Hyundai Sonata MP3/Aux Input Alternatives
I am really considering buying a Hyundai Sonata or Santa Fe but I can't get over that there is no MP3/AUX plug. I went to a dealer yesterday and test drove both in the V6 and decided that a Camry, Accord, or Altima just aren't worth the price difference given that they don't have the warranty that the Hyundai has. What's my alternative to not having a MP3 option? Thanks.
Anyway, there is a Sonata audio thread that may have some good info for you. Read through that one if you haven't already.
Anyone?
Crutchfieldadvisor.com
Page 5 has the info on wired RF Modulators.
This FM Modulator option would work well in vehicles with either fender whip antenna or the Glass antenna (wire antenna embedded in window or rear glass).
But in the case of the new Santa Fe (or similar vehicles), you may have problem. The reason is the FM antenna now is the little whip antenna on the roof of the vehicle. The metal roof of the vehicle will act like a good RF shield that prevents the FM Modulator's signal from getting to FM antenna. And the result is your FM modulated audio is probably very lousy. It probably sound like listening to weak FM stations when you tune FM mode.
In the normal case of listening to FM radio, this little whip antenna is fine since radio stations are outside of your car and there is little RF shield caused by the metal roof.
So for the new Santa Fe, if you were to use the FM modulator, you may have to stick this FM modulator unit outside the vehicle (on the roof) to get decent Audio. That is rather unsightly.
jt
With the modulator costing only $20 through Sirius, or ebay, I plan on purchasing a new one for the Sonata. Check this link for the Sirius website.
Like I said, the unit works great and as long as you can get to the back of the stereo, is fairly easy to install.
