Toyota Avalon Windshield Wipers
We have a 2000 Avalon XLS which we really love. I had to change the wipers just before the big Noreaster last weekend. Since the Avalon is so big, I ran the wipers and then stopped the engine when the main wiper was right over the steering wheel, making access easy! Changing the wipers was then a snap.
However, ever since I did that the wipers won't park and don't run on intermittent!
Does anyone know what this happened and better still, how to reset things in the car so they work correctly?
Unfortunately, I can't press on them hard enough to make the clump-type sound occur.
It's also hard for me to get the wipers to stop in the 'normal ' position. Whenever I turn off the wiper switch, they just stop right there in the middle of the windshield, so I have to try to time it. Intermittent doesn't work either.
Any other suggestions?
Wynn
Tim in PA
Wynn - you are lucky to have a mechanic that will do anything for less than the one-hour labor fee. Since I am 0.52 mechanic :-) I'll give it a go on my own. The alternator on the Rodeo is next.
Thanks again.
"push down on one of the wiper arms (it'll apply to both wiper arms), until you hear a clump-type sound"
Please don't do this. The wiper arm is secured at the base by a bolt. You will likely have to remove a small cover to get to it. Just loosen the bolt, then lift the wiper arm off and re-position, then re-secure the whole thing. If you have a socket the right size handy, you're looking at about 5 minutes start to finish. I had to open the hood to get at my bolt as it was slightly under the hood.
