Chevy TrailBlazer Climate Control Questions
Son jumped another car,using mom's 2003 Chevy Trailblazer, blew a 125 amp fuse under hood to fuse block, replaced fuse,everything appears to work except the A/C blows only to the floor and not out the main dash vents,have check fuses, swapped around other like relays. I know its probaly simple fixs, but i cant find it. Thanks.
I've also had problems with a "sqeak" somewhere in the suspension and both of my rear speakers stopped working at the same time.
Engine start stoling now and then, few weeks later engine dyed on the highway @65MPH while towing the boat! Imediately lost of power stering, power breaks! I managed to stop and after few atempt started again and get lackily get home with constant power jump and few stoling. Went to dealer twice: first they replaced crank shaft actuator $550, next day(car stoling again)they replaced o2 sensor=$150! After that no more stoling but: 1 week later while changing the speed of the ac/heating fan it stop working and the same moment hapen foloving: ABS light-on;brake light-on;4WD light-on; cruise control not working; ilumination of driver door butons not working; unable to change the direction of air blow. NOW - after 10 -20 minutes of driving everything goes to normal until i stop and restart the car!!!??? I have been in service with this problem about 5 times, spent $1,250 (replaced 1 computer module)and theproblem is stil there???!!!
Thas enyone have any idea what to doo? Please and Thank you.
- TursiopsTech
Has anyone else had this problem, and what did you find out, and how much did it cost to correct?
Now the dealer is telling me the heater control module needs replaced. To do so he claims the dash and steering column need to be removed which is why they want $600 to do the job. Does this sound right? It seems you should be able to pull the part of the dash that surrounds the radio, climate control, and instrument cluster without the steering column. I assume the heater control module is located behind the climate control levers. Is that correct?
SORRY
Let me know if you found the cure, drop me an email even at jimmatyas@zoominternet.net
Thanks. Jim
Thanks again, jim in Ohio.
I did spray it with contact cleaner, but am going to double check again when i get the new part, which is tomorrow, takes 3 days to order an get it in at Auto Zone.
Thanks Jim, Ohio
