Lexus LS 430 Suspension and Drivetrain
I bought LS430 in 02 and currently it has 106K miles on the odometer. I hope somebody could offer some advice to my question: I recently noticed, during my regular highway commute, a sound consistent with a tire being slightly out of balance or perhaps having a flat spot. It's coming from the rear. I checked with a tire place and they couldn't find anything wrong with tires, but they said I'll have to live with it until the next replacement (Toyo Proxes TPT with 36K). After a week, they rebalanced all 4 tires and replaced the rear ones. The sound did not go away. Could this be linked in some way to suspension wear and tear items. I do mostly highway driving. Any suggestions will be greatly appreciated.
Andre
Andre
Andrej
I thought the factory-installed Dunlops had an awful lot of rear wheel spinning on our 2004 LS430, even on dry pavement.
After 40k miles and now going into winter, we recently replaced the factory-installed Dunlops with the Michelin MXV4 Primacy. I can tell that they grip the road much better.
Here's my question. Since I have the electronic air suspension, is there a shock absorber that can be easily replaced, or is it more involved, like replacing a special strut or special shock absorber for air suspensions???
Oh man what a huge difference in the ride!!!! :shades: Now I can fully appreciate what the air suspension struts do to make the ride comfortable and/or sporty. Major improvement from the 96' LS 400 I had before this LS 430.
A defective, actually defective, air shock would have undoubtedly resulted in that corner of the car sagging overnight.
Interested in selling the "take-off"...??
So far I have swapped the L/R pressure lines going from the manifold in the trunk to check for leaks at the manifold connection and the leak remains on the driver side rear.
Now off to Lowes to buy new o-rings to install just to be sure and probably some black rubber cement in case I have a leak in the shock itself. But next up is a check of the air pressure connection to the shock itself.
Anyone know what the most common point of failure is...??
Probably the shock itself but checking the easier stuff first.
http://www.suncoreindustries.com/lexus-pages/ls400/lexus-ls400-rear-suspension-s- trut-shock-driver.htm
http://www.sewellpartsonline.com/
but there are several other online vendors as well. Please compare several sources before you order using Google for the best deal.
On our '91 I was able to swap the pressure lines left to right at the rear pressure metering manifold in order to determine the true failure point. The driver side rear had a series of small slits at the most common ride heigth air bladder fold point.
I have an issue with my 05 ls 430 Ultra. Car only has 36K so its in pretty good shape. Someone rear ended the car about a month ago. The damage was actually on the driver's side rear of the car almost all the way up to the gas tank lid. I had the car repaired from a lexus certified collision center. But now the whole car is leaning/sagging to the right. I have noticed this inside the garage which is a flat surface. I stuck my hand in between the wheels and the fender/quarter panel to measure the space in between each wheel and fender and its definitely different on each side. Also when I'm going over bumps I hear a thump noise coming from passenger side rear of the car. I have taken the car back couple of times and it seems that they either can't fix it or aren't fixing it. If someone could please help or point what could be causing the car to sag to one side. I would really appreciate it.
Thank you very much
The strut-mount, the top mounting plate for the shocks is an active part of the LS' suspension. I always thought it was simply a "solid" mounting plate, shock "tower". After replacing the shocks and the lower ball joints my '92 with 155,000 miles still has the "clunk" at the front when driving over road irregularities.
Order the strut-mounts, "suspension support" this AM. $109 each, discounted, at Lexus, $50 aftermarket.
Discovered the story of the "strut-mount" via the internet forums.
Apparently a fairly common, early, failure point of Toyota and Lexus suspension systems.
The thunk was not the strut mounting plate at all. It was the rubber cushion/insulator (with the protective bellows/boot attached) between the spring and the strut mounting plate. The insulator/cushion had worn down and been compressed so much that when going over the slightest bump the top of the spring would hit/contact the bolt head holding the mounting plate in place.
Slid 14" of 5/8" ID automotive water hose over the top end of each of the front springs...
No more "thunk".
Truly amazing...
How quietly riding a '92 LS400 with >150,000 miles can be with the top of the front coil springs NOT striking the bottom of the strut mounting plate when going over minor roadbed pertubations, bumps.
Has anyone tried sealing these with the "green gunk" found at Home Depot and the like that can be used to seal lawn/garden tractor tires..?
Our '04 LS430 with 80,000 miles recently started driving like a truck, so we took it in to the dealer and they confirmed the air suspension struts were bad. Fortunately we have an extended warranty, which covered all but the deductible. They replaced all 4 struts. The insurance company paid $5,700, I paid $200. Now she rides like a magic carpet again.
