Well, it all depends on your personal preference. I chose the MS3 because I'm an incorrigible hot-rodder/track junkie, I needed four doors, and I like hatchbacks. There's not a thing wrong with the Civic- it just wasn't what I wanted or needed. Drive them both and make your own call; you can't lose with either cat.
Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
I figured it ws a bad car so during a heat wave (temps in the mid to high 90s)I dove (both '06) a GT and an S. After a 13 minute test drive the slaesman could not wait to get me out of the car b/c it was so hot. Te air coming out of the a/c vents was only cool not cold.
I test drove an '07 i with temps in the high '90s. After a 20 minute test drive teh car was still too warm although the air coming out of the vents was very cold.
I rented a 3i not sure if it was an '05 or an '06 with the temps in the middle '80s and teh A/c was fine.
My neighbor has an '06 GT w/ dark tinted windows and his a/c is fine when temps are in the '80s but is always too hot if temps are in the '90s.
The a/c issue kept me from buying the car.
http://www.hwm.ca/mazda_locks.htm
Thanks :confuse:
In most new cars, the AC compressor is on when you're on the defrost setting. You didn't mention whethere or not this is happening on defrost, so I thought I'd ask.
The fact that it cylces on and off doesn't sound right. I get the start up noise of the compressor when I first start up my heating/cooling system, but just that first time, not over and over again.
That part sounds like you might want to have your service guy check it out.
It might turn out that all this is normal, or they will say it's normal and you just happen to be focused on it.
Any 3 owners out there experiencing something similar?
The Mazda Club Chat is on tonight. The chat room opens at 8:45PM ET Hope to see YOU there! Check out the schedule
Manual or automatic?
Does anyone know if it is possible to change the manual climate control on a 2007 Mazda 3 to an automatic climate control unit?
anyways, i found a good mechanic to do the work, but I have been having a difficult time trying to find a used compressor for my 06 3. all of the ones I am finding on ebay are specifically stating that they are for 06 models FROM 9/1/05
...this is a problem..my car is 7/1/05.
now WHY is this a problem? im not sure..according to everyone selling these ac compressors..they all have this listed in their ad.
anyone have any clues as to why I couldnt use one of these in my car? anyone know WHERE i can find one that WILL work in my car? thanks so much for the help..hope im in the right place!
If your compressor actually seized, putting on a new compressor alone will not solve your problems, as debris has contaminated the entire system. So you'll need to flush the entire system and probably replace all the components.
If the compressor did not seize, you still need to replace more parts than just the compressor such as the receiver dryer. If the dryer dissicant (drying material) has burst inside, then the expansion valve is contaminated.
Replacing the dryer is a must. And of course recharge, etc, which should be done by a professional.
The dealer's price is high, since the compressor is about $500, the dryer $75, + refrigerant and labor. Seems like if you shopped around you could get a better deal from a professional AC shop. Working on your own AC if you don't have the right tools can be very dangerous.
You can't get it to work, unfortunately. Besides, you would need a different wiring harness and sensors too.
I took it to a mechanic and he said the compressor was bad and that it had also damaged several other components, all of which needed to be replaced. His quote was $2500.
The AC has never been very strong, but I can't believe I'm going to be out $2500 for a car with 51,000 miles on it. I am very stingy with the AC as well; I only use it when it is really hot. Anyone else having problems with their Mazda 3?
This is a problem for me because I live in Miami, FL....there are very few days that I meet the requirment to change my temp!
As of today I discovered that the temp changes if the car is turned off, ie: I parked my car and prior to turning it off the temp displayed is 94, 3 hours later start my car and the temp displayed is 104. After driving a few hundred yards the temp dropped a couple of degrees and with in several minutes (please keep in mind that I an not driving over 20mph for 90 seconds...the requirement to INCREASE the temp) the temp is back down to 94. So the AAS works fine if the temp needs to decrease, yet to increase the temp you have to meet the above mentioned requirements
Is any one having an issue with this? If you do contact mazda customer care!!!!
If my car sits in the sun for a long time...it will read 70+ degrees... (when it's 95-100 degrees outside). Then it takes about 20minutes or so for it to actually read correctly. It's kind of a pain.. but not a real big issue imo.
it takes forever to respond to a temp change. the gauge is in the dashboard, not
the mirror. Some times after a ten minute drive, the temperature does not move
at all.
Now it's 18 months later, and the NEW compressor has seized. Just my luck that the warranty on that is 12 months, so they won't replace it for me. I'm beginning to think this is not a problem with parts, but somehow with the engine putting undue wear and tear on the compressor for some reason. In any case, I am NOT happy about having to pay another $1,400 to get another 18 months of A/C.
Other than that... the car seems to run okay. But it sure would be nice to have a defogger on humid evenings. It's becoming a safety issue.
I'm 5'11", and although I never noticed before, I've recently improved my posture and noticed that I don't quite have enough head room in the driver's seat of my Mazda3. Any other tallish guys out there have head room issues in the Mazda3?
Are you actually hitting your head at times? 5'11" isn't what I would consider unusually tall (since I just scratch 6' myself). How much space do you have above your head?
I'm close to 6'4" and my wifes Mazda 3 hatch(2013) is fine, only if I lower the seat nearly all the way. Lowering the seat also gains some leg room.
