Do you currently own a 2019 or newer RAM pickup? A reporter would like to speak with you. Please reach out to [email protected] by 1/27 for more info.
Chevrolet Malibu Clunks and Noises
Hi, All
I've been reading the about the steering column noise issue. I have some very slight knocking, but it's not quite as described in Tsb 06-02-32-007. It only happens during slow speed turns (as in in and out of the driveway). Driving straight is ok even in bumpy roads. The sound is like very slight tapping and I think I can also reproduce it when standing still and jiggling the steering wheel from side to side.
Overall, not a big deal at all, but I still have warranty and wonder if I should worry about it.
I found anothe TSB on alldata that seem to be right on the money: TSB 06-02-32-005, "Snap/pop Type Noise During Steering Wheel Rotation(Replace Inner Tie Rod Boot)"
Interestingly the tsb comes up as applicable to 05 LS, but within the TSB there's a list of models that only has Classic in it.
Anyway, my dealer heard the noise and argeed to look into it. The car is going in tomorrow, will see what happens.
Only 43245 km and the this ugly steering knocking noise has suddenly appeared.
Time for another fun filled visit to my favorite dealer, soooon.
(i have a feeling all the little things will eventually annoy the hell out of me and i will and up dumping the car yet again. it's a shame really, only got in March)
Thankfully, the dealer was very helpful. I told them I had it in there for the same thing before and the service consultant explained about the new shaft and what not. I then learned that the extended warranty wouldn't cover it. So, I reminded them that it had been treated for this problem before. They are going to replace the steering gear and the steering shaft under my factory warranty since it was worked on before. Love that 12 month / 12,000 mile guarantee!
I get it back tomorrow morning and I am hoping that all is going to be normal with it.
I noticed yesterday that there's a rattle when I accelerate normally....it seems to start at some point as rpm climb and stops somewhere before the max rpm is reached before shifting. Sounds like a metal type of rattle, not too loud - can't hear it with the radio on.
Is it something known perhars?
I just got the car back today and the problem is totally gone. I can't believe how much better it is now. No popping at all!
I asked and it was only going to be about $750 out of the warranty had I not previously had it in for the problem. That's not as bad as I thought it would be. Still a lot out of pocket though.
price was $150-$200 less than dealer quotes.....
So this isn't related to the dreaded power steering failures that cause you to lose all power assist abruptly and with little warning?
My '04 Maxx just started making a clunk in low speed left turns only 1000 miles out of warranty. Naturally.
Since it's going to need tires ($400), brakes (probably another $400), battery, serpentine belt and now this...the thought of ditching it now while it's still worth something has crossed my mind.
so honestly.....getting out of it now is a personal choice...or do you simply do scheduled maintenance and keep going....guess it depends in finances and if you have the new car itch.....
End result, I have a new steering rack. 'Hope it last longer than the 7,000 miles I've read about elsewhere here. Otherwise, Camry/Accord here I come!
I can't recall how many miles I drove it in between fixes but I could always look at my records to find out.
Even though we have an extended warranty-what good if the local highest volume dealer didn't fix it in two years. Tranny shop changed the fluid, the axle seal at the tranny and The Bushing. Car feels brand new and no front end noise. He said that the 4T40E tranny is even used behind the regal w/supecharger? and good for 100k miles. Asked about the 5/8 inch chain w/noise versus requesting the 3/4 inch chain be installed by the dealer and the response was the answer about the regal-didn't know about the small chain but said the chain has never been an issue.
3.5 v6 with the 4 speed automatic-not exactly the 250k miles plus previa tranny-but then again it is only $1800 to replace at 100k or 150k miles.
WARRANTY COVERAGE
Passenger Cars and Light Duty Trucks Dealer Installed – 12 months or 12,000 miles, whichever occurs first, from date of installation (parts and labor). Subsequent replacements under this warranty will receive a new 12 month or 12,000 mile warranty from new date of installation. Part replaced under new vehicle warranty will be covered for balance of new vehicle warranty, but in no event less than 12 months/12,000 miles.
It's not for the Malibu but I'm pretty sure it's the same thing. Good luck,it helped me
thanks,
joe
I am taking it back to the dealer I got the car from on 7/7 to have them look at it.
thanks for the info!
We just got notified by our mechanic that BOTH hub bearing assemblies need to be changed. The car was making so much front end noise, it was unbearable and undriveable. ridiculous. Of course we get the nice clunking noise when the car turns. its like the steering colum or steering is just going to fail any second.
I'm sorry, but GM is indeed a GENERAL MISTAKE.
I dont know if anyone is experiencing this issue, but i keep having a buzzing noise when i take my car over 50 mph. its not constant, its more like a pulsing with about 1 sec pulses, and i feel it on the steering wheel and on the gas pedal the most. it gets obnoxiously loud and vibrates like nothing you have felt before, and feels like my steering is about to rip apart when i hit 80. I have read about this issue, and it has something to do with the power steering which of coarse is a hazard, but leave it up to those idiots at GM to not make a recall on it. any who, i will update once i take it to the dealership and see what they say.
I also have a whoop - whoop - whoop noise coming from the read, but i think its cause one of my rims is bent so its a non issue.
John S.
I would advise you to at least speak with a dealer. Please keep me updated.
Christina
GM Customer Service
I have also been looking at used Mazda 3's and i did not see chassis lubrication on any report.
