Suburban Tahoe Using Synthetic Oil or Conventional Oil?
Hi, I have a 1999 Suburban with a V8 5.7 liter engine with 98,000 miles and I have always used conventional oil. I do live in a cold area, so I was wandering if sythetic oil would be better suited for my car. I am planning to keep this car for a long time, so I want to do the best I can to prolong the life of it. Thanks for any help.
The data may be out there...but I am not aware of where it is located...if it exists.
For the older engine part of your question, some suggestions may be found in the Fuel and Oil Additives discussion. They do market some oils intended for high mileage engines but I haven't paid much attention to them (my high mileage rig is just at 117k; barely broken in. :shades: )
Engine life cycle testing can be done...where several engines are run continuously...on stands......with the oil changed at regular intervals...in a laboratory controlled environment...with different oils in their crankcases. This test can be done...with the engines run to the point of failure.
So why hasn't it been done? What keeps the lubricating oil producers from running this type of test?
Do they really want to know the answers to this question?
SUVs and Smart Shopper
