Trooper fuel pump fuse shorting out
Fuel pump fuse blew and the truck would turn over but not pick up; mechanic replaced it and it lasted ~6 months. Blew again a few months later, replaced it and the third time it blew, just a months later, we replaced the fuel pump. Expensive.
Now, 8 months later, it blows again. Mechanic replaces it and it immediately blows; he switches the relays and it works... for a day.
Blows while driving home and while waiting for the towtruck, I try to start it again and it actually started but then died out, twice (no fuel, doh). It didn't do that before when it blew...
just the turn over and no pickup.
Mechanic sez he is outta ideas...
Anyone have any ideas?
One guys opinion.
Disconnect high tension cable between coil and distributor.
Hold coil high tension cable end approximately .23 inch (1/4 inch) from suitable ground.
Engage starter and check to see if spark jumps across gap. If spark is not present, check for defective ignition coil. If ignition coil is satisfactory, I would check power transistor, which is a little more involved.
The power transistor, in-line between the ignition coil and ECM, is the switch that triggers the coil. By calculating various inputs, the ECM controls ignition timing through its control of the power transistor. The ECM considers input from the crank angle sensor, throttle valve switch, coolant temperature sensor, air flow sensor and vehicle speed sensor when calculating ignition timing. I would check for loose or corroded connectors on these items as well.
