Ford Explorer Tires and Wheels
I have recently bought a 2001 Ford Explorer Sport.
The previous owner (in my family) actually bought it with the Firestone tires and they shredded to pieces one day at low speed (no damage to anyone or anything thank God).
Ford immediately replaced the tires for some P235/75R15 Michelin that were always kept at around 30 psi.
Nonetheless, now that i got this car, and after reading the manual and the dozens of websites regarding tire pressure and danger issues on the Ford Explorer i dont know what the correct tire pressure should be.
The door indicates 26 psi but that is supposed to be the "dangerous" underpressure level of most accidents right?
Someone told me they should be inflated at 35 psi but that seems way high to me.
Can anyone tell me what is the real safe and official tire pressure I should use this this Michelins?
Thanks a lot!!!
Thanks a lot!!!
Hope this helps
Great info, thanks a lot for your help
I hope someone has an idea what is going on. I am tired of being mad everytime I go somewhere because of the thumping created by the feathering of the tires.
Hen
I also have a 2004 Sport Trac and have been experiencing the same problem with my tires that you describe as "feathering." I have been referring to the problem as "cupping" where the inside edge of the front tires are worn unevenly and little "ramps" are formed on the tread. It drives me crazy to hear and feel all of the thumping. I have spent about $1000 with balancing and alignment. I even bought two new tires for the front and in a matter of 10,000 miles, the cupping was evident again. Nobody seems to understand what is going on. And the dealer is mostly dummying up for fear that I am going to go after Ford for a remedy. Goodyear has told me that the only next step they would recommend is to replace the shocks, although they don't appear to be bad with only 43,000 miles on the truck. Like you, I am sick and tired of this problem. Did you ever figure out what the problem is and how to solve it?
Best regards,
Jeff
What do I know....it seems no one else has an answer out there...I have talk to many many mechanic about this and NO ONE has the right answer...TIME FOR FORD TO TELL US WHAT TO DO!!!!!
Possible causes:
1. Lugs not tightened properly after rotation.
2. Attempt to steal tires interrupted.
3. Metal fatigue.
I'm not sure if anyone has ever encountered this with their car, but still attempting to determine if other Ford Explorer owners have ever had this problem.
You can check yours by jacking the front wheel off the ground then grab the top of the wheel and the bottom of the wheel and see if it has any play by shaking the wheel up and down.
If you have play then you will need to replace the wheel hub assemblys.
Cost varies between $700 to $1500 depending on who you get to do the work.
Hope this helps.
