2008 Acura RDX Rumors
My wife and I just started with the very early stages of looking for a replacement car for her 2005 FX that is coming off lease at the end of the year.
We were both rather disappointed that the RDX has no passenger side power seat and no seat memory but are still drawn to it because the technology package is the best out there in a compact SUV.
The salesman insisted that this is being corrected for 2008 (he says due to weak sales) but we were interested in whether or not anyone had heard anything similar or not.
Any other 2008 rumors? The other vehicle we are looking at is the Nissan Murano which is rumored to be completely redesigned for 2008.
~alpha
http://www.caranddriver.com/autoshows/12721/infiniti-ex-concept.html
With VPP discounts through my employer we will pay a little under invoice on any Infiniti or Nissan product which is why we were looking at the Murano. The FX is really compact actually and a little smaller inside than the Murano, but our main complaint with the FX is the extremely stiff/harsh ride (harsh even by sport standards, my Audi A4 has a much more supple suspension than my wife's FX).
Thanks for suggestions, I will check some of those other cars out. The technology package on the RDX is still the most impressive I've seen with the GPS integrated climate control, traffic data for the NAV and bluetooth with handsfree dialing.
I have a friend whose son works for Honda. I will see if he can verify/refute this rumor.
FWIW, I'm with you on the compact nature of the FX. While a great performance vehicle, I've always joked that it's the hatchback of the mid-size luxury SUV class.
I think that if the RDX continues to sell poorly the more likely scenario is that the price stays the same with more features added, possibly a few things slipping from the technology package into the base trim and bigger manufacturer incentives.
Has anyone heard a whisper as to when the 08 models are going to be available?
Thank you kindly.
Rumors I've heard are that changes to the RDX are going to be pretty minimal, like a couple of new colors, moving some of the Tech features into the base model, and making some of the accessories standard. No word on pricing, but I expect that you will pay more to get more.
Different strokes, I guess.
(2) Demographics at "play". How many buyers have "this" interest?
(3) Power passenger seat... Power/memory seat "base" from Ebay? My 2001 Ford class "C" MH has an RX300 driver's memory/heating seat in the passenger's position, as does the driver's side. $250 on ebay for the RX300 "set", plus another $150 for an ES300 seat from which the memory/power base was removed and installed under the RX300 passenger seat.
Anyone in the market for a '97 ES300 driver's side seat but with an RX300 passenger side power seat base?
(4) See above.
(5) Aftermarket...my 2001 RX300 has 17X8 RH brand wheels along with +1 summer only Bridgestone Turanza tires.
(6) Nowadays auto-dimming rear view mirrors are not as viable as they once were due to the now consistently deeper tinting, darkening, of the rear and rear side windows in order to increase the efficiency of the climate control system. There is an aftermarket solution but absent putting the rear "looking"/view auto-dimming sensor on the outside rear(??)to avoid the tinting desensitation it would likely be useless.
(7) Auto-on/off headlamps...hmmm, does seem an odd thing to leave off.
(8) Rain sensing wipers. I have these on my 2001 C4 but I'm not so sure the cost would justify. Even here in Seattle.
(9) I would agree, air suspension would be really nice.
(10) Obviously you haven't yet had to endure the continuous "shiftiness" one encounters with a modern day 6-speed. More likely 9 "speed" with the modern day use of the torque converter lockup clutch in gear ratios below O/D.
All this "shiftiness", while somewhat discomforting as a driver will undoutedly improve FE and FWD safety. Most FWD and front torque biased AWD vehicles are now being programmed to upshift upon full throttle lift to prevent engine compression braking from resulting in loss of control or even ABS operational interference.
(11) The Feds require that HID headlamps be self-leveling. Insofar as "articulating" is concerned this seems to be a somewhat mixed bag. Where do these headlamps "point" as you are existing the curve/turn?
Answer..
Not toward the roadbed.
(12) Aftermarket, Ebay, again, specifically V-LEDS, Velocity LEDS. Both my 2001 AWD RX300 and 2001 Porsche C4 are fully retrofitted to LEDs, tail/stop/turn/parking/street/DRLs/high mount. Plus many of the interior lamps. During DRL operation the tail/street/parking/marker LED lamps are also enabled as is required by our neighbors just to the north.
