Infiniti G35 Lighting
i recently bought 8000k bulbs for my car i was excited about them and put them in they worked great the next day they didn't even turn on i thought the ballast burnt out, i ordered two new ballast, i put in the right ballast and it worked great and than did the same for the left i changed the ballast but it still did not work can some one help me with this? and also is there a fuse for them because i could not find a fuse for the headlights...thanks
I have NOT found this option to be available on the G.
There are, however, very inexpensive kits available from your local auto parts stores which install easily and will automatically turn your lights on when the wipers are set to On.
This may be your only option.
Z
I don't like them, don't have a need for them, and I'm happy the G doesn't have them.
Go into the various forums and read the numerous threads from people asking how to dismantle them.
Rain sensing wipers are another option that can be hit or miss.
I have them in my 06 MDX and yes, I do enjoy them, but there are times where I wish I could just set them to intermittent and choose my speed.
This is not an option.
In the right conditions, like dusk with a light drizzle rain, rain sensing wipers are crap.
They don't work well and you end up manually sweeping them from time to time.
I like the G the way it is.
This is why car makers like Infiniti have to make decisions on what to include.
The problem is, for those who wanted something and didn't get it, they just assume the manufacturer is cutting corners to save money.
Bottom line is, you can't please everyone.
Z
It certainly was not a buying point for me at all.
I suppose some people may consider that a buying point, and everyone has their own opinions, wants and needs.
I bought the G for it's balance of Luxury/Power/Fun Factor.
If the Lexus IS was available in AWD without the IS250's pathetic power output, I would have bought one in April of 06.... DRLs and all.
The G came along and offered me what the IS and Acura TL did not.
I love it.
On most cars it is a simple adjustment that is on all cars so they can be sold in Canada. When I had a Lexus the service department asked me if I wanted them on or off. I went with on.
I asked at my Inifinti dealer if they could turn them on for my G35 Sedan and they did not know how.
I have thought of calling a Canadian Infiniti dealer to see if they have knowledge of what to do.
Any suggestions?
Thanks, Richard
As far as I know, and from what I have read, DRLs are not available on the Infiniti G35.
Please keep us posted if you happen to find this to be incorrect.
Z
DRLs keep you more visible to other people on the road.
Maybe they were thinking it was unnecessary... an additional cost, and more out of the owner's pocket when it came time to replace them. :confuse:
Second question... does anyone know how I can find the steps to replace the LED assembly myself? I understand the sedan is difficult compared to the coupe. It would be an expensive fix if I take it to the dealer. Someone mentioned the rear seat needs to come out, but I'd need direction to do that as well. I'm pretty handy and can do just about any repair with good directions.
Rob
That may be your best bet.
A bit off topic but can you tell me if you paid duty charges based on the price you paid for the car in US Dollars or the Canadian value of the car? Thanks,
Ron
I just bought a 2008 G35 and am bringing it to Vancouver this week, did you have any luck with the DRL's? I was quoted $700 by Infiniti in Seattle. That seems a little steep.
Why not just have a switch installed to run the fogs when the headlights are off?
That's gotta be way cheaper than $700.
In fact, it sounds like a fairly easy Sunday morning project at home.
Could you please let me know the details of how you brought back your G35 back to Vancouver. I am planning to do the same. Appreciate if you could tell me approximate savings, thanks.
Please help!
I checked with my dealer about a replacement lite unit and they said it was close to $300. The dealer will do the whole job for around $550.
Has anyone else had to deal with this problem?
No way will I spend $550 hard earned dollars for this item. I may try to fit some other kind of unit into it and see how that works.
