Kia Rondo Drivers Headrest
                    I am hoping I can get some help or advice here.
I test drove a Rondo and I really liked everything about it except the head rest on the front seats. I have whiplash, so I like to drive with the seat almost straight up so my entire back is supported, but the Rondo headrest sticks so agressivly forward I can't hold my head up straight. If I tip the seat back so I can hold my head up straight, then the top half of my back isn't supported. And I can't drive without pain in any position.
The dealer's solution was to turn the headrest backwards, but it wasn't designed to be that way, and that makes me nervous too.
Are there other head rests that would fit on the seat? Does anyone else have this problem?
Thanks for any ideas or help you could provide.
I hope this helps.
I will definitly try that on my next test drive. The headrest seems like such a stupid reason not to buy a car, but if you can't drive without pain, then you can't buy the car.
This is really good to know, I appreciate you taking the time to respond. Have a great day!
If the rearmost position of the headrest is still not far enough back for you, you could try using a shoulder-height accessory cushion between your back and the seat. Such a cushion would increase the distance between the back of your head and the headrest.
It may not be a problem for everyone - I can only assume that airlines make many of their seats have an uncomfortable protuberance that forces the head forward because some people like them. But if you hate the bump on airline seats, don't buy a Rondo.
We don't own a Rondo, but we have sat in one a few times and found the drivers seat very comfortable and had no problem finding the right driving position for both my wife (5'-3") and myself (5'-11"). I don't know what position the headrest was in when we sat in it but it did not cause any interference with our seating but we will look more closely next time.
We thought the "active headrest" was an excellent safety feature and should be on all vehicles. To quote the owners manual "The active headrest is designed to move forward and upward during a rear impact. This helps to prevent the driver's and front passenger's heads from moving backward and thus helps prevent neck injuries."
It would be nice to see a picture as to why this causes a problem, wouldn't just reclining the back of seat solve it? My daughter owns a 2007 HHR and she says her husband removes the headrest when he drives it, but I drove it and had no problem and neither did my wife.
As you didn't fill out your location I don't know whether you are in the US or Canada - have you thought of contacting KIA US or KIA Canada?
Other than this (and a few minor gripes), we love out Rondo. Having a car with three rows of seating is really handy. Another favourite is a heat/AC vent in the back seat, so we can thaw and freeze the kids when they need it.
We are in Canada, and no, we haven't contacted Kia Canada - not sure what good that could do? I don't think it's anything wrong with our particular vehicle, but just the way it was designed. I keep hoping there will be a substitute headrest we could get, but so far haven't heard of one.
kathyO
Any experience with heating or cooling issues for 3rd row occupants. Specifically for heat, does any heat blow on the the 3rd row passengers feet?
Yes there are toe warmer vents for the third row. According to my kids it takes a bit of time to warm up. I suspect that by the time the hot air gets to the back, it would be rather weak. KC
Wife bought vehicle, first time I drove it had 900 miles and my comment to her was, "Drives like it has been wrecked."
Unfortunately for me, she has no sense when dealing with such things, except I get to correct the aftermath.
Probably did it without consent because I kept finding problems with vehicles she looked at. Last one was a one year old very low milage Sable. Very fine car for money in every way except excessive noise, even for a Sable. Low speed trip around block revealed it and getting back to lot it was obvious someone bent frame around window outward. Very light metal compared to first generation (late 80's).
Absolute shame there are any problems with new vehicle. But it seems to go for all, including Corvette. Toured plant a few years back and they rolled one off the line, not out the door, but into pit. Terrible clanking like rod bearings or wrist pin. Asked mechanic how long it took to put new engine in it. "Oh no, we'll fix it!" So whoever got that car got one with a rebuild engine.
These headrests are also activated in case of rear end collision.
As for the steering wheel, I find it an ideal size (I usually drive in the 9/3 position) and also the steering wheel should be about 10" away from you. Also I have a clear view of all my instrument panel with nothing blocked (I am 5'-11"). I agree the leather on the steering wheel could be a little softer (maybe it will over time), but there is no excessive vibration through it other than normal road feel and the steering is very light.
