Ford Escape Paint
I recently purchased a 2005 Ford Escape which does
have some bumper to bumper warranty left on it and I also bought the extended warranty.The body paint on the driver's door under the window near rubber seal has a bubble forming under the paint(rust! /corrosion)There is no other rust on the outer body.Will the dealer fix this under warranty?I know that the 5 year corrosion warranty
is for perforations only but the paint is warrantied for 3 years..I think.The spot is about the size of a pencil eraser tip.
Mark.
They tell me they won't do anything since the warranty has expired and THERE IS NO RECORD OF ANYONE ELSE COMPLAINING. Well I've seen a few posts around the net about this exact problem. So I would love to hear from you if you have complained about this problem. And I don't care what the colour is.
Help me out folks!
Only Ford and GM provide any paint warranty at all.
Mark.
I've filed a complaint with the FTC, and have already contacted several consumer advocate/attorneys with the complaint with the hope that enough will trigger a class action lawsuit. I suggest you do the same. Also, be sure to rate the vehicle with your experience on sites such as Edmunds to help others avoid the same problem.
On 1/21/09, I became the owner of a Gold Ash Escape with paint missing. It's on the hatch to the right of the license plate holder. The part that has come off is about 6" X 4" and the bubble wants to continue upward.
On 1/22/08, I contacted the dealer and was told that since they no longer have a body shop I should contact one on my own. One of the techs at the recommended body shop said last night he'd speak with the dealer again in my stead as it was "clearly a defect since it's the adhesion of the paint to the primer that has failed." I'll keep you all posted, but suffice to say I'm not happy! Any advice will be appreciated.
I don't think Ford will ever issue a recall because it is not a safety issue where they may get sued for an injury or death related to peeling paint. There may be a TSB but even that does not guarantee you a fix.....sorry!
I found the proper legal language to use that addresses Ford saying that the defect is out of warranty. The "discovery rule" should apply in this case. The discovery rule is a legal concept that "tolls" (suspends) the statute of limitations as it would be impossible to discover the latent paint defect until the paint started peeling off your vehicle. Some judges may decide that the statute of limitations did not comemence running until you actually learned ot that the paint condition on your vehicle was a result of a concealed, latent manufacturing defect.
It's cost me $50 to file the small claims case and $10 to have Ford served. I'll post again once I go to Small Claims Court on Friday.
Ford does have a Facebook page where paint issues have been expressed
on other models.
There was a press release on Vehicle Paint Quality Flaws associated with Outsourcing.
It described a study correlating factory data with paint failures.
Apparently there has been multiple newscasts throughout North America documenting automotive paint failures.
If its out of specification, then it would be a factory paint defect.
Of course my issue is with Mazda-- a body shop here has told me that you can visibly see that the sealant coat is missing between the top coat & ecoat and it is a manufacturers defect. Large sections are just falling off-- when it first happened I thought is way a sheet of paper flying out the back of my car. They also let me know that painting even a portion of the car would (the cost is very high for a full strip/paint of the car). I have had both the Mazda dealership review it and a body shop-- but Mazda refuses to correct the situation. I am pleading my case with the dealership, but I'm very discouraged after seeing similar issues like these are widespread.
This issue seems very large and related as both the Escape and Tribute came off the same production lines in some cases -- I have to wonder if these issues aren't very related and if there is something a group of unhappy customers could do to change this situation if needed. Please see this thread discussion as well (here on Edmunds) link title
I have some of the sheets of paint that came off and pictures of it so I'm going to begin a writing campaign to Ford.
With the economy like it is, I can barely afford gas and insurance and a new paint job just isn't there.
Where do I send (e-mail) them?
