Olds silhouette climate control
hoffman693
Member Posts: 1
Does anyone have any idea where the rear blower is for the rear climate control? Is there one? When I turn on the rear it sometimes works and sometimes doesn't. When it does it makes a loud screech sound.
Both mixer motors had same problem: the contact pins that the connector engages had broken off the PC board. Confirmed by unplugging the connector and the pins were stuck in the connector. These pins are soldered to the top side of the PCB and break over time when the solder fatigues. I carefully pried open the plastic motor housing to expose the PCB and soldered the pins back onto the PCB. Taped the motor housing back together and re-installed and they worked perfectly. Be careful to keep the gears in their original position.
The challenge is getting to the motors. You need to pull the rear interior trim (large piece of plastic) that runs from the rear hatch to the driver's side slider door. Remove the seat belt anchors and a couple bolts and then the rest is held in place with trim clips. Once this is removed, the temperature mixer motor is in back near the blower motor and the air diverter motor is located just below where the rear side window meets the rear slider door.
