The car was on a flat area of our driveway when it apparently started to move, but the driveway quickly becomes very steep. He apparently put on the emergency brake as it was going down the steep driveway. He also turned the wheel and someone told me that he should not have had been able to do that either. I tried to get it to go from Park to Neutral today and I could not....however on further, gentle questioning he said he pulled with all of his might because he wanted to see what would happen....but I pulled pretty hard too. I am floored as to why this happened and am going to have the gear system checked completely.
Thanks for your reply, any information is so appreciated. More than anything right now, I want to find out why this happened and if there is anything more needed to be done to prevent it from reoccurring....other than never letting them go into the car alone again.
If you cannot move the shift lever from the
"P" (Park) position to any other position
with the brake pedal fully depressed and
the ignition key in the "ON" position, remove
the cap on the console and with a
thin object such as a flat-head screwdriver,
push the shift lock release button down.
Then, with the brake pedal depressed,
move the shift lever to the desired position,
and then the shift lock release button will
automatically return to its original position
after shifting from the "P" (Park) position.
Then, reinstall the cap.
If you need to use the shift lock release, it
could mean your car is developing a problem.
Have the car checked by your Hyundai
dealer.
Check to see if the cap is still in place on the shift lock cover. It should be right above the P indicator on the shift console. It is possible your son stuck something in there or maybe the shift lock was broken or damaged when he pulled on it.
It was not disclosed whether the vehicle moved in a straight line backwards as that would determine if the child was able to move the steering wheel, or just tried to. Moving a steering wheel without the power steering on is very difficult to do, anyway.
The dealer inspection may throw some light on it. But I bet from now on the parking brake will be applied every time the car is parked so close to a steep driveway.
My son did move the wheel and did turn the car (which was a good thing in this situation, putting him in the path of least possible harm). I don't know how difficult it was for him to do so, I just know that he did.
I was told to have it checked out and will definetly do so ASAP. Neither my husband or myself can get it to move to neutral ourselves.
I thought it might be that I parked it and left it in neutral, but the key would not release if I did that. Also thought possible that it was not fully in Park, but then it would have to slip down two slots to neutral.
I wish I had answers, especially since I don't want this to every occur again.
I do thank you for your replies.
FYI: NO KID WILL EVER PLAY OR BE IN A CAR OF MINE ALONE AGAIN...NOT EVEN FOR A FEW SHORT MINUTES.
We still enjoy the car, and wow, the new 2008 model has everything I would have changed on the 2003 model. Nice changes and then some! I'm checking into selling this one and maybe leasing a new 2008 model. I would think a used car with a "new" computer and transmission would be a selling plus!
Bob
Then I try something in the uphill (but it has a very small grade): drive to a position in the uphill, stop and park it. Then switch to “D” again, the car CANNOT stop and start retrogress :mad: . At this time, I push the gas pedal harder, then the car begins move forward with shaking.
I am thinking it is the transmission problem, but not sure if it is the same as what is being discussed here.
This is a brand new car and I did not drive it a lot. I do not do oil change or any maintenance yet.
Thank you very much for your input!
No codes in system - internal mechanical concern - low pressure at idle possible pump failure in trans.
But they refused to work on it and advice me to bring it to the dealer where I purchased it. So I drove to the dealer where I bought and still waiting for their test.
That is bad, it only has 1600 miles. :mad:
Should I just accept the replacement? Or can I do anything else? It is a brand new car with only 1650miles!!!
We have a 2001 Santa Fe which keeps jumping from second gear into third and then will not go any higher or lower until you turn the engine of and then restart when it jumps from 2nd to 3rd it goes with a thump,will be taking it to a hyundai dealer asap but just wondered if anyone has had this also
Many Thanks
I checked the fluid and it was low and dirty so I am hoping a good transmission service will take care of it and the check engine light. Does that sound like a reasonable solution or can I expect the worse and a huge transmission repair bill? Again the vehicle was driven a very short distance back home so hopefully no further internal damage occured.
