Ford Expedition Air Conditioning Questions
cougltcouglt Member Posts: 2
i've got an 02 eddie bauer. this weekend i began to notice a smell coming from the a/c when you first turn it on. it also takes longer for the system to get to an acceptable cool temp. definitely different than normal.
i go to walmart and buy a canister of refrigerent with attached gauge connector hose and i can't find the port to connect the connector to. i have a jeep wrangler and readily found the correct port on it but all i see on the ford is the "upper" a/c port. the canister says to look for the "lower" port.
can someone tell me where this "lower" port is?
«1345
    kastrojkastroj Member Posts: 6
    To All,
    Need assistance, looking for the electrical diagram for a 2001 Expedition, XLT Sport Edition. Took the truck 3 months ago to get the oil changed, all of the sudden the rear a/c stopped blowing cold air. A week ago I did my own oil change and noticed a loose connector underneath and I am asking myself if this has to do something with the A/C situation. This connector is nearby the drain plug. Looking for the diagram in order to troubleshoot it.
    kastroj
    jminierjminier Member Posts: 1
    To All,
    I have a noise with my rear air in my 02 Explorer. It sounds like a pump or something pulsating. Its a constant click, click, click. The engine does not have to be on, just the ignition. The rear air still blows cold. I pulled the panel off in the rear and it feels like its coming from a clear colored part behind the air unit. I unplugged the rear air to get rid of the annoying noise. When it started it would continue for about 30 minutes and then go away. Now it does not go away.
    If anyone has any idea's on what this might be, I'd love to hear them.
    jminier
    This discussion seems to be overlooked. Try the main Ford Explorer: Problems & Solutions one (there's a Ford Expedition: Problems & Solutions one too).
    Or check out the more generic Climate Control Problems (Air Conditioning, Heat) - All Cars discussion.
    fordonfirefordonfire Member Posts: 1
    I have just stumbled upon your problem while trying to search for the part to repair my exact same problem. My noise presented itself in almost the same way, however, occasionally the kids in the back would complain that the A/C was blowing hot air. The culprit in my 2003 explorer seems to be the air temperature mixer control for the rear air. There are two controllers on the rear air unit...one to control the air direction (up or down) and the other to control the air temp. They are both constructed of white/clear opaque plastic. The air temp. controller went bad on mine...it appears to have stripped a gear inside the sealed unit. I checked it by removing the unit from the main blower housing and plugging it back in. It did not click until I grabbed the shaft that goes into the mixer door on the housing. It felt as if it had stripped out and would not move when I was holding it with my fingers and just click. I guess the only way to repair is to replace the controller (don't know the cost yet, but it appears it is a dealer part and is probably expensive! :mad: ) I guess you have had the cover off to at least see these from your description of your problem. You have to remove two bolts and one nut to loosen the housing from the Explorer body enough to pull it out far enough to remove the controller(s)-- (3 screws hold them on) :D . You could just unplug the elec. connector to this controller to stop the noise as a temp. fix. Hope this helps!!!">
    jrhoppjrhopp Member Posts: 1
    I own a 2002 7.3L Diesal Excursion 4WD. and the rear airconditioning unit has stopped blowing cold air It only blows hot air. any suggestions for fixing or for trouble shooting? Thanks in advance.
    intmikintmik Member Posts: 6
    The rear air on my 99 Expedituon started to blow hot while the front one blows cold ? Any suggestions?
    wrencherwrencher Member Posts: 1
    Just fixed my 2002 Explorer with this issue.
    You'll need part number #YL5Z-19E616-AA costs $86.06 + tax.
    It is the unit described by jminier in his reply.
    The box snaps apart by 2 plastic molded clips on each of the 4 sides.
    The gears had teeth that were indeed broken. I did some more investigation as to why this happened. The box is a simple DC motor / gear assembly with a wiper resistance pot to feed back position. The cars controller does not have the correct set points for the stopping points. This problem drives the motor even when the mechanical stop (flap is fully open or closed) is reached. This continued pressure strips the gears and causes the clacking noise.
    We all need for FORD to better engineer their vehicles so this does not happen. :mad:
    I have not dug into the controller to see if the end points can be adjusted to turn off the motor at the end points.
    Let us all know if someone does this work.
