Pontiac Torrent Noises
i have a 2006 torrent with 40000 km on it and i have developed a very loud humming noise from the front end any idea what it is
Greetings from Colima, Mexico
PS. The warranty is valid to November 2008, and it´s 12500 miles.
The other problem of rough starts is also familiar and may be a major one. Check the level of your engine coolant. Is the exhaust white smoke when you first start up. Mine has been leaking coolant into cylinder #1. May be a leaky intake manifold or worse yet a head gasket.
Have you had your vehicle into your dealer? If not, I would definitely recommend doing so! Please keep me updated.
Christina
GM Customer Service
\also had white smoke from exaust and was leaking into cylinder 1 like someone else was stating
Please keep me updated on your progress at the dealer.
Christina
GM Customer Service
Did you ever find out what the "When I accelerate is is the sound of a rushing river." sound was?
I have an '06 Torrent and i started noticing the same sound when i first start driving few months back.
Thank you for the update in advance.
T
Sarah
GM Customer Service
moreover when the heat is on it clicks as the condinsor and belt of the AC fan work together when heat is on
anyone can help me
Does the click sound more like it's coming from a blower fan, or is it an engine noise? Since you said it's when the heat is on, does the click speed vary with different fan settings?
