USED European Luxury Cars (pre 1990)
Also, the 380SL is a slow, gas-hungry car, and with prices hitting $2 a gallon, are you sure you want to put in a tank of fuel for $40 and go about 260 miles on that?
The C Class 280 is priced more fairly and is a better car in all respects...safer, faster and more economical.
I'd only consider the 380SL if it was an extra car for Sunday drives. And I'd still make him prove that mileage with records, otherwise I wouldn't believe it to be true.
Also, the later diesels have a problem with the trap oxidizer, which is upstream of the turbo. This device was meant to cut emissions but can cause problems with overheating, clogging, etc.
US models using this oxidizer are the 1985 300D, 300CD, 300TD and 300SD (californian versions) the 1986 300SDL (california) and the 1987 300D Turbo, 300TD Turbo and 300SDL (federal and california versions).
In theory, these old oxidizers have been replaced/improved, but if you find a car that has one, have it thoroughly checked out.
An upholstery guy says he can "rebuild" the seat for $150-200 (no fix for the leather of course, and no guarantee that it will be firm) and some friends suggest getting a late model MB seat from a junk yard--but how can I know if it is compatible with this car?
The movement of the seat is another matter. It could be just loose in the anchoring bolts, bu the rails could be worn out and that might require some new parts or some junkyard parts. Perhaps this could be ascertained before the seat is removed, and then the new/used parts installed at the same time the seat is repaired.
Thanks for the advice.
RE: seats----I always felt that a car needs good seats and a nice dashboard to look at, otherwise the driving experience is much diminished. While old German dashboards aren't the most elegant, they don't look good with torn and tattered dashboards, and nothing could be worse than driving while tilting left in the seat.
thanks for your thoughts
I'd never, ever give it to a national chain, they will just ruin it. Either cough up the $5,000 it costs these days for a quality paint job or drive it like it is.
Paintwork is all in the prep work and the quality of the paint itself. Even a $2,000 paint job has to be a "tape" job, and if it isn't prepped correctly, between the overspray, tape lines and possibly peeling paint you'll see in two years, it isn't worth doing.
The only proper way to paint a car is to strip the paint off, and remove all the glass and trim. That is, as you might imagine, very labor intensive.
If it were a Pontiac, I might say go for it, but with a Benz, they really look BAD with a cheap paint job, and their value is much diminished.
If you do it yourself, which I have a couple times, stay with a high quality, well balanced orbital buffer and use the appropriate pads for each of the compounding and polishing steps. A good auto parts or auto body supply shop will have everything you need.
The work on my Alfa Spider was miraculous. But it took the man hours and hours to do it right.
Way cheaper than paint, though, and now I have the original paint job back again.
I wonder what you might recommend as a used German or other Euro car purchase. I have a 1990 Saab 900 base model with 110k and a 1999 Passat 1.8T. Both are manual trans. and I maintain them faithfully. The Saab was rear ended recently and experienced frame damage which has largely been corrected and the car is in good running shape. I do plan to replace it though as it had some reliability issues last winter(I live in Maine)and now needs repairs to the ABS and AC.
My price range is up to 15k.
I love the handling and chassis response of both cars although their charcteristics are very different. I am more oriented to performance/safety than luxury but need four doors, firm, excellent seating, and decent reliability. I do not drive hard but like precise steering and cornering ability and will put both city and highway miles on this vehicle. There will be kids in the back at times.
Mercedes 300E, Volvo 850, Saab 9000 Turbo are all available in this area and I am always looking for cars that are interesting and special. An E30 or E36 BMW might work. If I could find one, a Volvo 850 T5 or type R would be of interest. I could of course look for another Passat but it is nice to have variety too. My Saab has been manitenance intensive but otherwise a solid performer. Do you have any thoughts about the above vehicles and am I overlooking ST worthy from Audi or another make?
Thanks in advance for any help.
Jace1
An Audi Turbo Quattro would be very nice for Maine, if you can get service and parts. Also not necessarily an exciting car to drive (in the years you'll be shopping for), but a very credible handler and very comfortable. By the early to mid 90s, Audis were pretty good cars, too. I would avoid any 5000 series however.
A BMW 325 would be a good choice I think, even though it is not a superior winter car. I think I would avoid the bigger 7 series, but if you could find a very clean, well-maintained 5 series BMW, that would be worth a look.
Shifty
Re: BMW, I have wondered about the 325 but they are not known for their snow-worthiness, as you point out. I run 4 Nokia NRW's on my Passat and maybe that would work on the rear drive BMW too.
Interestingly, there is a '92 525 touring wagon being sold privately in the area, white with 63k for 13,500. I have'nt seen it, only the ad in the paper.
Thanks for your help, it is helping me focus my search.
BTW, I see by your profile that you own Alfa's. I think the 164 is lovely and saw one in Portland recently (they are rare here). If you are ever in the area, check out the Owls Head Transportation museum. They own and run a 300SL Gullwing in beautiful, but to their credit, not perfect condition. It is silver over red with a lovely patina.
Thanks again
Jace
Audi 90 is fine, but no very exciting to drive I'm afraid. My brother has one and it's been pretty good to him after 100K....no major issues except let's see...fuel pump, general wear and tear, but driveline on an Audi is pretty bulletproof.
Maybe others can comment on the pre- and post 1992 300Es?
MOre often than not, when I meet a Lexus or Benz or BMW or Volvo owner who claims less maintenance costs over time than $200/250 month, and I drive/look at the car, I can see the result of not giving the car everything it needs.
But seriously it was good to see the feature on our own Shiftright in Road & Track. It's been a while since I've looked at a Chronicle but I remember Farley looking a lot like Nigel who looks a lot like Shiftright. Different artists, same rugged good looks.