    Hope this helps (it is not cheep) :D
    fliverfliver Member Posts: 1
    I have this same problem. Can you explain how to get the cover off? I'm assuming you have to remove the interier panel?
    rhelmbrightrhelmbright Member Posts: 8
    I have a 98 Expedition and had a problem with the rear only shooting out cold air, not hot. After tearing out the rear interior trim and was able to access the blower and heater core assembly, I found the blend door (which is what allows the hot/cold air through) was broke. This is a very common problem with explorers and expiditions. Very easy part to change for the rear. You just have to remove alot of trim to access the housing for everything. Also, the rear heater core was clogged and I had to replace that myself. I reccomend troubleshooting and fixing yourself. They will charge you an arm and a leg to take it somewhere.
    The front on the other hand is a pain in the you know what. I replaced the heater core in that. You literally have to take out the whole center console along with the whole dash board and everything in tact. After replacing and getting everything back together, I still had no heat. That is when I heard the "blend doors" go bad 95% of the time you have ac/heat problems. So for a temp fix, I drilled a small hole behind the glove box, into the left side of the housing for the heater core, and used a screw driver to pry open the blend door till warmer wheather comes and I can rip the dash out again to repair. Good Luck! :blush:
    The front is a whole different story
    lhwilllhwill Member Posts: 5
    A noise started coming from the rear heater in my 2003 Expedition this winter. At first I thought it was one of the kids kicking something in rhythm but then found it to be coming out of the rear heater. Does anyone know how to open that rear panel or has anyone heard of this noise?
    boatsnmateboatsnmate Member Posts: 2
    I have a 03 Expedition, the A/C works fine however, when I turn the A/C on in the rear there is a constant thumping noise from the rear fan area. I just noticed it would stop in a short while, before it was on going. I called the dealership who said the problem I described sound familiar however, without having a tech analyzing the problem they where not able to say what it was, except the price range to repair is usually $300 & $800. If there is anyone else that has or had this problem, I would love to hear from you. I would rather try to repair this myself instead of the dealership!! Thanks… :D
    I have the same problem (and the same model 03 vehicle)but thought that our noise only happened with the rear heat. I need to try the A/C and see if it happens when I turn on the air, too. I have done nothing about mine as it just happened in January and I don't usually have a lot of passengers in the 3rd seat. Let me know what you find out if you do take it to be repaired or repair it yourself.
    Thanks. :confuse:
    wmoenartwmoenart Member Posts: 1
    I have the same problem, I was told it was the accuater, which would cost about $200.00 to repair at the dealer, I took it apart and see one gear has two teeth broken off, very easy to replace, however, they don't replace just gears, they want to replace the whole item at $35.00, is their a place to purchase just the gear/s?
    The "accuater", is that the correct part name. Because I tried to pull it up by that name on the ford web site. They said there was no part listed under that name, I would rather buy that part for $35 then paying the $200... :confuse:
    jbaker14jbaker14 Member Posts: 1
    The only thing I could add to this answer (which was a big help, btw) is the location of the bolts & nut. There's one bolt at the bottom rear between the blower motor and the rear bumper. There's another at the top center of the unit. The nut is at the front and is kind of hard to find. It's in a hole facing toward the seats about halfway up the front of the unit. You'll probably need a deep socket to get at it.
    ahightowerahightower Member Posts: 539
    Maybe it's a typo. Try "actuator".
    mjeongmjeong Member Posts: 4
    I have a 2004 and had the same thumping noise. My problem would show up when I tried changing the air flow direction from above to below. My 2004 is still under warranty. Dealer replaced "Blend Door Motor" Ford Part Number 1L2Z 19E616 BA no charge works fine.
    truetidetruetide Member Posts: 1
    I have a 2004 Expedition Eddie Bauer. The A/C suddenly started blowing warm air. I checked all the controls and stopped and retarted the system numerous times with the same result. It's blowing warm air out the rear a/c as well. Fuse numbers 11 & 13 checked out OK. Any ideas would could be wrong? Thanks.
    rjm13rjm13 Member Posts: 2
    I have a 2003 Expedition Eddie Bauer with similar problems. I took it to the dealer and it was fixed. They commented that there was a leak at the condensor core and o-rings at high side liquid line fittings.
