GMC Yukon Cruise Control Problems
I have a 2007 Yukon. My cruise increases from 3 to 7 miles per hour depending on the slope of the decline. I have taken it to the dealer and they said that was in normal range. I have had a 2002 Tahoe that never had that issue as well as I rent veihcals of all kind with out having to break on every decline to avoid speeding. Has anyone else experienced this and has any dealership repaired the problem?
Do you have a link the the other forum? Also, will applying the programmer void the warranty?
Document ID# 1892711 6L80 Auto Transmission Busy Shifting, MIL Illuminated, DTC P1751 Set (Replace Control Body Spacer Plate) #07-07-30-002-(01-30-2007)
Its says vehicles built before December 2006 but I think I still have the problem.
The programmer plugs into the UDC connection under steering wheel and when you take vehicle for service you just re-enter the OEM program and the truck is back to factory settings.
The other fourm is The Chevy Avalanche Fan Club
I will get with my local GMC dealer who seems to really want to please their customers. Will keep thread updated!
Difference??? The only thing I did was increase the tire pressure (20 inch rims) from 34 to 38 psi.
Have you found anything out yet?
Good Luck!!
Switch is attached to the brake pedel and connects to the rod going to the master cylinder. Remove one bolt which holds the retaining clip in place. Defeat the interlock on the retaining clip and slid up to remove. Slide the switch assembly off the post connecting to the master cylinder rod and the switch is free. Unplug the wiring harness you can get out of that uncomfortable position with the switch in hand.
What I determined was that the switch has a somewhat friendly user removable access which exposes the contacts within. Defeat the four plastic release tabs (tow on each side) and pry the cover off. Inside are one set of open contacts with two contact points, and one set of closed contacts, with another two sets of points. The open contacts close when the brake pedel is pushed, completing the circuit for the brake lights. The closed set open, causing the cruise control to disengage.
Everything looked as good as new, but I decided to clean the closed set of contacts. Using electrical contact cleaner and a gun barrel cleaning patch I wedged the contacts open, inserted the solvent soaked cloth and let the contacts close. Then pulled the cloth out to clean the face of the contacts. There was a hint of black residue on the cloth, so I repeated until the cloth came out clean.
I snapped the cover back in place, reinstalled the switch and the cruise control has worked flawlessly ever since.
I my case, a new switch would have fixed the problem, but the contact cleaning is a pretty simple process and saves a trip to the dealership!
Sorry to hear that you are experiencing some difficulties with your door locks - if you were planning on visiting a dealership to get this looked into, please send an email to socialmedia@gm.com and let us know. We're available to assist in whatever way we can!
Best,
Sarah
GM Customer Service