BTW I once brought back the shine on a '61 Catalina convertible with 0000 steel wool. It started out as an accident--I was working on the chrome trim and strayed onto the paint--but it brought back paint that rubbing compound and a cheap buffer couldn't bring back. I tried it (carefully) on a Dodge and it didn't work, so I guess it only works on $200 Pontiacs.
starrow68 - My wife get's this all the time in her restored 380SL. Even the last CHP that gave her a ticket was oogling the car. I think I'll be keeping this car on the road for a long time to come as she really enjoys the attention.
It can be repaired with a new gasket usually (in some cases the cam tower is warped and will need to surfaced or replaced) but it's a big job, disconnecting timing chain, removing cams, etc, plus you know how one thing leads to another.
My wifes 280SE has been leaking for a long time, and even though I bought the gaskets long ago, I haven't been able to convince myself to do the repair, only degreasing the engine and cleaning the oil spots from the driveway. It leaks about 1.25 quarts between 3000 mile oil changes.
I agree with Shifty, it's a dog off the line, it starts out in 2nd gear unless manually shifted or pushed real hard. On the highway at 70mph it's revving at about 3200rpm. My daughters 95 Pontiac Grand Am with 4cyl. can outrun it easily.
On the other side of the coin, it's a well built, durable car, very smooth and quiet except for the creaks and rattles in any older car.
I wouldn't recommend it if you don't do your own repairs. It will nickel and dime you to no end.
1. Is it economical to keep vs. buying a 24,000 SUV. It has been costing me a lot to repair. But a good car overall.
2. What can I expect to get from this if I sell it to a private party. Excellent maintenance with all records. Excellent condition inside and out.
3. Where can I get factory wheels for this car?
4. Should I wait till it dies on me and replace the engine (rebuilt fr. a reputable MB guy here is 4,500. w/out tranny ??i think.
Comments and suggestions please.
You could probably get about $4,000 for your car if you found the right buyer and you didn't want to wait forever for a higher price...maybe $5K if you present it well and advertise it aggressively.
Your new SUV will drive like a dream compared to the old Benz, and you'll get comparable fuel economy, but your new car will never be as strong and solid of course.
Two different worlds here, so very hard to compare these two types of vehicle.
Jace1
'77 280SL----bad deal all around. The car is not nor will ever be a classic. Also it is way overpriced by about double real value. Last of all, it is a European model that was never imported to this country...a 6 cylinder engine in a very heavy car.
If you want a later SL, and you can spend $16K, you should either reach a bit higher and get a 560SL (best of the V8s) for around $20-22K, or shop for a late model 450SL. You should be able to find a mint show car for $16K, and very clean daily drivers in the $12K range, and occasional decent cars at $10K or under. I've seen them sell as low as $7K in very acceptable condition.
The V8 SLs are used cars, not classics....they were made in large numbers (some 66,000 450SLs alone were made) and their prices behave like used cars...the older they are, the cheaper they are....and their prices have still not stabilized, meaning that they are still depreciating. Probably these cars will bottom out at $10K or under.
Still, a nice ride for the money, if you can stand the price at the gas pumps.
Jace1
RUN! Also, that car has the weakish 6-cyl engine... No 71-89 280SL is worth $16K these days. Well, maybe if it was perfect, fully optioned, Signal Red, Black, Smoke Silver or Brilliant Silver and had like 12K original miles. Remember, grey-martket cars are always worth a solid 20% less than US-Spec cars with some rare exceptions on cars that were not oficially imported (BMW 745i, Ferrari 512, BMW M535i, etc..)
I think you might even be able to find a decent 560SL for $16K. As a dealer I have seen several sell at auction for $12-14K, granted those were higher mile cars that showed some signs of aging but they were still clean and presentable.
560SLs are weird. A REALLY REALLY Low-Mile and MINT one can fetch as much as $25K++ Heck, I saw a Smoke Silver 89 with 30K miles in absolutely flawless, perfect condition do like $23,000 or maybe a little better at a wholesale auction.
With those cars, condition is paramount.
Bill
try $3,500 or so...
Bill
I mean, a higher "asking" price is fine, great...but not double the value:
Maybe these guys are like a guy I heard about---has this old 85 Afla he's owned since college days. Well, his wife is buggin him and buggin him to get rid of it to make room in the garage for HER car (fair enough I guess) and so finally he says...."okay, it's going in the paper tomorrow". Which he does, for $11,500....lol! Only about 3+ times book value! Of course, he'll have to explain to her that "he couldn't sell it", no matter how much he tried...even knocked $1,500 off the price. Not a bad "compromise" for a $57 ad!
I listed it at market for a nice one and got real close to it really quickly (I had a few pices of "if you ever wanna sell it call me" papers..) unfortunately.
I SHOULD have put it in Hemmings instead for $149,900...
Grrrrrrr
Bill
These vehicles were crap when they were new, so they have just got to be worse after years on the road.
They can join the lists of foreign iron that should have stayed foreign such as Fiat, Alfa, and Peugot, as none of them can hack it in the North American market.
I believe in holding on to cars for a long time to get the most out of them, but this car has lived it's useful life and keeps on going.
I guess my question is, what is/was so wrong with these cars and why does my uncle's 5000 seem to buck this trend?
By the way, I got post 200!
Probably the car being a stickshift helped some, and the quattro system is hardly ever a problem. Also, by 1987 the 5000 had already been out...what...6-7 years and some problems were solved already. The last 5000s were mostly bedeviled by electrical glitches.
Last of all, we have no idea what your uncle's standards are. He could be driving a rolling wreck with all kinds of problems, none of them fatal.
