Volkswagen GTI Lighting & Electrical Problems
moncef
Member Posts: 1
in Volkswagen
Hi Guys,
I have a 2000 VW Golf GTI VR6, and the dashboard light is not working so I have hard time at night see how fast I am going, Can someone please tell me how to fix it because I don't know nothing about electrical stuff.
I have a GOLF GLD of 1981. I tired to change the switch but the new switch didn't had a terminal for 'S' but it still works.
This is not clearly written in VW specs, as it is for other models (GLI for example), so I have doubts..
I also have a 2007 MkV GTI and I believe it is equipped with auto-leveling system.
if its just the gauge cluster (speed,gas,rpms) then you can check the fuses for that as well. if it is only the speed display that is out. then that will take a whole new cluster. the lights are LEDs and are made into the board. so if not like a bulbs replacement will help that.
good luck!
The MPG display has gone haywire. Instead of giving me an accurate readout of the mpg's as I'm driving along, it's spitting out random numbers, then it goes blank like it's trying to reset but then it starts to spit out random numbers again.
Only 2300 miles on it.
I know this means a trip to the dealer, anyone had a similar experience? :sick:
I have to turn the light switch twice (almost always) before I can have lights on the dashboard. Is there anyone who experienced this before?
SYMPTOMS:
1. Key OFF, Lights OFF
a. Brake lights OK when brake depressed
2. Key OFF, Lights ON
a. No low beam
b. Hi beam OK
c. Tail lights not working
d. Brake lights OK
3. Key ON, Lights OFF
a. Brake lights OK
b. Left turn front DIM & FAST
c. Left turn rear DIM & FAST
d. Right turn front DIM & FAST
e. Right turn rear DIM & FAST
4. Key ON, Lights ON
a. No tail lights
b. Brake lights OK
c. Low beam OK (DIM?)
d. Hi beam OK
e. Left turn front DIM & FAST
f. Left turn rear DIM & FAST
g. Right turn front DIM & FAST
h. Right turn rear DIM & FAST
Any ideas?
