Isuzu Rodeo Noise Problem
                    I have a 1995 Isuzu rodeo with 80K which makes a screeching noise only when I push in the clutch and when the temperature change ie"Hot to Cold" or when its damp. I just replaced the clutch and all its associated parts i.e." through bearing, flywheel, pilot bearing, disk, and pressure plate. I also replaced the master and slave cylinder. I don’t think it’s a clutch issue anymore. Any ideas.
Does anyone know what this could be from?? The belt looks fine, the clutch is new.. Any idea??
Replace and problem solved.
Bret
