Chevrolet Impala Coolant System
WANT TO KNOW MY LOW COOLANT LIGHT KEEP COMING ON SO I WENT TO THE MECHANIC AND HE CHANGED THE SENSOR WELL IT DID NOT LAST THE NEXT DAY I WENT BACK AND HE SAID IT MUST BE DEFECTIVE SO HE REPLACED THAT ONE AND TWO DAYS LATER QUESS WHAT ITS ON AGAIN SO HE TOLD ME HE GOT THE PART AT A NAPA AUTO PARTS STORE AND MAYBE THAT SENSOR IS NOT COMPATIBLE WITH GM SO NOW HE WANTS TO PUT A GM LOW COOLANT SENSOR WHAT AM I GOING TO DO HELP!
I replaced the low coolant sensor ($36 from Rockauto.com), ...problem fixed.
The sensor is located on the right(rear)(pass) side of the radiator (about 1 1/2" square in shape) ...near the battery. It is simple to replace, ...more work to remove the battery to get to it.
As for 'bleeding' the system at the thermostat. This is done to remove air from the system. If you do not bleed the system, ...there could be pockets of air (hence absence of coolant) in the motor, ...which could(will) prevent adequate cooling.
I have replaced hundreds of NEW aftermarket sensors, not because they were broken, but because they didn't work properly. The customers ended up paying twice for the sensor, because they were saving money with the aftermarket parts.
As for the low coolant light coming on, there is a service bulletin on diagnosing and repairing this problem.
Any good mechanic would have checked it.
Bulletin No.: 04-06-02-007
Date: August 11, 2004
TECHNICAL
Subject:
Low Engine Coolant Level Indicator Always On (Diagnose Low Coolant Level System Operation/Check Sensor for Oil Contamination)
Models:
2000-2002 Buick Century, Regal
2000-2001 Chevrolet Lumina
2000-2002 Chevrolet Impala, Monte Carlo
2000-2002 Pontiac Grand Prix
2000-2002 Oldsmobile Intrigue
Condition
Some customers may comment that the low engine coolant level indicator is always illuminated.
Cause
The cause of this condition may be due to engine oil contaminating the coolant. Possible sources of oil contamination are internal engine leaks, improper service procedures, or the addition of some types of anti-leak additives to the cooling system. Once in the coolant, the oil leaves deposits on the level sensor creating an insulating film. This film results in a false activation of the coolant level indicator.
Correction
Diagnose low coolant level system operation and check the sensor for oil contamination using the procedure listed below.
Important: No coolant supplements should be used in GM cooling systems, other than what is approved and recommended by GM. The use of "aftermarket" over-the-counter sealing and cooling supplements may affect the operation of the low coolant level sensor. Discoloration of the coolant recovery bottle is normal and does not necessarily indicate that coolant contamination is present.
It rarely goes in the red, but it gets pretty darn close. I've resorted to turning the A/C off when I'm stopped to help out. I live in the Midwest and in another 45 days, it will start cooling down, so won't have to worry too much then.
I just hoping it's not a serious issue and I can nurse it along another 4 or 5 months.
Only other thing I can think of is we used to have an old Ford Escort, and the controller that regulated the electric cooling fan burned out under the dash. I didn't notice anything wrong with the car until the summer when it would get hot if I got stuck in traffic. Basically as long as the car was moving, there was enough air going through the radiator to keep it cool, but if I stopped for any period of time the car would get hot. So if you notice the car gets hotter when you're sitting still you might have a fan problem.
That's what I'd normally do with this one, but I've got 3 little kids and the last thing I want is to get stranded in -20 degree weather. I also want the new stability control systems for more safety.
I had the auto shop drain and flush the system and replace the thermostat. The system will reach the red zone after a few minutes of operation and blow cold air, then it will cool itself off to normal range. Sometimes it will blow cold air and sometimes it will blow hot air. It seems to lose power when it passes the red zone, but the power comes back when it cools off a little. Drove it for two hours last night with heat in the cab, but it blew cold air and overheated when I entered town. The mechanic wants to replace the head gasket at a $1000. I am not losing any coolant so I'm not sure it is a head gasket. The system has been bled by the mechanic and the dealership at least a dozen times and the problem still persits. Any thoughts?