    orlando32817orlando32817 Member Posts: 9
    I have a 2003 expedition and found that you are correct about the set point problem. I took a my unit apart (broken gear also) and determined that when the temperature knob is set to full hot (5 o'clock position) the control voltage from the knob is about 0.15 volt. when full cold (7 o'clock) it is ~12.0Volts engine off key on or about ~14.0 vdc engine running. This causes the servo loop for the door motor to try to keep turning against the stop when cold position is set. The issue stops if you set the temp knob to the 10 o'clock position from cold. From all this I determined that the motor doesn't like the control voltage to be more than ~10 VDC. To alleviate this problem I calculated from the internal resistors used in the unit that one can add a 75,000 ohm resistor externally in series with the control signal wire on the 8 pin connector that leads to the hot/cold motor. The wire is one located closest to the white connector key way. The other 2 wires are for the battery key on voltage and ground. To order a new unit from ebay look at item 200116596985 ford # YL5Z-19E616-AA. I just ordered one from this seller on ebay. I will test it on the bench before I install it to make sure it behaves like the original and report back that it needs the 75,000 ohm resistor also.
    weldmechweldmech Member Posts: 3
    Hello: I just wondering if you ever got an answer to your wonder about the charge port for the expedition i got the same problem, please let me know if you found the port . Thanks in advance; weldmech
    Help!! Do anyone knows where the a/c recharge port is located on 2002 ford expedition, Thanks in advance
    The rear A/C problems discussion has been merged with this general A/C questions topic.
    SUVs and Smart Shopper
    jdhernandezjdhernandez Member Posts: 1
    Yes I had the same problem and the dealership fixed and a little over a year later it is doing it again. And ofcourse now they will not fix it because it is not under warranty, even though I had the same problem before and they supposedly fixed it. So be prepared for it to break again. I was told it was some kind of recall on the original visit but now they deny this fact and said there is not. Kind of odd that several people are having the same issue! The part number given in the other reply is correct. That is what is on my receipt and it is called the A/C Door Actuator (Temperature/Blend) So now I guess I will either get rid of the vehicle or go buy the part and do it myself, I am not paying over $300.00 for them to fix something they have already fixed. It is pretty upsetting!!!!!!!!!!
    bpartainbpartain Member Posts: 2
    I have a 1997, 5.4 Expedition. Whenever the RPM's increase (climbing a hill, causing the transmission to drop into a lower gear) the air condition air flow changes from the front panel to the defroster. As the RPM's decrease, the air flow reverts back thru the front panel. I'm stumped.....
    traderdaddytraderdaddy Member Posts: 3
    bpartain-
    Your problem is in the vaccum line that runs from the firewall to the ari mixture controls behind the dash. More than likely its in the hose under the hood at the firewall. You can just cut and replace it there. Inspect the line good and see if you can find any cracks. It just takes a small crack for this to happen. It is located between the battery and the firewall. It is a very small "spaghetti" tube. Hope this helps!
    Thanks, I'll take a look and let you know if this fixes the problem. I do appreciate the help!
    There should be a vacuum check valve and reservior also to store vacuum for medium to hard acceleration conditions to the vents dont go to "default" defroster mode when vacuum is low. YOu need to especially verify the check valve is not stuck open or leaky as this will cause the AC vents to act like you are decribing. A leak in the reservior can also cause problems.
    lenancilenanci Member Posts: 1
    I have read through these posts on the rear air issues but still dont understand totally on how to fix my problem. I have '03 Expy that blows hot air in the rear only. I understand that some parts can be replace without going to the dealership. My question first is where is the rear ac components loacated so that I can see what needs to be replaced?
    mrmikeymrmikey Member Posts: 6
    I have a 2007 Expedition EL. Occasionally the A/C just shuts off. It usually comes back on in a second or two, but once it didn't come back on at all. The only way to get it to come back on was to stop the car, turn the engine off, and resart. Then I could turn the A/C back on. This occured after going over a speed hump at 20 MPh. But sometimes in will just shut off. Sometimes I'm on the freeway, sometimes at a stop light. Like I said it will usually come back on by itself. This has been occuring since the car had just a few hundred miles on it.
