Honda Pilot Noises and Sounds
My 2007 Honda Pilot make this "BUZZING SOUND" when I first give it gas (between 10-20 MPH) then it goes away. It seems like something is loose but can't locate anything. Very annoying since car has only 3,500 miles on it.It also happens when truck is in neutral. Before I attemp to bring it to dealer I was wondering if anybody on this site had the same experience and if so what did you do. Please Help!!
The car is at the dealer for 2 days now. They are trying to figure out the problem. Honda dealer would not take my car in unless I was able to show them the problem. Thank God. I was able to duplicate it in their parking lot.
Honda dealer doesn't know what is wrong. They said that if they cannot get it to happen, they cannot do anything about it.
Then today I get in it and the radio shows it's working but no sound.
Anyone else have a sound problem or a squeeky shock?
Has about 400 miles on it now and the following 2 noises just started:
1st Noise: In Drive, sitting at idle while at a light or a drive thru, AC engages (the compressor) and there is a very low frequency hum/booming that resonates throughout the cabin...did not do this previously and both wife and I noticed it at the same time. Either the ANC is using the bass woofer incorrectly to attempt cancelling a noise or an engine mount is not quite up to task...at least those are my current theories.
This morning: Short drive to drop off daughter at school, heard a creaking from suspension...seems to be in back...can duplicate it to a lesser degree when parked and shaking the vehicle.
I've seen other posts on the suspension noises and will have dealer look if it persists. Has anyone else had a low frequency/booming resonance problem at idle?
Otherwise...totally impressed with the smoothness and functionality of the vehicle...just like all my other Honda's.
I also think the vehicle is too noisy with alot of road noise, most of which I attribute to the somewhat sub-standard OEM tires, which are most suited for a sedan than SUV.
When you visit the Ratings of these 2 OEM tires at tirerack.com, you will see BOTH are at very low rating when users were asked "Will You Buy These Tires Again" ... Apparently Honda agreed to use these poor performance OEM tires out of money saving.
I changed to a better set of tire when my 08 had 850 miles - quieter ride & better surer handling. I will mount the set of OEM back when the lease is up in 3 years,
I saw somewhere that the '09 Pilot' was equipped with much better Goodyear OEM tires, plus a 4 year/48k warranty - 1 yr more than the 08 one.
It has always been one of the best actions to do in my opinion. My former SUV's tended to ride on Michelin LT rubber. I like the idea of the heavier tire (even though it can sacrifice some mpg's) for road worthiness but am always looking for the new and best alternatives. I'm also thinking of trying to add a few millimeters of width for a slightly more aggressive stance and the aded cornering support.
www.tirerack.com
+ $49.00 shipping + $79.00 mount & balance ... ttl $496 for set of 4
2 days time to arrive at my installer, picked from the list suggested by Tire Rack.
1 of tire is defective --- found steering has to be at 1 o'clock position to keep the car go straight, slightly pull to 1 side right after installed. Reported problem to the installer, Installer has Hunter 9700 tire balance machine to perform 'Road Force' to identify which tire is defective.
link
Under Tire warranty, they took my VIN# & shipped a new one in 2 days. I will have the defective one replaced tomorrow. Still drive better than the OEM even with defective one on.
1. Good Year Fortera TripleTred ....... $139/ea
2. Avon Ranger TSE ....... $92/ea (white sidewall, can turn inside to be black sidewall
3. Continental CrossContact LX ....... $95/ea
Micheline LTX M/S ($143 - 145) also is one of top rated.
The "Booming" or ultra low hum at idle has come and gone intermittently. Have not been able to discern a pattern other than AC on and sitting in Drive at idle. Not enough of a problem to pursue with a special trip to dealer. :confuse:
Otherwise, we've already maxed out with 8 people on a couple of trips around town and hauled some gear with more than 5 people...nice versatility smooth running continues. Really enjoy jumping in and getting it out when I can wrestle it from my wife.
Tires: I figure road noise will become worse with the OEM tire wear. My most recent set of replacement tires for my old Accord was Bridgestone Turanza's and they've been great. Anyone know of good target replacement tires for the Pilot? I need handling, wet traction, and quiet operation as priority...no snow around here in Houston. Look forward to hearing more!
The other frustrating problem is when I go to pump gas for my Pilot and after several seconds of pumping gas it keeps making the clicking sound as if the tank is full, please keep in mind my tank probably has only two or less gallons remaining, and it does this all the time when I go to pump gas. I have tried different gasoline stations and the problem still persists. I would have to spend like 20 minutes just to pump gas each time because once it click I would have to squeeze the nossle again. It basically click indicating the tank was full every 0.3 gallon that goes into my tank.
Please, please help me out. I would appreciate any advice. Thank you.
Paul
Is the hunming a very low note? We've had this on and off since new (2.5 months old). I'm very suspicious of the ANC (Auto Noise Cancellation) system. This seems to also coincide with low noises from outside. As in, we first noticed it when sitting in a drive thru behind a diesel truck emanating its low engine growl, then when our AC compresser kicked in, on came the humming noise. I also notice it stops the hum if I bump the idle just a little bit.