I drive a 2008 EX Canadian model.
(wish this site would allow more details in the left column to show what you drive and your location)
How are they activated?
Also you have leather which may have more padding. Base model is a near hard slippery vinyl which requires a firm hold to keep it from getting away.
See my post about alignment in tires, etc.
Even with the Rondos headrest set to its' rear extreme, my head is held too far forward. I had a severe neck injury several years ago, which likely adds to my issue. However, my wife was also complaining about it after a test drive and it was set to the rear adjustment when she drove. Even our salesmen commented about it!!!
That being said I took a rear head rest, inserted in the drivers seat back and it was much better. Still not what I like but better and I could live with it.
Will check out the 08s one of these days to see if the issue has been addressed in any manner. If not I'll move on to another vehicle as the seat bottom was also another issue for my height and long legs.
Check my postings under another discussion pertaining to tires and alignment.
Vehicle will never handle properly if they can not align it. No adjustments for camber and caster. Either they put it together with a bad batch of suspension parts, front and right rear, or they welded it together wrong.
Three times for same repair invokes lemon law. Been in twice already and best efforts on alignment rack can not fix it. They are talking about bringing engineer from Atlanta. And I will not let them do as many Ford customers ended up with in later 80's. They ground open existing holes to allow for play. This weakened some components to the point it caused accidents and law suits. Don't want accident or to end up sitting in court endlessly with or without a bad injury.
This one may be that Monday or Friday vehicle, but considering so much is done with robots these days I feel certain there has to be a string of bad ones on the road. All bodies would roll down the same line.
http://www.kia-forums.com/kia-carens-rondo-forum/
http://www.kia-forums.com/kia-carens-rondo-forum/42361-my-new-rondo-my-opinion.h- tml
http://www.kia-forums.com/kia-carens-rondo-forum/42517-problem-pulling-right.htm- l
Not sure how its activated, probably a sensor similar to the ones used for air bag activation.
My first vehicle was a 1960 VW 1200 Deluxe (used) and my first new vehicle was a 1965 Pontiac Parisienne 2-door hardtop.
I wonder when KIA US is going to start showing 2008 Rondo info - they have been out in Canada since August!
We have not experienced any problems whatsoever with our Rondo, including pulling to one side (we used the original Michelins on the 17" rims 'til November, then installed studded Goodyear winter tires on 15" steel rims). We love our Rondo, and are really pleased with the build quality and engineering.
Those of you who are having problems with your Rondos pulling to one side, I hope you are able to get this resolved - please let us know what happens.
I bought a 1991 Civic Si new in Jan 1992, and it pulled to the left really badly. After numberous trips to the dealer and repairs in vain, they finally replaced the entire steering rack and the problem was solved. Maybe this is something to consider?
My vehicle received $4,500.00 rear end damage and I walked away, I do remember the Headrest comming forward and catching my head as I was pushed back then forward then back in the seat again. Please don't remove them THEY WORK.
If I raise it, which I did try, the wide part at the bottom of the restraint still hits the top of the back of my head; it does not push it as far down, but it is still uncomfortable.
The only thing I could do if I bought this car, would be to turn the restraints around, which I am sure would horrify the safety designers. That makes the restraint too far back to protect me from whiplash; I can't even lean my head back on it for a little rest if a long drive.
I suppose if we like enough other things about the vehicle, I could turn the thing around and wrap something like a towel or sew up some padded thing, to make it wider at the top for some protection.
I did not think 5' 3" was that short! I don't really want to buy a wedge or other cushion so I can sit in my own car. If Kia & Honda & the rest of them want to sell cars to women they should design them so women can sit in them.
Do you know the headrest can be adjusted back and forth as well as up and down?
Now it's completely comfortable to me. I drove another car recently without the headrest against my head and found it awkward and uncomfortable.
Play around with the seat postion, it moves up and down and you can change the angle a little. You should be able to find something that works.