    Plus the A/C seems to take a long time to get cold. Haven't brought it in yet, but just wondering if anyone else has had the same problem, or might know what is causing it. Of course when I go in, the dealership will probably give me the old "well we can't replicate the problem" routine, so I know I'm going to be frustrated as usual. Please help !!
    asandsasands Member Posts: 2
    I have a 2003 Expedition and the rear overhead vents are not working. The AC works fine in the front, but when we try to turn on the rear air it only blows in the third row seating floor vents. Any idea what might be causing this? :confuse: :confuse:
    buzzz1buzzz1 Member Posts: 42
    This is a common problem. Check some other ford message boards for more info. Ford tried to blame it on having a cell phone charger plugged into the 12v outlet near the controls....
    methridgemethridge Member Posts: 1
    I have a 2003 Ford Expedition, and the front AC is stuck in defrost mode. All other AC controls work. It just won't change modes. Is there a relay or control board that changes the modes or is it just in the switch?
    rswangerrswanger Member Posts: 1
    Go to O'Reilly's and purchase a new Actuator and install Price is $32.00 Plus Tax. Very easy fix for the clicking sound in the rear air. Just pop off the side panel and unplug the wire on the side next to the front of the blower and it will confirm the problem. Will only go one way so be careful. Good Luck! :)
    txpowerwagontxpowerwagon Member Posts: 1
    How to you get the side panel off. Is it the panel from floor to roof. I do not see any panel the will pop off. Thanks
    ejbarbsejbarbs Member Posts: 1
    Any hints on how to remove the rear panel? Thanks.
    dadoeightdadoeight Member Posts: 2
    Hope you found your fix. I replaced one in the Ford front end to my 99 motorhome and now I need to work on my Expedition. Did the 75K ohm resistor work?
    bjehlebjehle Member Posts: 1
    I recently had the heater core replaced and since that time, when either using the AC or the heater, when I turn the truck off, the blower for the front defroster will come on after the vehicle is completely turned off. I have pulled the fuse, #22, for the blower and it still remains on. The only way to turn it off is to disconnect the battery. The auto repair shop where the heater core was replaced says there is nothing wrong. Please help.
    03expedition03expedition Member Posts: 1
    This started last night and still doing it today. Whenever I turn on the rear air conditioning of my 2003 Expedition Eddie Bauer, I hear a clicking noise from the rear passenger side panel. Can you help me identify this problem?
    peanut9peanut9 Member Posts: 2
    I have an 03 expedition EB, i am hearing a noise almost the sould of a winshield wiper running from the rear right side panel in the back behind the third row seat???? Any ideas of what this could be?
    drallendrallen Member Posts: 1
    Thanks!!! just had a new engine put in an ever since going up hills would stop air conditioner from pushing air forward. After reading your message I check the vaccum lines and found one not attached....works like a charm now!!! thanks again..
    butch2772butch2772 Member Posts: 1
    I have a 03' expo and i have just recharged the refrigerant however the A/C is only shooting out what seems to be vent air. does anyone happen to know what is going on?
    arch610arch610 Member Posts: 1
    I just replaced the A/C Door Actuator motor today it worked till the temp got cold and the the clicking noise started again. Any ideas let me know
    dtownse1dtownse1 Member Posts: 1
    Just had the ac go off on a 95 degree day. after pushing buttons finally got rear to blow cold but not front seats. Checked fuses (3 different ones related to climate control) and everything ok. Turned vehicle back on and everything worked fine. What gives??
    maumalienmaumalien Member Posts: 1
    I have an '07 EXPY. I noticed that
    my AC was working, occasionally. Then I noticed that my cold-hot gauge would drop to "c". When this would happen the air compressor would shut down and then the AC wouldn't blow out cold air. Then, for whatever reason, the gauge would be reading correctly and the air would resume. This eventually got to be where the guage wouldn't read at all then there was no cool air. I took this to the dealer and a local mechanic. Both said there was no correlation, but still no solution to the problem. THe local mechanic has replaced every thermostat that might be related, the accuator, flushed (or whatever) to the vacuum, but still no cold air, nor does the hot-cold guage work. The dealer has never seen this problem. Any suggestions?
    tbone06tbone06 Member Posts: 1
    Good call on that vaccum line fixed that same problem on my 99 Ford Expedition. Thank for the info.
    wralexjrwralexjr Member Posts: 1
    Did you get a fix to this problem? My 03 is doing the exact same thing.
    bart175bart175 Member Posts: 1
    I can only find one port but it not the one I need to recharge the system I looked all over the truck does anyone know where it is.
    Jim
    jmlmeljmlmel Member Posts: 1
    Hi, I have 2000 Expedition that is doing the same thing. Did you ever get it figured out? Thanks
    slick3299slick3299 Member Posts: 1
    I have a 1999 Eddie Bauer Expedition and the rear a/c is not blowing cold air. The front works great but the rear air is not cold MOST of the time. Every once in a while it may blow cold . Does anyone know what my problem is?