It is my fault for not checking an keeping up on fluids so lessoned learned, usually that does not occur. Thank you for your feedback and input.
SUVs and Smart Shopper
Did they hassle you much before offering the new transmission?
- Bokonon
I can understand that but I know I'd feel a LOT better about not having to pay for it myself.
The 2007 and 2008 appear to be essentially the same, so I would think the trans problems would apply to both years.
Even though I am really upset with my trans problem, so far the diagnostics that have been run on it show that it is working properly. And it DOES work properly once warmed up.
When you are looking at problems with the Santa Fe trans (5 speed auto), they fall into two areas: 1.) Poor shifting under certain conditions or trans failures and 2.) a 'slow' 1st to 2nd shift.
There have not been many posts related to #1 (mine falls into that category), but there have been a lot about #2. Mine does have the #2 problem, but it has never bothered me. I had a Villager minivan that shifted from 1st to 2nd in exactly the same way, so I am used to it. Other people absolutely can't stand it. I suspect that problem #2 will never be eliminated (although it is possible that there could be a future software upgrade that might help).
So, I think that unless you are unlucky like a few of us have been, you probably won't have a trans failure or other trans weirdness. However, you should put a lot of test drive miles on one before you buy to be sure that you can live with the way it shifts from 1st to 2nd.
I'll be reluctant to recommend Hyundai to people I know base on my experience but I don't know if I am "one in a million" or "one in a hundred". So as to a new car buying decision, I would ask you to weight the cost saving (if any) to say an equivalent car of a more reputable brand. If the SF is 2 or 3 grans cheaper then an say Honda CR-V, is that 2 to 3 grans worth the headache to you? Or maybe 4-5 grans saving?
Anyone know what the would be causing this to happen
My issue is that I paid for a new car not a car that had to be ripped apart to have a new transmission put in at 290 miles. I'm currently in the beginning stages of fighting for a completely new vehicle. I was just wondering how you got the dealership to buy back your car and if you had any suggestions on dealing with this issue. Where did you buy your car from? Did they buy it back? Everyone at Hyundai that I've talked to said that have never heard of this happening before an it's such a freak incident but honestly if it is I don't understand why I can't have my car replaced. It doesn't seem normal to me.
I really appreciate any information and advice you may have. I'm shocked to have found someone else that has had a similar situation happen to them.
I have also bought the new '08 Hyundai and I was talking to someone from Hyundai customer support about some accessories I wanted which do not come on GLS (Fog Lights) and the customer associate told me if my car is less then 500 miles then dealer ship should be able to fix me up with the new car since less then 500 miles is considered as new car. You should check this out.
The dealer where I purchased found that the transmission has problem and needs to be replaced. Wow, it is a brand new car!!
You are not alone.
Can anyone tell me if this is true and what causes the shift to overdrive? Hydrolic pressure and or electronic controlled valve?
Not too bad.
Just today, I went to put it into reverse and it just sat there....and sat there.....and sat there. I would rev it up and nothing would happen and finally I would hit the gas and it would start to crawl back like I am driving a manual vehicle.
I've also noticed that it shifts hard from 1st-2nd and if i dont have my foot fully on the gas at slower speeds (under 45) it seems like it slips out of the gear. I checked the transmission fluid and I put more in it, but it hasn't helped.
My SF 2008 SE is driving me crazy. On one day the car drives very smooth and shift very well, on another day it drivers like if I'm polling a truck behind me, stiff and slow shifting from gear 1 to 2. I took it to Hyundai dealer three time , and every time they told that the car is perfect and there in no error or code to duplicate. I don't now what to do anymore. I will lose lot of money if I try selling it. Any help appreciated.
either or is under warranty. i have a feeling this guys are going to change the transmission. Has anyone being thru this before, any idea how long that takes?
i find my self checking if its in reverse drive or in park. ill will keep you guys posted with any issues, but so far it feels like i have a new car again.