Backup bulbs are 12 volt 50 watt bi-pin halogens (re)fitted into OEM lamp Bases. With the RX, during tail light only operations the inside set of rear tail lamps are disabled but enabled for STOP/BRAKING. On the C4 both OEM rear "fog" lights are wired to come on with braking. These mods provide a much more pronounced notification to the rear that I am "on the brakes".
(13) Like with OEM embedded GPS/nav systems, an aftermarket solution (two DVD player/screens actually) will not only be more competitive overall, but more viable in that they can be moved about for use in other family vehicles.
11) HIDs are required to be "leveling," not "SELF-leveling." There are plenty of cars out there where the HIDs are leveled by the driver's finger. Which means if I'm not on point, I could conceivably aim the things to the sky. I don't change the load in my car too much, but can understand how the non-SELF-leveling lamps could be a pain.
13) I agree that aftermarket systems are the way to go. However, that's irrelevant to Acura. They stand to make a lot of money charging $1,100 for "integration" of a $300 device...
On the latter one outside rear view mirror position "follows" driver seat memory so I simply use one of the extra seat memory positions to tilt the outside mirror downward slightly during night driving.
11) Not sure I fully understand here. Both of my HID equipped vehicles will auto level the headlamp assemblies each time I turn the ignition on. The RX will continue to self-level up to about 20MPH roadspeed. I only know of one vehicle wherein the driver can control headlamp "leveling" and in that case it turns out to be a "downward" over-ride of the existing auto-leveling. You can never move the headlamps above the auto-leveling upward "target".
13) The only reason my '01 Rx has a "captive" GPS/nav is because it was "packaged" with other features I wanted, something I will always resent.
There comes a time for all manufacturers, regarding factory vs aftermarket options, that demographics overcomes greed. Consumers do not indefinitely remain stupid to price/value disparaties.
Now if we could just get the idiot dealers to recognize that.
Back in late 99 when I was in the market for an early MY2000 AWD Chrysler T&C delivery every local dealer (Seattle) had them loaded up to the "gusset", every factory option consieveable and then locally installed dual headrest DVDs.
I called a dealer in AR who found me a "stripped" AWD T&C LXi.
I have a 5-position dial on the dash that is the only way of vertically aiming the HID headlights... There is a page in the manual that tries to correlate number of passengers (therefore, vehicle load) with dial position. But I think it's a crude baseline at best, and that the only way to realistically aim the headlights is out on the road, and even then only if you've owned the car a while and have a feel where the lights should be hitting.
For the record, I COULD have bought the $1K+ OEM DVD system in my Mazda (and have the kids and make the journeys to justify it) but ended up getting a dual-screen setup for less than $200. I admit that it looks junky slung over the headrests, but it also comes out of the car when not needed, reducing the chance of getting stolen, etc...
I own a different brand, but I've never encountered anything I would call continuous shiftiness in my 6 speed AT. I find my 6 speed very responsive, and I much prefer it over a 5 speed I previously owned.
Bruce
XM standard on all models
Auto-dimming mirror standard on all trims
Driver 2-way memory seats standard on both trim levels
Multi-Information Display (MID) standard on the base model
Handsfree-Link standard on the base
Most accurate statement in the thread. :shades:
I have a 2004 V6 Touareg that I will payoff now in July/2007 and I am seriously considering the RDX.
Since I never tow or go offroad, I think this car would be nice. Still looking for news on the 2008.
Does anybody has it with 20s? I have on my Touareg and really like it...
I was expecting more changes and not the price to go up... :confuse:
Visiting Host who may be interested...
The 2007 is stiff and has a lot of highway noise. I seriously doubt that this has changed for 2008 as it has more to do with the level of insulation in the vehicle and the sporty suspension/handling than anything they can "tweak" out of the chassis.
2008 Acura RDX base package, out the door $32000 even. best deal i got so far all week.
