Impreza Towing Capability Questions
If this is a stupid question I am sorry. But I have a small 16ft aluminum fishing boat that at most is 1,000lbs. And all the lakes I fish on are within 20min. and I would not excede 50mph. Is this something the wrx could easily tackle? Or would I be looking and lots of problems because of it? Any help would be greatly appreaciated.
Bob
I assume the stock stuff for the rear lighting is puny and there's no extra harness for electrical in the 05, so I'm looking for an aftermarket unit. There must be something out there, right? ((p.s. this thing is completely stock, with almost no options save a factory short-throw shifter and a sub, which are both crap [-the sub is a useless joke!] and a little more rubber on the road with tires and a slightly aggressive alignment. No guages, no gps, horrible audio, big-time understeer, etc. Basically, it's a clean slate that I intend to start throwing stuff at! ))
So I'll be back with more questions . . .
Thanks for the help,
-stretch
-mike
FYI: 2007 and earlier Imprezas are rated to tow 2000 pounds—if the trailer has trailer brakes. If not, they can only tow 1000 pounds. Sounds like you should be okay.
All Foresters, except first-generation models, are rated at 2400 pounds, but with the same trailer brake restrictions, if that's of any interest.
Bob