I can't get it to reprodce enough to take it in to Honda yet.
Will be going to honda tomorrow and I do hope I can reproduce this because if not the honda guys might think I am going nuts!
Another thing the humming sound disappears when ypu open the door a little bit, that's how I knew it could be a vibrating thing. Makes me crazy when I hear that sound.
Will be posting for updates.
Thanks for the reply!
Paul
And yep, my wife is ready to scratch someone's eyes out after sitting with it more than a minute or so.
If they give you trouble at service, tell'em someone else is having the same issue.
Good Luck!
Paul
Hope one of you guys will find the "cure" to this problem, and please do let us know.
Thanks again, will be updating you.
If I can get mine in before a trip next weekend, I'll let you know. I think I won't use the word hum but more of an ultra-low bass note...maybe that will get them on the same page faster.
leroyg
Thanks for posting
Paul
- On our extended weekend trip a day ago, zero problems including this droning noise for the 1100 mile adventure.
- The first return of the noise was in my driveway as I headed out for an errand. So there is reproduceability(sp?) since this is one of the settings in which I had the noise before.
I have heard about complaints of the other year models with a droning noise at different speeds on the road. But so far, the noise described has only occurred as described at idle. I remain suspicious of the ANC system and the motor mounts. Hopefully, we will have time to visit the dealer in about two weeks.
Good luck all...next one to the shop...report back!
Reference Bulletin 06-092, 12/22/06
Service Bulletin
© 2006 American Honda Motor Co., Inc. – All Rights Reserved ATB 34078 (0612) 1 of 1
CUSTOMER INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment,
and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume
this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an
authorized Honda automobile dealer.
December 22, 2006
06-092
Applies To: 2006 Pilot – All LX 2WD models
2007 Pilot – LX 2WD models from VIN 5FNYF2...7B000001 thru 5FNYF2...7B006392
Booming or Humming Noise From Speakers While Driving
SYMPTOM
A booming or humming noise is heard from the
speakers while driving with the radio on or off.
PROBABLE CAUSE
A faulty ANC (active noise control) unit.
CORRECTIVE ACTION
Replace the ANC control unit.
PARTS INFORMATION
ANC Control Unit: P/N 39200-STW-A02
H/C 8563413
WARRANTY CLAIM INFORMATION
In warranty: The normal warranty applies.
Operation Number: 0101C9
Flat Rate Time: 0.6 hour
Failed Part: P/N 39200-STW-A01
H/C 8159055
Defect Code: 03217
Symptom Code: 04201
Template ID: 06-092A
Skill Level: Repair Technician
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
DIAGNOSIS
1. Start the vehicle.
2. Turn the radio on, and make sure it operates
normally.
3. Turn the radio off.
4. Press and hold the preset buttons number 1 and
number 6, then press the VOL push PWR button.
The audio system enters its diagnostic mode and
Diagnosis (or Diag) appears on the display.
Release the preset buttons.
5. Press the number 1 preset button. ANC ON
6. Press the number 1 preset button again to turn the
ANC OFF. You should hear a humming noise
coming from the speakers for about 60 seconds.
NOTE:
• To turn the humming off, press the number 1
preset button to turn the ANC ON, and wait for
the hum to stop. Press the number 1 preset
button again to turn the ANC OFF.
• Repeatedly pressing the number 1 preset button
cycles the audio unit ANC ON and ANC OFF, but
the ANC control unit won’t hum until the ignition
switch is turned on and off, and you put the audio
system back into Diagnosis mode.
• When the ignition switch is turned on and off
again, the audio system defaults to its ANC ON
mode.
7. With the ANC OFF (audio unit on), test-drive the
vehicle as described by the customer. If you can’t
reproduce the booming or humming noise, go to
the REPAIR PROCEDURE.
8. If you can still hear the booming or humming noise,
disregard this bulletin and do the ANC
troubleshooting in the service manual.
REPAIR PROCEDURE
1. Replace the ANC control unit.
• Refer to page 22-345 of the 2006–07 Pilot
Service Manual, or
• Online, enter keyword ACTIVE and select Active
Noise Control Removal/Installation (2WD)
from the list.
2. Test-drive the vehicle to confirm the repair.
PHX1138: The ANC will re-activate itself when you turn the ignition back on. So, we just quickly press the 1, 6, and power buttons on the radio (when off), hit #1 for the noise to first amplify, then hit #1 twice more to activate then fully de-activate the ANC. (more complicated to write than to do)
I'm happy to have found the apparent culprit! That droning noise will make you jump off a cliff after a while.
While driving it this weekend together I heard what she was talking about. It almost sounds like a vent creeking open or something. It is very quick and could almost be a loud beep for a second. Has anyone heard something like this? I see there have been reports of a humming noise. Very confusing.
New rattle developed with the panel covering the subwoofer on the passenger side of the cargo area. I kind fo half expected it. I'm very nervous of the techs tearing it up for investigation and fix but the rattle is not something to live with...even does it without the radio on now. Just one of those things...I'll take it if it's the worst thing that can happen! Rest of vehicle continues its sterling performance.
Costs about $50 to get the leaf removed.
Odie
Odie's Carspace
