will work. Most marketing ploys don't seem to work well on me, show me gobs of power at a good price with good performance and that will sell me more than a commercial. But Subaru is trying to target a very broad audience with this stuff and going after Internet sales says a lot.
    I hope it works for them but I think they need more focus. But what do i know I'm not a marketing guy. maybe the next few commercials will be better. If they wanted this stuff they Should have let SquareSoft do the commercial for them and that would have been much better IMO.
    I like the JDM feel. Too many people try to go "euro". The ads make it proud of what it is.
    For those who may have overlooked it:
    http://video.on.nytimes.com/index.jsp?fr_story=597d89c8d6a7521869c30d9b8a77d50783ff5d39
    I think these ads are pretty sophisticated. I like the visuals and direction they are taking. They should appeal to a broader audience, which is what they're trying for. From what I see here—they will stand out—and that's half the battle in advertising.
    Bob
    I'm not crazy about that one. It's too artificially digital.
    But what do I know? Movies like that get crazy box office numbers.
    You do realize that VDC would be 1000x safer for a person driving in snow over an LSD would right? Your wife having VDC would be a lot more important than having an LSD for your auto-x excursions.
    -mike
    I'm with you, juice... celebrate the Japanese-ness of the brand, when appropriate. Many have grown up with an image of Japanese culture as ultra-modern, cool & intriguing. To do that in the US, though, they should've followed through by including the high-tech features offered on the JDM models.
    As long as you're marketing to folks below 65 years old, Japanese products have a solid reputation. They need to be careful about keeping upscale, modern & high-tech images in their ads, too. High-tech Japanese goods are awesome. Average Japanese goods are, well, not inspiring.
    Yes but if 2 people need to drive the car then it's a different matter. Also consider this many cars already have some form of traction control. Better than Subaru? No idea until I drive it but we have dropped a few cars off our list and the Subaru is still on it. Why Subaru can't offer the LSD as a $500 option which is what it costs as an option on some other cars is beyond me.
    I am liking the MINI Cooper S and it has a LSD and traction Control and it has a good style to it but the dealer is very far away about 2 hours and I have no clue as to how I would get it serviced. My wife likes a few cars that I don't but the Cooper S we both like but there is no room in the back seat for a full sized adult on a long trip nor luggage space.
    Saw the video of the new STI and I'd buy a BMW for that kind of money, seriously, they are just too expensive and the BMW will be an easier sale down the road.
    Make the LSD an option in the WRX and it would be a good thing for those who want it versus those who don't. I may have to go back to the US mainland for a few weeks and then I have to come back here for 6 months. I am thinking I just might buy the older WRX Wagon 2007 model, lots of incentives but parking it for 6 months is a worry as no one can start it up and run it. It would sit in a garage for the entire time which might damage it.
    But the VDC sounds good i just don't think they should have taken out the LSD in favor of what amounts to fancy braking and throttle control. maybe Subaru couldn't figure out how to use both components together?
    VDC is fairly advanced, to break it down to "fancy braking and throttle control" is belittling it a bit.
    As for a $500 stand alone option, Subaru can't afford to do stand alone options, especially one that is produced in Japan and shipped over here. They just don't do the volume to be able to mass pre-produce all those options, there is no such thing as "special ordering", yes you can order a car with XYZ options, but really what happens is your dealer waits until the distribution corp gets one with those specs in stock and then sells it to you.
    As for getting it to work together? The Spec B has VDC and a rear LSD, but neither is an option and you are paying top dollar for that car.
    The Mini is a nice car, but if service is 2hrs away that's not necessarily a good thing and it won't be 1/2 the car that the WRX would be in the snow. Also from what I've been told the LSD on the Mini is fairly limited with only a 20% LSD at most, a friend just sold one to get a 2001 2.5RS
    -mike
    I remember Ultra Man from when I was a kid, and Anime is fresh on the minds of Gen Y nowadays, they grew up with it.
    Who in their 20s would not recognize Pokemon, for instance.
    Leave the 'kraut for the Euro brands.
