Hyundai Elantra Lighting
rural43017
Member Posts: 2
When I try to remove the plastic cowling to first remove the battery the phillips head screws turn but won't come out. Any suggestions?
I hope that made sense; let me know.
I can't explain why it happened to both at the same time, unless I had only one light for a while and didn't notice until the second one went out. But the problem was the headlamp bulb socket. The wires going into the socket had a small amount of corrosion on them (apearantly enough) and they didn't work. While trouble-shooting I was jiggling the wires (somewhat vigorously) and the light came on, then repeated on the other side and same thing. So I removed the wires, cleaned and reinstalled them and have had no problem since.
JCH
I replaced the bulb on the driver side to no effect. I switched them and the driver-side light is always weaker.
I never heard of that problem. Some people reported both lights going brighter or dimmer but I never heard of one light being weaker!
Do you have any advice on how to deal with this?
Dan
Luckily for me it was a misalignment. I upped the driver-side light and things are looking OK now. Thanks again.
Dan
has anyone been able to locate upgraded headlight bulbs h11bw yet?
other than oe from the dealer, nobody seems to have them. the i30 website indicates that overseas elantras get h7 low beams instead.
why did hyundai switch the bulbs?
BTW, both of the bulb replacements on my GT were done for free by the dealer, under the bumper-to-bumper warranty. They told me the headlamp bulbs are covered, but other bulbs e.g. turn signals are not.
