Toyota Solara Convertible Top Problems
"Someone Please Help Me." I purchased a new 2007 convertible SE (white with tan top) in November of 2006 and had it fixed for leaks in December of 2006 after rain entered my vehicle. Once again I am having the same problem in May of 2007. I have a good amount of water leaking into my vehicle underneath both rearview mirrors when there are heavy rain storms and the carpet is getting wet. The first time I had this problem the dealer reaplaced both parts of the rearview mirror that they thought was causing the leak, and now I have to bring it back in for the same problem. I must say that this is definitely not an issue of a few drops of water entering the vehicle when I am washing it, and I am quite upset about the entire matter. I am bringing my car back this week (May 14 2007)to see if the problem can be resolved. I would greately appreciate any feedback on this problem and would like to know if anyone else has experienced it???? Thanks.
Vehicle is new: 2007 Solara SLE convertible
anybody having difficulty with the passenger side clip in closing your top? Things are not lining up right and it can only be closed if I sit on the passenger side. The driver's side is fine.
Alan Russell
I had the same problem with mine...schedule a top adjustment at your service department and the warranty takes care of it. They basically realign the top and you will find it easy as pie to close it after it is done. BE prepared to leave your car for the day. Good Luck! Tonya
Check your top, you may have this problem too.
I don't think it's so much a design problem as it is a function of convertibles not having the 'drip moldings' that hard tops have. I have read that all rag tops have the same 'issue', regardless of make. I don't like it any more than you do, but it comes with the territory, I guess! I have started to keep a large towel under my seat.... and have gotten pretty good at opening an umbrella really fast - even before I'm all the way out of the car :P
Well said.
Been back to the dealer twice, but they were unable to eliminate the noise and told me it is normal for the convertible.
Since this discussion's for convertible top issues, I've moved your paint finish post to our existing 2007 Solara discussion, where you're more likely to get the feedback you're looking for.
Thanks for replying to my question. I have not yet resolved the issue with Toyota. I have had my vehicle fixed 3 times for the water leak and I just recently had the regulator in the drivers side door replaced because my automatic window kept tearing the weather stripping around the door off. I could not roll my window up or down without the weather stripping coming off. They finally got that issue resolved, but I am still having water enter my vehicle in heavy rain. I filed a Lemon Lawsuit in June and I am just waiting for my lawyer to be contacted by Toyota. He told me it typically takes about 8 weeks for car company's to respond. Since you have had your vehicle fixed 4 times during 1 year you should look into filing a Lemon Lawsuit. We definitely have to stick together on this issue. I probably had the same amount of miles on my vehicle when I noticed water coming in at the side view mirrors. At least the dealership you purchased your car from offered to give you a new car, I just got the run around from my dealership. Toyota needs to stand behind their product. I am sure the two of us are not the only ones with the same issue. Maybe we can force Toyota into doing what they should have done in the first place, which is fix the problem or give us a new vehicle.
My 2006 has just about 20,000 miles on it. Still tight as a drum.
Had three other convertables, never had that problem. I bet if you test drove a bunch of used convetables few if any would display that rattle.
Meegwell
Meegwell
Joyce
The Problem Is Solved. Toyota purchased my vehicle from me three weeks ago and cut me a check. They tried to fix the leak 4 times and could not resolve the issue, so my car was deemed a Lemon. I have since purchased a 2008 Lexus IS 250, and I am very pleased. :shades:
Thank you! :confuse:
Cheers!!
--njexpress
As it's designed when the top is retracted the volume automatically to compensate for the outside noise. When the top goes back the volume reduces back.
What I have noticed is when the top is up the volume intermittenly blanks out for a second then comes back. When the top is down I have no problems at all.
Does anyone know where the sensor/contact in the top mechanism that recognizes the top is down? I'm willing to just bypass the sensor.
Any help would be greatly appreciates.
Randy
Anyhow, now that you gotta deal with it, Have you tried any of the convertible top cleaners? I use Wolfstien's Raggtopp and it is pretty good overall. I have never had to deal with any stains, duct tape, gu etc... but I wa always able to notice the difference after the top dried out.
Good Luck!!
--njexpress
We had to replace a smashed broken rear glass (vandals.) I've noticed, a year later, that there is some black material showing on part of the window.
I brought it to a different upholstery shop and said there is a hole in the bow for centering the window. He checked the dimensions and said it was about 3 inches off. He redrilled a new hole in order to adjust the window.
Could this have been a manufacturer problem? Was the original puckering due to shrinkage and the shifting of the bow? The dealer saw it before it was brought to the 2nd upholsterer and was unable to help.
Is there anyone else with the puckering problem or any problems with the top as I described?
Not had a chance to look for it yet.... My radio works just fine.
Donald
What was wrong with your top? Why did you have to replace it twice?
I have a 2007 Solara convertible and never had a single problem. I'm at 34K miles and I don't know if I should buy the extended warranty to cover the electronics and the convertible top. I own the car flat out and plan on keeping it for as long as I can. I'm afraid if I fork out the money for the warranty it will be for nothing.
On the flip side, I'm so frightened that the second the warranty expires my top windows will break.
Does anyone have any advice?
We have the extended warranty and while it doesn't cover the fabric of the top, the stitching was a different story.
The owner of the top repair place told me I'll need a new top this year. The seams are puckering.
The car is not garaged. Next top gets a little help. A carport if I can or a car cover if that's the best I can do.
Megwell
out
That's so weird...yesterday I just noticed that the stitching on my top is coming apart. I am at 34K miles. What did the shop do for you ...just replace the entire stiching? I'm not even sure what the stitching is good for it looks rather flimsy.
I have a 2006 SLE bought new and it's out of warranty. Lots of white streaks and dryrot in many places. I have never run car through a carwash. Roof repair guy said it looks like defective material and to check it out online. Anybody else have this problem?
Thanks, Meegwell
Thanks for listening.
pam
Spenser3
Your problem isn't normal based on my experience with 9 different GM and Chrysler convertibles over 50 years of owning them (except for a 65 XKE with a mohair top). However, those GM and Chrysler tops used less porous, more durable looking fabrics that physically wore much better..
In the past 50 years, I only replaced 2 tops, but that won't be true with this Toyota.
Despite the many assurances and lies the Toyota salesman and one of the owners told me before I bought it, the tan top on my nine month old 2008 SLE is not only streaked, but stained and wrinkled like cheap clothes that have been repeatedly laundered.
Though I would never go back to the selling dealer, the other Toyota dealers who, over it's 15,300 miles service it, are very pleasant ,personable, and seemingly honest.
However, they continue to spout the Toyota line and insist that every complaint, shortcoming, and dissatisfaction I have with this car, including the top, is completely normal and that no one else ever complained about any of the issues I'm unhappy with.
In my experience, Toyota is the most overrated car I've ever owned, and the factory is totallly unresponsive.
But if you are otherwise happy with your car, just try to get used to the crummy looking top.because that's the only top Toyota makes available...
