Lexus LS 430 Engine Problems
Trying to find out if anyone has had a similar problem. If my car sits for more than a day, when I first start it it makes a loud clattering noise, almosts like collapsed hydraulic lifters, and pours out lots of blue smoke out the exhaust. Its happened 3-4 times over the last 3 years and all I get is dealer bull****, lots of lip service but no repair. I've been told its the buckets over the valve spring hanging up "but its not a big deal or problem". Well it happened again the other day and I'm just tired of the nonsense from the dealer. Has anyone had a similar problem or heard of someone else having this problem, if so please let me know
My suggestion to you is to take it back to the dealer and explain the problem. May be even do a recording using a digital movie camera with sound to make your point.
I have found that the LEXUS dealers I go to are excellent in diagnosing problems.
Oddly enough, it seems to happen more if I park on an incline with the nose higher that the rear.
Any suggestions would be great!
Any suggestions will be great
I just read your message on edmunds and wonder if you ever got this problem solved.
I own a 98 myself and just start developing that same problem, the engine noise when i start it during this cold weather and when i steer and it all stops when it warms up.
I'd like to get your input as to what the problem was and what you did to get it solved.
thanks,
Anthony
tony11210@yahoo.com
Never did get it completely resolved. At the time I made a big deal with it at Lexus, factory, and they gave me an extender warranty for free, I guess to shut me up. They made a big deal about using the factory oil filters which I switched back to. It hadn't happened for over a year but actually just did about a week ago. Just to explain again my noise only happens at start up and sounds like hydraulic lifters that have bled down and then refill after 30-45 seconds of the engine running. When I spoke to one of the mechanics he explained the the "buckets" that work off the cam and actuate the valve springs must be hanging up. He knew what was happening, so they must have seen this before, but told me that he has never heard of engine damage because of it. My car now has about 135,000 miles on it and runs fine, burns no oil and sems to have no repercussions because of it.
Good luck
thanks for the quick answer. Actually my problem seems to be worse than yours, not only do I hear the noise that sounds like hydraulic lifters bleeding down u describe, what bothers me the most is the loud cranking that occurs when i steer to the left / right.
I own the car for three years and that's the first problem I ever experienced with it, after warm up it runs like a charm.I was very concerned when it start happening and took it to the mechanic right away but they couldn't pinpoint the problem. This is my third winter with it and never had this problem before, i guess that's because this one(season) is really a bad one.Really cold.
In any case you put my mind a bit at ease if ur mechanic reveals that he never heard of engine damage because of that.have about the same amount of miles and always use factory oil and filters whenever I do an oil change. I'm gonna keep on driving it like that and see what happens when the season's over.
I'd like to thank u for the input, very thoughtful . Keep me updated if u have further info. I'll do the same here.
A great year to you and your family.
Tony.
Took car home, next cold morning, check again and noise is exactly from steering wheel pump, weired hummy noise when I steer left/right.Tap / warm with hair dryer, still noisy, but as usual dissappeared after couple minutes.
Note that my car parked in unheated carport, And can't explain, after that morning, the noise dissappeared forever.Every thing normal now, 24 or 28 F still no noise.
Can't explain but happy.Share this experience with your guy. My car was a 2001UL / 80K.