    Strange, I can't connect. I'll try again later.
    Works for me.
    Bob
    How so?
    I don't necessarily agree. Having something cut power and hit the brakes for me on a slippery surface doesn't sound all that helpful, actually.
    Especially if this comes at a cost of making it less fun to drive the rest of the time.
    Finally got the video working...that thing was really hauling asphalt! :D
    Mike says: VDC is fairly advanced, to break it down to "fancy braking and throttle control" is belittling it a bit.
    Steve asks: Ok so can you tell me about it because to me it pretty much seems like that's what it's doing. I'd really like to know about VDC in a way which explains it clearly but what I see is traction control that works by using the brakes and reducing the throttle. So honestly I'd like to know what I'm missing.
    Mike says: As for a $500 stand alone option, Subaru can't afford to do stand alone options, especially one that is produced in Japan and shipped over here. They just don't do the volume to be able to mass pre-produce all those options, there is no such thing as "special ordering", yes you can order a car with XYZ options, but really what happens is your dealer waits until the distribution corp gets one with those specs in stock and then sells it to you.
    Steve says: Yeah I hear you on that one. Still it would be nice if Subaru would do something like that. As far as the Spec B I don't think it's as performance oriented as the Impreza but a lot more comfortable.
    Mike says: The Mini is a nice car, but if service is 2hrs away that's not necessarily a good thing and it won't be 1/2 the car that the WRX would be in the snow. Also from what I've been told the LSD on the Mini is fairly limited with only a 20% LSD at most, a friend just sold one to get a 2001 2.5RS
    Steve says: Yep, and people sell WRX's to get Mini's it's what drives the car world. :)
    Yes, it's hard to beat AWD in the snow but so many factors come into play. Price, reliability, fuel economy, looks, driveability etc....
    For me right now the WRX is competing with the 2008 Honda Accord. I'm a bit ticked off because they won't offer the V6 with a stick in the 4 door any longer but it's a lot of car for the money and we get snow for maybe 3 months of the year. The Accord gives you a lot for a similar price point but no AWD. I know you are/were a fan of the GTO, but we need reliability also and I have to drive a lot of highway my wife has to drive more in the city. Nothing in 2007 interests me and 2008 is a dull year as there are no diesels. :( I'd take an Accord diesel over a WRX in a heartbeat! But I'd have to wait another year. This is why so many conflicts about cars. I want a diesel, my wife likes diesels also but no one likes VW dealerships and not one in my area has gotten a good review online, and the ones I've dealt with in the past :mad: the words I'd use would get me thrown off the forum. Plus resale on them isn't very good either, at least not in my area. So for us it will either be buying a Fit then move into an Accord diesel or buy a WRX and get a diesel in 2 years or something like that. Either way we will most likely end up with a Fit as a second car. The Mini is nice but it's a long hike to the dealership and if you don't like the dealership you have to deal with Boston traffic, and that one is the only other one in the State and it's a long drive to buy and service a car, nice and cute as it is and no discounts just full MSRP.
    BMW 1 series looks nice but might be too small and price is unknown but if I can buy a 135i for $30K and the back seat is actually useable for an adult I might buy one.
    3 series is ideal but $41K is not what I want to pay, I have other things I like to do with my $$$.
    The wife also likes the RAV4 and the CR-V but I'm not into SUV's. If I'm going to buy a truck it had better be able to haul about 5,000lbs or so.
    The CR-V and the RAV4 sold outside the US are smaller than ones sold in the US.
    I drove a Miata with Nokian Hakka Q tires and I passed all kinds of cars in the winter during weather that was really horrible. Drove through a canadian blizzard up in Quebec City in that Miata so tires make a big difference.
    We shall see I'm not married to any of these cars. I really need to drive them to make a choice but the choice is narrowed down and Subaru is still up there even with them pulling out the LSD. I'm still :mad: about that!
    VDC
    The euro RAV4 is indeed smaller but the CR-V is one size for the whole globe, I believe.
    Honda does have a smaller FR-V but it's just not competitive.
